Old 05-30-2019, 05:46 PM   #1
N. Coast
Default easy fix for water leaks on side body panels
What do you think... will this work?
N. Coast is offline   Reply With Quote
The Following User Says Thank You to N. Coast For This Useful Post:
feynmanfan (06-05-2019)
Old 05-30-2019, 05:51 PM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default Re: easy fix for water leaks on side body panels
It's not a 'perfect' solution, whereby water can still get in from the sides.
What concerns me is...
Adding the vinyl trim to the top of the molding may loosen or increase the space between the clips and the the body allowing more water. Plus, the trims have been known to rub-out the paint from vibrating/rubbing and the insert may increase the rubbing on the bottom.
Removing the trim and using sealant on the clips is 100% effective.
SD26 (06-01-2019)
Old 05-30-2019, 06:28 PM   #3
pfflyer
pfflyer's Avatar
It's not a 'perfect' solution, whereby Water can still get in from the sides. What concerns me more is, the trims have been known to rub-out the paint from vibrating/rubbing, and adding the trim to the top increase the rubbing on the bottom....
Does removing the trim and using sealant eliminate the vibrating/rubbing? I had my lower cargo panels off after 4 years and I saw no evidence of water infiltration causing any problems. I understand the problem if you insulate but if you don't is it really a issue? This method if it eliminates the majority of the water seems like a lot easier than removing the trim.
Old 05-30-2019, 06:44 PM   #4
OrioN
2008 2500 170" EXT
OrioN's Avatar
To stop the rubbing which had removed the paint down to metal and started rusting, I removed a minimum 2mm of material from the back of the top and bottom of the trims which increase the open space and make the trim float better.
Red: Sticky hole covers that fell off and allowed rain to flood in.
Yellow: Rubbed out paint & rusting.
Green: Clip holes that wept.
The Following 2 Users Say Thank You to OrioN For This Useful Post:
Mickyfin (05-31-2019), SD26 (06-01-2019)
Old 05-30-2019, 10:23 PM   #5
pfflyer
pfflyer's Avatar
So just removing and resealing does not stop the vibration? Surgery needed or you went a step further to make sure? I wonder if the 80/20 gasket in the video would still rub away paint. I don't think it would be a good idea to gasket the whole bottom but maybe intermittent pieces, if the gasket doesn't rub off paint, at the bottom to allow any water that gets in to escape. That would take care of the rattle and I doubt any water coming in from the bottom or sides would make it up to the trim clip holes. I might have to see if I have any rubbing issues like in your picture.
Old 05-31-2019, 03:56 PM   #6
kcshoots
This is a good idea. I just put the tip of the chalk tube over the clips from the inside of the van and squirted chalk onto the clips from the inside, no need to remove the body panels and the chalk pushes from the inside to the outside of the clips and holes.
kcshoots is offline   Reply With Quote
The Following User Says Thank You to kcshoots For This Useful Post:
Dongoose (01-05-2020)
Old 05-31-2019, 04:39 PM   #7
GSWatson
2013 144
GSWatson's Avatar
You canít get to all of the clips from the inside. Itís a simple job to just pull the panels and caulk the clips. I did a whole 144 in a couple hours.
Cheers,
Greg
SD26 (06-01-2019)
Old 06-01-2019, 03:18 PM   #8
feynmanfan
The clip seal has been on my todo list (I bought a 2018 six months ago). This trim solution looked interesting so I bought a small piece of trim.So here are my thoughts:
1. There is a pretty large gap between the body and plastic trim, top and bottom. I suppose there could be paint abrasion on other vans, but looks like plenty clearance on mine.
2. I slid a piece of 80/20 trim in the top gap in the only orientation that made sense. I think a different profile may work but this one is not easy to "fit" and not very secure. Notice how easily he installs and removes.The fellow in the video was candid about this approach and I give him credit for that but clearly planted the seed.
3. So I have two approaches to look at, both I frankly prefer to calking the clips. That will be my fallback.
a - Find a traditional "christmas tree" extruded trim that fits. This is my first choice. I'll share if I find one. There are literally hundreds available online/in stock to choose from.
b - Calk the top gap only. Non hardeniing, will not attack the paint, long life, and available for calk guns. The other criteria is it adheres (not bonds) to the plastic. That will be the trick depending on what it is; ABS, PE, PP, etc). Any guesses what plastic it is?
feynmanfan is offline   Reply With Quote
The Following 3 Users Say Thank You to feynmanfan For This Useful Post:
dynaco1 (06-14-2019), michaeldorian (12-10-2019), SD26 (06-03-2019)
Old 06-01-2019, 03:56 PM   #9
OrioN
2008 2500 170" EXT
OrioN's Avatar
There are only a few pressure points between the trim and the paint. Thermal expansion/contraction plays a role. I'd check the whole length of each trim piece. Secondly, it appears later model year trims had a revision to mitigate the issue.
feynmanfan (06-01-2019)
Old 06-02-2019, 10:39 PM   #10
MN170
This weekend, I just used Sikaflex 221 on the clips and re-installed them. Waited a day and put the side molding back on.
MN170 is offline   Reply With Quote
