Old 03-28-2019, 02:27 PM   #11
Winterbagoal
Default Re: DPF CAUSES AND ACTIONS.
Originally Posted by Bobnoxious View Post
I tried looking for the version I used but couldn't find them.
No problem. I'll probably try the codings for the ones from the LL website, "2011+ Mercedes Sprinter" or whatever they titled it.
When I get a chance.
At a glance, most of the 2011 codings look identical to the "2015 + Sprinter" versions I used that I downloaded from the website, that were part of the discussion thread including a PDF file and comments by GChapell and JDeLong of LL, last year. I had to get my old SGII flashed to 4.22 + for them to work. Theoretically, of course.
Mike.
2018 (2017 Sprinter Cab Chassis) N24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Winterbagoal is offline   Reply With Quote
The Following User Says Thank You to Winterbagoal For This Useful Post:
Bobnoxious (03-28-2019)
Old 03-28-2019, 02:53 PM   #12
Bobnoxious
Here's codes form LL's Website. Not sure if the same I used.
https://www.scangauge.com/mercedes/
Old 03-28-2019, 03:03 PM   #13
Bobnoxious
You were able to get this feature to work?
Old 03-28-2019, 03:21 PM   #14
Winterbagoal
Thanks. I'll try to see if the "2011+ Mercedes Sprinter 3.0L Diesel" codes work. When I get to it.
As for the RGN gauge, it worked for a while last year, then I had an (early) Service A done back in January before we set out on a long trip. While they were changing the oil, they applied a pending recall 2018010004 to my ECU, and the DST and RGN gauges don't seem to work any more, so I was thinking maybe the reflash did something to disable them.
It might just be a case of finding them in my X-gauge list and recoding/re-entering them. When I get around to it, I'll update this thread.
Mike.
Old 04-17-2019, 05:56 PM   #15
Winterbagoal
I recoded/reentered/renamed/saved several of my X-Gauges, DPF, EUP, RGN, and DST with the parameters from the 2011 MB Sprinter section of the LL website. I noticed most of them are identical to the 2015+ GChappell/JDeLong parms. Alas, no change, DST still doesn't increment, RGN ON/OFF doesn't ever change, and the EUP is a mildly fluctuating decimal number near 6.0.
I think the DPF (Particulate Filter Load on my SGII) number is around 50 which is a percent, so it may be accurate. I don't know.
Overall, the gauges that worked prior to applying MB recall 2018010004 (ECU reflash) no longer seem to work.
I may try reloading some of the ones I got from the 2015+ pdf file, but most of them are the same as the ones I just refreshed.
Mike.
Old 04-18-2019, 03:07 PM   #16
Winterbagoal
These are the parms for the RGN X-Gauge from the GChappell/JDeLong list
Regen Status (On/Off) 07E02220A5 C32320000000 2F01 000100010000 RGN
4.22+
Required
I used these last year when I first added the Sprinter specific X-Gauges.
As previously stated, it worked for a while, and with corresponding observed EOT and fWT temperature increases, during the regens.
Maybe I'll try your parms.
Mike.
