Old 06-09-2019, 01:20 AM   #61
BobLLL
Default Re: Agile battery separator
Those starting battery voltages are discouraging to say the least. Either there is a high parasitic drain, or the battery is very weak. Since the battery did not seem to take a full charge from the 10 amp charger, it seems likely the battery is failing. But it is hard to tell for sure from this distance.
There is still the question of why the battery failed so soon in its life. Perhaps it was defective from the beginning. Or there was an episode like Dick described earlier, where some systems remained powered up even after he removed the key. This could have completely discharged and permanently damaged the battery. But I'm just guessing here.
Bob
2011 Roadtrek SS Agile
Old 06-09-2019, 01:27 AM   #62
irvingj
2015 RT SS Agile (3.0L)
OK, now we're getting somewhere... 12.07 is most assuredly low, as far as my info goes. Fully charged should show 12.6 or better.
It surprised me when I first saw it, but one of the voltage charts I have lists 12.06 as equivalent to only 50% of full charge. (!)
Check it further, but it sounds like your starting battery either has a hell of a drain on it or it can't cut the mustard any more.
EDIT: OOPS -- Bob beat me to it.... Have that battery load-tested.
2015 RT SS Agile, 3.0 V-6
Old 06-09-2019, 02:24 AM   #63
Since you have the negative disconnect available ... it's "easy" for you to place a 10-amp ammeter "in circuit" by simply using a typical volt/ohmmeter's "10 Amp" connection option ... usually a 3rd socket that you never use.
Use clip-leads to allow the meter to hang in there *between* the disconnect cable and the disconnect socket.
Do NOT try to start the Sprinter (it'll blow the meter's internal fuse).
The Sprinter will draw significant (but less than 10 amps) current for a few minutes after reconnection, but after that you'll be able to see how much current your "sleeping" Sprinter is asking for.
That would give us a LOT more info.
Old 06-09-2019, 07:18 AM   #64
Inspector
2012 Roadtrek Agile
I will try and get the meter installed to read the amp draw. I'm beginning to think the old battery I had replaced just due to age was a mistake. The new one may have been bad from the start because that's when the trouble began. I want to thank everyone for all your help, it means a lot.
Steve
2012 Roadtrek Agile
Stockton, CA
Inspector is offline   Reply With Quote
Old 06-09-2019, 07:47 AM   #65
Inspector
2012 Roadtrek Agile
Should I charge the battery or for measuring amps it won't matter?
2012 Roadtrek Agile
Stockton, CA
Old 06-09-2019, 10:16 AM   #66
irvingj
It would still read, but probably best to start with a charged battery. Seems like Ohm's law is in there somewhere.... (low voltage = high(er) amps)
Old 06-09-2019, 04:26 PM   #67
I must admit that i'd be impatient and start by using the meter. If results are equivocal, then i'd charge the battery and re-test.
If the "sleeping" draw is much over 100 milliamps (0.1 amp), then something's wrong.
I agree that the battery is a prime suspect if the draw is under 100 ma.
p.s. let's see: 90 amp-hour battery losing 50% overnight. Let's call that 20 hours.
90Ah/20h= 4.5 amps theoretical.
Old 06-09-2019, 07:17 PM   #68
Inspector
2012 Roadtrek Agile
After another night of sitting, the starting battery is 12.04v and the coach is 12.61, I had expected the starting battery to be in the 11's! It's on the charger now. I need to find away to connect my meter leads to the van cable's as my meter leads are needle like probe ends.
2012 Roadtrek Agile
Stockton, CA
Old 06-09-2019, 09:34 PM   #69
Inspector
2012 Roadtrek Agile
I saw a note in my owner's manual that says the windows have to be reset if the connection by the pedal is removed...Is it any different than removing the battery?
2012 Roadtrek Agile
Stockton, CA
Old 06-09-2019, 10:55 PM   #70
BobLLL
No different.
Bob
