mikeysprinter
Here is the 2020 ordering guide. Seems like the prices have all increased slightly (but adds up) and the components in many of the packages has been shuffled.
This is a typo in the X30 price tag, which should be $7975; the gap between the 2CA46 and 2CA4X sticker prices on PDF pg 8. (MY19 DOG shows the correct price).Can anyone clarify something on the 2020 DOG: on the page for standard equipment for the v6 and 4x4 2500 Cargo (p 40 of the PDF), it lists 4x4 Package X30 as $2975 for the 4x4 model. This is unclear to me - does this mean its both standard equipment and adds a mandatory $2975 onto the base 4x4 price of $48595, or can I treat X30 as an option and leave it off?
The answer i was hoping for!Regardless, this is NOT an additional cost.
Heh, with the waitlist I'm on, more likely they add 5k to the cost, just because they can.Maybe you can get the dealer to take 5 grand off the price? Order a 2CA46 with option X30 for $2975. (Let us know how that works out!)
Thanks for the lead, I’ll look into this!The image from the 2018 DOG in post number 8 shows option code V40 described as "FLOOR ANCHORS FOR REAR BENCH SEATS". For the NCV3 vans, in at least some model years, that option code was part of the build if you got a crew van or a passenger van (even if the factory only mounted one bench seat in the crew van). I've also seen V40 labeled as "STATION WAGON FLOOR ASSEMBLY". However, if you got the crew with only 1 bench installed by the factory, the 2nd and 3rd mounting positions were covered by the van floor sheet metal (they could be uncovered by measuring carefully and drilling through the van floor).
I don't know whether the same is true for VS30 models, or if it is how easy/whether you can order V40 on a VS30 van that otherwise doesn't have rails or seats installed. You might look through a 2019 or 2020 DOG for the code V40.
I sure hope LEDs will actually be available for people not named FedEx.Anyone have any idea when the 2021 guide is coming out? It's 2 months past when the last two year's guides have come out...
The rails are not present.Anybody prove one way or the other that a crew V40 has the seat mounting gizmos for the remaining rows?
To further beat the dead horse...The rails are not present.
