Go Back   Sprinter-Forum > General Forums > Off Topic
Off Topic Nonrelated Sprinter things to say? This is the place to be (although certain threads that are politically or religiously charged will be moved to the DZ).
Subforums: Health The Funnies The Danger Zone
Old 06-12-2019, 03:09 AM   #1
Bikes!
Default Home Irrigation Advice
In case someone here is good with home landscape irrigation...
I have an irrigation zone that isnít spraying. I replaced the valve already. When I manually operate the valve, I hear the whoosh of water charge the line but only get barely any water oozing from the sprinkler heads (literally itís just damp at the sprinkler at most). I donít hear continued water through the valve once it charges and no leaks spring up anywhere. So I know the issue is somewhere between the outlet of the valve and the zone.
Hereís where it gets more complicated. The city recently replaced the concrete sidewalk where Iím 99% sure the main line runs underneath after exiting the valve. This work was done over the winter, but last fall this zone worked just fine with good pressure. It seems to me the contractor must have crushed the irrigation line, but could it be something else? Yes I have some big maple trees growing, but I wouldnít think a root system would strangle an irrigation line over the winter and not allow almost any water through.
Thoughts?
Bikes! is offline   Reply With Quote
Old 06-12-2019, 05:34 AM   #2
Bobnoxious
Default Re: Home Irrigation Advice
Are you certain you installed valve properly?
Sounds like the sprinkler supply line may have been crushed. Especially if it was schedule 200. Time to start digging, investigating.
Here's one circuit with 20 bubblers. The Rain Birds are temporary.
Old 06-12-2019, 11:42 AM   #3
John E
Sounds like your line could have been damaged with the sidewalk construction. I'd disconnect the irrigation pipe on the outlet side of the zone valve and open it manually. If water comes out strong, as it should, I'd then expose the irrigation pipe on the far side of the sidewalk, cut into it, and install a temporary pipe (or hose even) from the zone valve to the irrigation line. If the head then work, there is your damage. I'd be that is it.
2016 3500 144WB
John E is online now   Reply With Quote
Old 06-12-2019, 12:02 PM   #4
pfflyer
pfflyer's Avatar
You haven't mentioned anything about checking the sprinkler head. Heads do get clogged and or damaged. I would have started with the sprinkler head and then the valve. Sounds like your irrigation pipe got damaged but still start with the head before you go digging up pipe.
Full time cargo part time camper.
My convertible Sprinter http://sprinter-source.com/forum/showthread.php?t=39367
2013 long tall convertible crew van used for work now
2016 Jayco Melbourne 24K Class C on 2015 Sprinter chassis
pfflyer is offline   Reply With Quote
The Following User Says Thank You to pfflyer For This Useful Post:
Bobnoxious (06-14-2019)
Old 06-14-2019, 12:36 AM   #5
Bikes!
Thank you! I’ll post on here once I confirm the culprit.
