Old 06-12-2019, 10:21 AM   #1
shalev
Question Removing L-tracks
Hi all,
I'm in the process of stripping down the van before the actual build. I've got some L-Tracks installed along the walls which are a bit tough to remove. After drilling one rivet, i tried to see if i can get a crowbar between the l-track and the van wall, just to see if i'm making progress, but it won't budge. There seems to be some sort of very strong adhesive holding it down, in addition to the rivets. Anyone know how one might go about removing those things? Do i need to heat it up?
Thanks,
Shalev.
shalev is offline   Reply With Quote
Old 06-12-2019, 10:35 AM   #2
Mickyfin
Mickyfin's Avatar
Default Re: Removing L-tracks
Usually, to remove rivets you do indeed need to drill them, or if you have a dremel type tool, you could try cutting the heads off with that.
Mickyfin is online now   Reply With Quote
Old 06-12-2019, 11:52 AM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
If they are glued on then try using a cheese wire to cut along behind the L track.
Keith.
36,000 miles from New
Old 06-12-2019, 01:24 PM   #4
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
The track may have been installed with VHB tape included. There are some solvents which are recommended to soften the adhesive. WD40 was mentioned as one possibility.
Some 3M info is here.
Tape Disassembly of VHB Tape bonded materials
https://www.mountmymonitor.com/v/vsp...ve_removal.pdf
Originally Posted by Brian Goldkamp, Owner At Thomas goldkamp Inc
It may not be easy to remove 3m VHB removal adhesive tapes.
Heat
Applying heat is an age old method to remove a VHB tape. You can use a hair dryer to soften the 3M VHB glue. Use heat on the edges of the tape. Then scrap off the glue with an old credit card or a knife. Wipe off the excess with a cloth.
Vinegar
Vinegar can also be used to remove 3M very high bond tape.
Alcohol
You can try using alcohol to get rid of 3M VHB tapes.
Adhesive removers
If you want to remove the 3m tape from a delicate surface such as glass or vinyl, you can use a commercial adhesive remover. There are different types of adhesive removers available online. Such removers can also be used to get rid of grease and other sticky substances.
Other materials
Goo gone, razor blade, and WD-40 are some of the popular materials used for removing 3M VHB tapes.
Thomas G. Goldkamp, Inc. is a leading distributor of tapes, adhesives, and other packaging materials. The company sells high quality products to the clients.
https://www.quora.com/What-is-the-be...-bond-VHB-tape
shalev (06-12-2019)
Old 06-13-2019, 03:35 AM   #5
shalev
Thanks Aqua!
A heat gun and a crowbar did the trick.
Shalev.
The Following User Says Thank You to shalev For This Useful Post:
Mickyfin (06-13-2019)
Tags
l-track
