Old 07-16-2019, 09:40 PM   #1
bennrr
Default Road trip preparation, what spares/tools to take?
Hey all,
Just joined the forum, as I've bought a 2001 311 panel van, converted it to a camper and am setting off to Portugal for 6 weeks with the family. It's been serviced, new filters, oil etc and four new tyres as it had sat for a while. It passed it's MOT, and there's the usual corrosion on it but it seems to run pretty well. It's done 120k miles.
My question is what should I take with me to handle any common issues these vans have?
Cheers!
bennrr is offline   Reply With Quote
Old 07-16-2019, 09:57 PM   #2
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Road trip preparation, what spares/tools to take?
Your 2001 T1N will have the 'older' style of vacuum operated turbo boost control so my suggestion would be a spare solenoid, or 'Pressure Transducer' in MB speak.
https://sprinter-source.com/forum/sh...ad.php?t=67865
Keith.
Edit to add: Do you have a good Sprinter specific scanner (NOT a generic OBD code reader)? If not have a read through the Scanners sub forum. I use an Autel MD802 with good results.
36,000 miles from New
bennrr (07-17-2019)
Old 07-16-2019, 10:06 PM   #3
bennrr
Thanks, I'll pick a solenoid up.
I don't have a scanner, this is my first sprinter so am looking to pick up up knowledge where I can and will have a look at the thread.
Old 07-16-2019, 10:39 PM   #4
The Grand Tour
Banned
Where are you setting off from?
Old 07-17-2019, 11:01 AM   #5
bennrr
The Midlands, ferry from Poole to Cherbourg, down through France and Spain without many stops (hopefully) and cruise down the west coast of Portgual.
I did a similar trip last year in my old VW T3 and a faulty temperature gauge meant that the water was boiling away in the back before I realised what was happening and the water pump went kaput. That was day 2 of a 5 week trip. I've since seen sense and bought something sensible.
Old 07-17-2019, 11:06 AM   #6
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Originally Posted by bennrr View Post
The Midlands...
The Midlands as in the central area of the UK for those not familiar with the location!
(Benrr - Just to clarify, most forum members are in the USA with a spattering of others worldwide).
Keith.
Old 07-17-2019, 11:13 AM   #7
owner
owner's Avatar
Get the Autel AP200 and Autel MB-14 adapter for the round sprinter plug. That is currently the cheapest setup available new and it does work with your ROW T1N.
As for spares, you will want to take things that can leave you totally stranded. A boost transducer will put you in limp mode, it won't stop you from starting or running (although a bit slow up hills).
My absolutely must have things I take are:
  1. Sprinter capable scanner.
  2. cam sensor.
  3. crank sensor.
  4. Fan belt.
  5. Simple tools to replace these.
Either of those 2 sensors will leave you dead in the water. And you really shouldn't drive with no fan belt even though it won't technically leave you stranded like the other two. Any of these can be easily replaced at the side of the road within 30 mins using basic tools. Don't ask how I know that.
I also take an injector and bolt/washer, and some fuel hose if I need to bypass anything. But I wouldn't consider those must haves. The injector is mainly so that I don't get rheemed if I have one die in the middle of nowhere.
The Following User Says Thank You to owner For This Useful Post:
bennrr (07-17-2019)
Old 07-17-2019, 11:32 AM   #8
Patrick of M
2005 T1N 2500 (NA spec)
I travel with
a decent socket set (plus male and female Torx set)
a bunch of wobble extensions etc..
good scanner
multimeter,
lectric tape,
metal tape,
one jack stand (stowed deep, I do not want to use it)
a set of 1/2 in drive larger sockets (also stowed deep)
Jumper cables
12v air pump,
tie wraps
jug oil and coolant ( not sure why my van uses neither)
18V drill, impact driver, flashlight kit (speeds up disassembly, it is work equipment I already have
I would not suggest buying if u don’t already have it)
Needle nose pliers
Vice grips
Olfa knife
Leatherman (mostly used for making sandwiches)
I think that is it, I discovered of course (through this forum) that I should of had JB weld on board as well.
All very fresh in my head as I am 1 week into a 3 1/2 week road trip.
Unfortunately 2 small repairs in as well, so my hands look full on grease monkey, which I don’t enjoy, I like to clean up on holiday (about the only time I can).
Next trip:
nail brush and nitrile throw away gloves.
Final thought, see if your lug wrench can loosen all the wheel bolts, if it can’t get something that can.
I use a 1/2 drive deep socket and a 1/2 drive breaker bar that I stow in the bottle jack compartment.
Also see if the spare tire hanger can actually release your spare wheel and also that the spare is properly inflated.
That spare wheel hanger seizes up if not properly maintained and getting the wheel out will be well neigh impossible
/very lengthy curse laden experience if attempted on the side of the road if it is seized.
Happy travels.
Patrick of Montreal
2005 T1N (NA spec).
Patrick of M is online now   Reply With Quote
bennrr (07-17-2019)
Old 07-17-2019, 11:53 AM   #9
Fuel filter. And check your belt drive thoroughly. Have fun!
bennrr (07-17-2019)
Old 07-17-2019, 12:09 PM   #10
bennrr
Thanks for the replies, I now have a decent shopping list that I hope to never use...
Ah yes, some of the posts make much more sense now!
I think I might have left this a bit late, we go on Sunday and I don't seem to be able to find the adapter in the UK, just china and the US, I'll see if I can beg/borrow one for the time being... If I don't manage to get one, does that mean I'm not going to know if the cam/crankshaft sensor is gone, it'll just be dead and I'll be scratching my head on the side of the road?
Both excellent points. I did take the spare wheel off because it was wrecked and I basically ended up twisting the hooks off instead of loosening the nuts, they are totally corroded on so that 's a job for when I get back. My solution to get it off at the side of the road is to jack the carrier up slightly and twist off the hook with a big wrench. It's worked so far.
Thanks again!
The Following User Says Thank You to bennrr For This Useful Post:
Garandman (07-18-2019)
