Old 07-16-2019, 09:24 PM   #1
SprinterSnake316
Default Sprinter w903 / t1n 4x4 lower control arms (A arms )
Hello fellow Mercedes people , Im hoping a more experienced sprinter technician can advise me on a few things. Firstly I have a sprinter 2006 w903 4x4 allrad . The problem is drivers side front wheel looks and is physically more further back than the passenger . I heard on the grapevine thereís different kinds of Lower control arms that can cause this issue . Has anyone got the part number for the control arm that gets your wheel as far forward as poss ? Iíve put some new wheels and tires on it and itís catching a little . Any advice welcome . Thank you
SprinterSnake316 is offline   Reply With Quote
Old 07-16-2019, 09:29 PM   #2
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Sprinter w903 / t1n lower control arms (A arms )
Another possibility is that your front sub-frame has moved back on one side. Measure from the front of the sub-frame to the reference holes in the chassis to check position. I believe there have been posts in the Australian sub-section detailing this.
Keith.
36,000 miles from New
Old 07-16-2019, 09:33 PM   #3
SprinterSnake316
This was a concern of mine but I’ve seen a few vans stripped down and I don’t remember there being any adjustment in the holes that the subframe bolts go through . Il have a look in morning of s van with no subframe and post a pic . Can you all see the pic ? Just a bit of eye candy for you , il head over the the Australian side then ! Cheers Keith
Jake
Old 07-17-2019, 02:57 PM   #4
SprinterSnake316
Trying to upload some pictures of the sub frame holes
File Type: jpg 081BC332-068B-4F04-BEA4-048A53E243F9.jpg (65.0 KB, 36 views)
Old 07-17-2019, 04:08 PM   #5
SprinterSnake316
Default Re: Sprinter w903 / t1n 4x4 lower control arms (A arms )
Ok guys been looking at a few control arms . I was comparing the measurement from the leading edge to the front of the ball joint housing . And the part numbers . All the ones I measured seem to be exactly the same disputes having differed endings to the part numbers . Still in the dark really .
Part numbers of 2wd vans : Control arms
90400 sg1
90400 sgg
90400 sgv
90400 sga
Part number from both my vans control arms are 90400 SGX
Old 07-17-2019, 04:11 PM   #6
SprinterSnake316
Hereís a picture to look at
File Type: jpg 8E99FB09-3480-4350-92FC-C35EADA93389.jpg (172.9 KB, 35 views)
Old 07-17-2019, 04:52 PM   #7
SprinterSnake316
These pics show the side in question
File Type: jpg E216C7FF-F40C-417E-BA64-2D026E1970B7.jpg (103.2 KB, 36 views)
File Type: jpg E5388AEB-66F1-484A-8D8E-4E82509A21D4.jpg (129.7 KB, 35 views)
Old 07-17-2019, 07:24 PM   #8
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Read this thread from post #4... https://sprinter-source.com/forum/sh...ad.php?t=17642
Keith.
SprinterSnake316 (07-18-2019)
Old 07-18-2019, 10:22 AM   #9
SprinterSnake316
Thanks Keith il have a good read of that now . I did get under the van with a tape measure and the side in question is 3/4mm further back . The other side of the subframe has had a little knock so it’s weird that it’s this side pushed back .
Old 07-22-2019, 09:51 AM   #10
owner
owner's Avatar
This is the DIY thread for front cross member alignment...
https://sprinter-source.com/forum/sh...ad.php?t=18665
owner is online now   Reply With Quote
