Old 07-16-2019, 04:23 PM   #1
Patrick of M
2005 T1N 2500 (NA spec)
Default How long will this roadside repair last?
I ordered a resonator (should of had a spare with me) but the travels continue. I was loosing boost and surging on climbs so was not surprised to find it cracked. 3 layers of metal tape....3 minute, 3 hours, 3 days, 3 weeks.....
File Type: jpg 2F8C6511-135F-4A3A-9E04-8C1222923FD9.jpg (59.9 KB, 69 views)
Patrick of Montreal
2005 T1N (NA spec).
Old 07-16-2019, 05:27 PM   #2
vanski
'05 Box Snow Camper
vanski's Avatar
Default Re: How long will this roadside repair last?
?? if you jb weld the seam it'll be a permanent fix and you can return the other one and spend that installation time kicking back and sipping a cold one
The Following 2 Users Say Thank You to vanski For This Useful Post:
az7000' (07-18-2019), Patrick of M (07-16-2019)
Old 07-16-2019, 05:56 PM   #3
Originally Posted by Patrick of M View Post
... ls continue. I was loosing boost and surging on climbs so was not surprised to find it cracked. 3 layers of metal tape....3 minute, 3 hours, 3 days, 3 weeks.....
The problem I see is that the pressure will work the adhesive loose. Maybe wrap some wire around the tape to help hold the seal? Or daisy chain worm drive clamps around to contact the area of the failure?
I agree that JB Weld will work. Even though it isn't designated for plastic repair, if the application area is roughed up and clean the epoxy should stick. It isn't mega-pressure. 22 psi or so max. JB Weld should take the temperature. Some other epoxies not so much.
Good luck.
Old 07-16-2019, 06:29 PM   #4
Patrick of M
All I had was the metal tape with me. Iíll pick up some jb weld if it letís go again. The metal tape has a fairly high working temperature, Iím interested in whether it actually holds.
Patrick of Montreal
2005 T1N (NA spec).
Old 07-16-2019, 07:22 PM   #5
Bobnoxious
Bobnoxious's Avatar
I have heard some people call similar aluminum tape, 100 MPH tape. Told by a wingnut, under some circumstances, can be used to cover bullet holes in combat aircraft. Dunno, was he BSing???
Extreme heat may soften the adhesive or it will eventually dry it out and fail. I know it does on residential HVAC ducting.
Old 07-16-2019, 08:25 PM   #6
If thats aerospace grade stuff (speed tape we call it), I would give it at least a few hours. Eventually the 200lbs on that seam will cause it to work loose.
In a pinch, you can run a couple screws through the seam at an angle. Pre drill and blow out the swarf.
Old 07-16-2019, 09:09 PM   #7
If you have a destination address the part might be waiting for you upon arrival.
https://www.amazon.com/Dorman-904-30.../dp/B002E323DS
Old 07-17-2019, 01:24 AM   #8
Patrick of M
Yeah that is the plan, as well as the lower hose as Iím not impressed at the contortions necessary to get my fat paws in there. Once more and forget about it.
Patrick of Montreal
2005 T1N (NA spec).
Old 07-17-2019, 11:02 PM   #9
Patrick of M
Lasted 3 hours. It was nice to know that the leak was the problem, now I’ll just fix it again.
Patrick of Montreal
2005 T1N (NA spec).
Aqua Puttana (07-18-2019)
