Old 07-15-2019, 06:25 PM   #1
skwoodwiva
Default fiberglass honeycomb boards for bed slats
The trunk is under my sleeping area.
I would like recessed handles in 3/4 or so light weight boards
that I could easily arrange to access the trunk.
The stock board (2pc) is a bear.
04 freightliner / vista cruiser 170K
skwoodwiva is offline   Reply With Quote
Old 07-16-2019, 04:23 AM   #2
GSWatson
2013 144
GSWatson's Avatar
Default Re: fiberglass honeycomb boards for bed slats
Go with 8 inch pine boards; they have some give so it makes the bed more comfortable.
GSWatson is online now   Reply With Quote
Old 07-16-2019, 02:55 PM   #3
You may have better luck finding foam cored composite panels. You can make your own with 5mm plywood and good adhesive on a foam core.
Old 07-16-2019, 04:37 PM   #4
skwoodwiva
They will be 68 x 12 or less.
Would that be strong enough? I am single now but with a stout woman? Lol.
How would you form a recessed handle?
Thank you.
Old 07-16-2019, 04:43 PM   #5
You obviously need to pick the right materials and thickness, but it would be plenty strong. Worst case you need to bond an aluminum edge on side.
Another option is hollow core flat doors. They have a cardboard honeycomb inside, and are quite strong.
A recessed handle could be routed out, or you could use a through-cut to attach various designs. Over on the expedition portal website there are a couple threads about folks building their own composite panels fro truck bed campers and similar.
Old 07-16-2019, 04:52 PM   #6
skwoodwiva
68 span ,unsupported. At least at rear of battery support risers
Old 07-16-2019, 05:37 PM   #7
rollerbearing
Ditto on the hollow core doors. They are plenty strong and very light. One thing you need to watch out for though is excess knee pressure - the panel surfaces are thin enough that your knee can make a dent and crack through the wood. A layer of closed cell foam or interlocking foam floor matts solves this and makes an underlayer for a softer foam mattress.
Old 07-16-2019, 05:55 PM   #8
OrioN
2008 2500 170" EXT
OrioN's Avatar
If I were to need the thinnest & lightest per thickness for an unsupported span and a single piece: 7075 aluminum sheet.
Old 07-18-2019, 03:04 AM   #9
mofo989
Google: Structural Insulated Panels
Here is a Mecedss van that used them: http://singcore.com/news/sing-core-a...-portable-home
mofo989 is offline   Reply With Quote
The Following 2 Users Say Thank You to mofo989 For This Useful Post:
Midwestdrifter (07-18-2019), skwoodwiva (07-18-2019)
Old 07-24-2019, 01:11 AM   #10
Wheeljack
Wheeljack's Avatar
I used hollow slab doors over IKEA SKORVA cross members. Almost 3 years and still holding up just fine. This is a super light, super cheap, and super easy to remove setup. This, along with my aluminum quick frame and coroplast galley, and factory 2 seater is a super light, fully convertible to empty cargo in under 15 minutes. For some reason, the forum has rotated my pictures and I'm not sure how to fix them.
https://sprinter-source.com/forum/sh...ad.php?t=60475
https://sprinter-source.com/forum/sh...ad.php?t=78350
2010 2500 144 High Roof Cargo Weekender
The BlurrrrrMobile
Wheeljack is online now   Reply With Quote
