Old 07-12-2019, 04:05 AM   #1
Convincent
Default Another won't start thread !
So I've recently acquired a 2005 T1N with 375000. It's never started for me but it turns over .
Before I bore you with what to do next questions is there a write up or trouble shooting guide that I could follow to narrow down the problem? There are a lot of won't start threads but they are all piecemeal and I don't want to miss something obvious.
Convincent is offline   Reply With Quote
Old 07-12-2019, 04:22 AM   #2
The Grand Tour
Banned
Default Re: Another won't start thread !
You're asking us to teach you diesel no-start diagnosis over the internet?
Old 07-12-2019, 04:24 AM   #3
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
Is there diesel in the tank?
There is no guide, you need to describe your symptoms in as much detail as you can type.
Does the tach needle move when you crank it over?
Do you have a sprinter capable scanner? Is there a check engine light?
'06 Sprinter ~270K
'83 Mercedes OM617 manual
The Grand Tour (07-12-2019)
Old 07-12-2019, 04:26 AM   #4
The Grand Tour
Banned
It takes three things to make an internal-combustion engine run- compression, ignition, and fuel.
In the case of diesel engines, the ignition comes from the engine's compression itself.
So if it's delivering fuel, then it might be prudent to perform a compression test and/or leakdown test of the engine, to determine the engine's mechanical integrity, to see if the engine is actually capable of running. You don't want to be throwing expensive parts at something that isn't capable of running.
Old 07-12-2019, 04:40 AM   #5
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
That simplification is true of IDI engines (12V Cummins, OM617's, Ford IDI's, etc) but falls short in more modern commonrail/computer controlled injection beasts. What is missing in that equation - and a large percentage of no-start issues with a sprinter - is ELECTRONICS
'06 Sprinter ~270K
billintomahawk (07-12-2019)
Old 07-12-2019, 05:17 AM   #6
Convincent
lol, sorry for asking a dumb question, I dont expect to fix the problem with a quick guide, but rather a list of questions like you guys have started listing that I can run down and get answers to without wasting peoples time.
I've got a 2003 Jetta diesel that I do all the maintenance on and I've read probably too much about t1n's that their various problems so have a decent idea of which tree to go barking up but thought that there may be a list of basics or a guide that I was missing somewhere that would make the whole process faster.
SO the long story... van was running used by fedex then bough and used by and expediter for a few years, it had black death that probably got pretty bad and went to the a guy to get worked on. Story is the guy was doing it all wrong and cracked the valve cover (due to stuck injectors) and the owner got pissed that he was messing things up and took the van back. His son then posted it for sale because he knew his dad wouldn't have time to work on it. They replaced quite a few suspension parts and the rust is really not too bad on it so I bought it for $2500 to have a shot at fixing it up.
Right now the injectors are all stuck (except #4) and unbolted (cant be re-bolted without first cleaning out the threads and all the rest of the black crap (which is on the todo list). Fuel is getting to the injectors at an unknown pressure.
When turned on (but not started) the PARK, Battery, ESP, Engine and ABS? (slipping wheel?) lights are on.
Obviously the compression is super suspect as all the injectors are unbolted, even if they are stuck.
Diesel flow is good, although pressure is unknown.
I have just a basic bluetooth OBDII
Initial codes were U0423, P0336, P0303, P0087, P0672, P0671, P0380
After clearing the following returned: P0087, P0672, P0671, P0380
I'm in SE Indianapolis if there is anyone in the area with a proper sprinter computer that would be fantastic!
Tac does bounce up to about 200ish when cranking the engine.
I was hoping (dreaming?) that I could get the engine to start and run it till its hot and or the injectors pop loose so that I can finish cleaning up the and replacing the valve cover and put in new washers and bolts on the injectors.
The Following User Says Thank You to Convincent For This Useful Post:
Old 07-12-2019, 05:28 AM   #7
BrennWagon
Pete
Have you checked your grounds? The 671 and 672 can be concurrent with a poor engine chassis ground strap. Engine often turns over but won’t start with a bad ground. A quick and easy check is to run a jumper cable from clean bare metal on the engine to the negative battery terminal.
This is just based on my experience but it’s free and easy. Good luck
BrennWagon is online now   Reply With Quote
Old 07-12-2019, 06:05 AM   #8
Convincent
I tried the grounding jumper cable, cleared the codes and the following showed back up:
P0672
P0671
P0380
Battery is about out so had to stop cranking. Not sure if (P0087 is Fuel Rail/System Pressure - Too Low ) disappeared due to the jumper cable or just hasn't shown back up.
weirdly now the drivers side door won't unlock or open even from the inside, but that is probably random and unrelated. The doors and locks need a lot of work too but I figured I better focus on getting it to run before sorting out all the other parts.
Old 07-12-2019, 06:44 AM   #9
Nautamaran
2004 140 SHC U.S. T1N
Nautamaran's Avatar
Some guesses/checks to make:
- Fuel rail pressure needs to reach (3500?) psi before the ECM will trigger the injectors...
- injector wiring may have been damaged during black death repairs
- cam position sensor wiring damaged / unplugged
- air in injector hard lines (easily primed by cycling the key ON with fittings loose to run tank pump)
- low compression (injector seals passing?)
A tiny whiff of ether into the fender intake grill during cranking may give you the cranking speed needed to overcome leaking injector seats, build fuel pressure/compression, and get it to fire? Note that too much starting fluid CAN damage the engine.
PB Blaster and oven cleaner are weapons of choice in dealing with the coke/carbon/tar. Perhaps a small pencil torch, low on the injector body (stay below the fuel fitting to protect the solenoid cap) can get heat down into the bore to soften the tar back to a goo, then use a clawed slide hammer?
If the cover crack isn’t too bad it might be sealed with epoxy? JB Weld has been used by some after prying against the cover and cracking it.
-dave
The Following 3 Users Say Thank You to Nautamaran For This Useful Post:
billintomahawk (07-12-2019), DesertAdventures (07-19-2019), Midwestdrifter (07-12-2019)
Old 07-12-2019, 07:05 AM   #10
The Grand Tour
Banned
lol, sorry for asking a dumb question,...
No apology necessary- your question is not dumb, and there are a lot of smart people here that are willing to help.
As I'm sure you've noticed, a variety of posts in response to your question (most of which were posted by people with no vocational background in auto repair) are sending you in a different direction. The reason they're all sending you in different directions, is because they are guessing. And guessing is by far the most time-consuming and expensive method of vehicle repair. I recommend diagnosis instead. Diagnosis follows a logical path, and it starts with the basics.
It is not my intention to cause anyone embarrassment, but I'll share with you that at least one of the guessers is a self-admitted user of illegal narcotic psychotropic drugs, so I wouldn't place any value on anything he says.
There is a logical progression of steps in auto repair. They are referred to as "the four C's". The four C's are Complaint (your symptoms), Cause (determining the Cause of your Complaint via diagnosis), Correction (the repair to resolve the Cause of your Complaint), and Confirmation (the road-test to confirm that the Correction resolved the Cause of your Complaint). If you skip one step, or get one step wrong, you're gonna have problems.
You did a pretty good job of describing your Complaint- the vehicle doesn't run, but it does crank over. You also described the age and miles, and gave the background information that it's never run for you. I think you communicated that stuff pretty well.
So now it's time for the second step- determining the Cause of your Complaint. For the reasons I stated above, it's important to follow a logical progression of diagnosis, instead of just guessing.
My recommendation, as I stated previously, is to find out if the engine is even capable of running, before you go spending any other money on it or wasting any more time fooling around with any of the peripheral subsystems. If fuel is being delivered, I would recommend determining the sealing ability of the engine, by running a compression test and/or by performing a leak-down test.
