Old 06-29-2019, 11:13 PM   #11
Kevin.Hutch
2011 Mercedes 313 906
Kevin.Hutch's Avatar
Default Re: New Sprinter Owner
If your setup has the alternator charge the Auxiliary battery via the standard Mercedes ignition operated relay then connecting a charger to one of your batteries will only charge that battery when the ignition is off.
You will need two chargers or a voltage sensing relay (VSR) to charge both batteries and be sure you chose a multistage charger so you do not overcharge your battery.
I second Erics concern, extraneous wires especially still connected at one end can be a disaster waiting to happen.
Kevin Hutch
MB 2011 diesel NCV3 313 (906 635) 4325mm (170") WB high roof 651955 2143 95kw engine
Talvor 2012 conversion Rego 2013.
Be part of the solution not part of the problem
Kevin.Hutch is offline   Reply With Quote
Old 07-02-2019, 10:59 AM   #12
Aussie 2002 4x4
Aussie 2002 4x4's Avatar
Time for this pic again? Many were live and simply cut...including a hefty unfused one under the passenger seat
Aussie 2002 4x4 is offline   Reply With Quote
The Following 2 Users Say Thank You to Aussie 2002 4x4 For This Useful Post:
Bobnoxious (07-03-2019), phiblack (07-03-2019)
Old 07-06-2019, 01:15 AM   #13
Kevin.Hutch
Be interesting to know how many kilograms of copper that represents.
Kevin Hutch
