Old 02-28-2019, 02:42 PM   #21
Default Re: Yet another jacking question
Originally Posted by Bobnoxious View Post
Vic, following manufacturer's safety recommendations should not be construed as "Fearmongering."
Suggesting that the factory tire change jack points are the only "safe" place to bear a jack...
I have, as well you and others, have lifted many vehicle's from the pumpkin without damage. However, in my case, the vehicle's were much older and more stoutly constructed in contrast to today's vehicle constructed and scaled to reduced weight.
Supporting data? (Pun intended.)
Documented examples of damaged Sprinter axle tubes?
Many pumpkins now have plastic covers.
Sprinters don't.
There's at least one post documenting a pumpkin leaking as a result of a tire shop lifting at the pumpkin.
Again.
Yes Sprinters are damaged by people using incorrect jacking methods.
Shock mounts are damaged, body metal gets damaged, front structures get bent/metal tearing by not using blocking, differential covers get bent to the point of leaking because proper pads aren't used, etc., etc. All that stuff happens because the correct locations are not selected and proper methods aren't applied.
Video was certainly informative but too fast paced for my low bandwidth visual cortex. So, I took screen shots of the alternative lifting points.
The takeaway from your second screen grab should be that if using a floor jack with padded cup, the frame rails are perfectly fine to jack against to lift a Sprinter... not to imply that there aren't many other industry standard safe choices too.
To repeat.
Mercedes has a very specific list for where NOT TO jack a Sprinter when using a floor jack. Of course that list isn't all inclusive. They specify not jacking against axle tubes. If the differential case is a problem wouldn't it make sense for them to include that along with the axle tube comment? It is all the same assembly.
Jack as you wish. Carry on.
Bobnoxious (07-17-2019)
Old 02-28-2019, 05:25 PM   #22
flylikeabanana
I remembered I had a grinding bit for the dremel. I was incredulous that the little guy would do it and it took a pretty decent amount of time but I managed to shave down enough to fit after about 20 minutes or so and shaved me a trip to the shop. Going to echo pfflyer's success here, thanks Bob!
flylikeabanana is offline   Reply With Quote
The Following User Says Thank You to flylikeabanana For This Useful Post:
Bobnoxious (02-28-2019)
Old 07-17-2019, 07:01 PM   #23
white whale
white whale's Avatar
and one more.... is there a front jack point in the middle to use the OE bottle jack to get both front wheels off the ground and then bring back onto proper stands to support.
OM647 2500 Dodge cargo
2006 158 WB Super High Top
375K km Outfitting for Baja Mx adventure
white whale is offline   Reply With Quote
Old 07-17-2019, 07:52 PM   #24
Absolutely not.
I use a 3" x 4" hardwood block to bridge the front cross beam flanges when I lift using a floor jack. Even with a hardwood block a bottle jack is not safe in that position.
Old 07-17-2019, 08:17 PM   #25
Bobnoxious
Bobnoxious's Avatar
Pictures?
Old 07-17-2019, 08:54 PM   #26
marklg
Here is what I have found to be the best for me:
For the rear, I put a floor jack under the three sides of the metal frame member supporting the spring shackle and a tall jackstand under the curved piece it fits.
In the front, a floor jack under the frame behind the wheels:
And a tall jackstand under the curved piece it fits in front of the wheels:
I also add RV jacks to other places on the frame just for belts and suspenders.
https://www.campingworld.com/ultra-s...f-4-85164.html
I have a total of 5 things holding it up, two jackstands, two RV jacks and the floor jack whenever I am under the vehicle.
Regards,
Mark
Old 07-18-2019, 02:25 PM   #27
billintomahawk
'02 2.7 T!N Freightliner
If you are a skinny old man, for working underneath, driving up on a couple of pieces of 2"X8" front and rear is wonderful.
A large plastic tarp positioned first makes backsliding so easy.
Don't forget new batteries for the headlamp.
Or rechargables.
https://www.amazon.com/Panasonic-KJ1...s%2C345&sr=8-6
bill in tomahawk
billintomahawk
2002 T1N Freightliner
OM 612 2.7L
Transporter 1 Neu 154HP
2500 140"WB, low top
Tank, the repurposed van
Old 07-18-2019, 07:41 PM   #28
For those that don't recognize them ...
Mark's "jackstand" points are where MB says to position the bottle jack.
His "floor jack" points are where MB says to position a four-point lift:
--dick (who prefers cardboard under his back instead of just a tarp.. the gravel doesn't poke through)
The Grand Tour (07-18-2019)
Old 07-18-2019, 09:13 PM   #29
marklg
Attachment 115603
Absolutely right, but I found Mercedes explanation very hard to understand. They said you can use a floor jack but don't put it these places. They didn't say where you can put it. After a lot of head scratching, I put them in those places but it was very difficult to determine if it was consistent with their recommendations.
Regards,
Mark
Old 07-19-2019, 02:59 AM   #30
Regards,
Mark
I suspect that it relates mostly to legal implications.
In my experience there are many, many suitable places to jack up a vehicle, but what is appropriate and safe can change with conditions/situations. Experience and common sense can go a long way.
In over 8 years of ownership I have yet to use the OEM tire change jack points or the OEM tire change jack for lifting my Sprinters. The OEM tire change jack fixtures are tool specific and don't necessarily lend themselves for use with a roll around floor jack or the jack stands which I use.
The Grand Tour (07-19-2019)
