T1N Talk General Discussions related to T1N Sprinters. |
#11 |
I din't think you'd flattened the saddle, merely that you'd filled it with the flat-on-top "temporary wood spacer"
(and only in the photo that had the pointer) Patrick wrote: "Speaking of which no one reminded the OP not to depend solely on a hydraulic jack." Bob's final photo clearly showed additional bracing ![]() --dick
2005 T1N 118" Freightliner 2500 Passenger Wagon (2.7L, 15" tires, standard (short) roof) Get YOUR Sprinter's full configuration datacard by entering your VIN to https://www.datamb.com/ http://diysprinter.co.uk/reference <-- lots of service documentation, Thanks to Jens Moller and Arnie_Oli ((as always: this post may go through a couple of post-posting edits... so maybe give it ten minutes before commenting)) |
The Following User Says Thank You to autostaretx For This Useful Post: | Bobnoxious (02-27-2019) |
#12 |
The jacking points are provided to be used with the included OEM tire changing jack.
They are not the only safe places to use to lift the truck. Even the hydraulic lifts at the Mercedes dealerships don't necessarily include using the OEM tire jack lift points. Both my 2004 and 2006 have fully operational OEM hydraulic jacks/tools. I have used them on trailers, I have yet to use any on the Sprinters. That 2 stage high lift jack does work great on trailers BTW. I carry a small floor jack in each Sprinter complete with some blocking. The times I've needed to lift a Sprinter when not at home, those floor jacks have worked fine. Personally I wouldn't get too hung up on exclusively using the OEM tire change jack points. That approach will leave many perfectly fine tried and true truck lifting methods off of your list. A Sprinter is afterall just a truck. Added: This for example. AxleJack.jpg NOT this. JustStupid.jpg Before anyone jumps in with "Don't lift on the axle tube", that official warning is included under the Floor Jack cautions. fluid.JPG ![]() P.S. - Many fleet vehicles have had their jacks/tools removed as SOP. Not all missing OEM hydraulic jacks were stolen.
DAD NAS (N. Amer. Spec) 2004 140 2500 >330,000+ mi. 2006 Freightliner 140 2500HC >183,000+ mi. Arctic Whitewash (Spotted Snow Leopard accents) "My opinion and worth everything you'll never pay for it." assumed. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR 16 ounces of unnecessary prevention can be worth a pound of manure. Last edited by Aqua Puttana; 02-27-2019 at 11:48 PM. |
#13 |
My jack is precisely the one that Bob posted, and facing the jack saddle was definitely one of the options I was thinking about. I have access to a hammer though, not a grinder, but I'll hunt around and report back.
#14 |
Made some minor mods to jack.
#15 |
There was once a looonnnngggg thread about jacking on the differential pumpkin.
I'm amused to see that the "hoisting" chapter does NOT forbid it. --dick ![]()
#16 |
2005 T1N 2500 (NA spec)
Was the long thread forbidding lifting via pumpkin? I sometimes lift cars by the pumpkin, don’t think I would lift a sprinter like that, although empty and in a rush to put winter wheels on, I might/might have?
Patrick of Montreal 2005 T1N (NA spec). |
#17 |
It was a looonnnngggg thread because it had proponents of both camps: "lift" and "don't lift".
No final "resolution", the two camps still happily exist. https://sprinter-source.com/forum/sh...0965#post90965 https://sprinter-source.com/forum/showthread.php?t=1325 https://sprinter-source.com/forum/sh...ad.php?t=20493 Msg#7 in this thread ended up with a damaged differential: https://sprinter-source.com/forum/sh...ad.php?t=61664 --dick p.s. this is about a 2008 and an MB tech saying "don't use the diff": https://sprinter-source.com/forum/sh...ad.php?t=33506
2005 T1N 118" Freightliner 2500 Passenger Wagon (2.7L, 15" tires, standard (short) roof) Get YOUR Sprinter's full configuration datacard by entering your VIN to https://www.datamb.com/ http://diysprinter.co.uk/reference <-- lots of service documentation, Thanks to Jens Moller and Arnie_Oli ((as always: this post may go through a couple of post-posting edits... so maybe give it ten minutes before commenting)) Last edited by autostaretx; 02-28-2019 at 02:39 AM. |
#18 | |||
Again.
Yes Sprinters are damaged by people using incorrect jacking methods. Shock mounts are damaged, body metal gets damaged, front structures get bent/metal tearing by not using blocking, differential covers get bent to the point of leaking because proper pads aren't used, etc., etc. All that stuff happens because the correct locations are not selected and proper methods aren't applied. I have yet to see any documentation where jacking a Sprinter up using a properly padded floor jack cup against the differential case has caused axle tube failures. Please provide the data if you have it. Back in 2010 I searched for any documented axle tube failures related to jacking the differential case. I found none. I have been asking for some documented axle tube/differential failures since 2010. I have yet to have anyone produce any data. Lift your Sprinters however you wish. I have no problem with members telling others to apply caution and offering specifics as to lifting their Sprinter. I don't believe that fear mongering is productive. ![]() Quote:
DAD NAS (N. Amer. Spec) 2004 140 2500 >330,000+ mi. 2006 Freightliner 140 2500HC >183,000+ mi. Arctic Whitewash (Spotted Snow Leopard accents) "My opinion and worth everything you'll never pay for it." assumed. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR 16 ounces of unnecessary prevention can be worth a pound of manure. |
The Following User Says Thank You to Aqua Puttana For This Useful Post: | ptheland (02-28-2019) |
#19 |
Vic, following manufacturer's safety recommendations should not be construed as "Fearmongering." I have, as well you and others, have lifted many vehicle's from the pumpkin without damage. However, in my case, the vehicle's were much older and more stoutly constructed in contrast to today's vehicle constructed and scaled to reduced weight. Many pumpkins now have plastic covers.
There's at lest one post documenting a pumpkin leaking as a result of a tire shop lifting at the pumpkin. Video was certainly informative but too fast paced for my low bandwidth visual cortex. So, I took screen shots of the alternative lifting points. Last edited by Bobnoxious; 02-28-2019 at 05:37 AM. |
#20 |
I can say Bob's solution of milling/grinding a little off the jack/jack stand saddle works. It doesn't take much effort or heat generated to get the excess off. The curve of the jack/jack stand saddle is close to the factory jack point as well.
Full time cargo part time camper. My convertible Sprinter http://sprinter-source.com/forum/showthread.php?t=39367 2013 long tall convertible crew van used for work now 2016 Jayco Melbourne 24K Class C on 2015 Sprinter chassis |
The Following User Says Thank You to pfflyer For This Useful Post: | Bobnoxious (02-28-2019) |
Thread Tools | |
Display Modes | |
