Go Back   Sprinter-Forum > General Forums > The Competition
The Competition Discussion of other vehicles similar to the Sprinter; Transit, Promaster, etc.
SubForum: Write-Ups
Old 12-27-2018, 07:33 PM   #1
asimba2
2016 4cyl High Roof 144
asimba2's Avatar
Default Man TGE high roof 4x4 van
They say the grass is always greener on the other side. I want to share a van that I wish we could get here in the U.S. It's a MAN TGE, based on the VW Crafter (which used to be built in the same factory as the Sprinter).
I like it over the 4x4 Sprinter because:
- in my opinion it has a much better 4WD system. It's a full-time 4WD with a more favorable torque-split (than Sprinter) AND a push-button locking rear diff.
- the Sprinter/Oberaigner 4WD requires a 4" BODY lift to make it work. The Crafter/TGE system was designed to go in the van and doesn't require a stupid tall body. A body lift nets you no more clearance under the axles than a 2WD van.
- twin turbo 4 cylinder engine. I'm so disappointed MB dropped the OM651 4 cylinder because it's a far better engine than the V6.
- 6-speed manual transmission. I'd give just about anything for this but know I'm the minority.
I will take one in gray + a 2" suspension lift, please.
asimba2 is offline   Reply With Quote
The Following 2 Users Say Thank You to asimba2 For This Useful Post:
pdxkid (01-30-2019), slem (12-30-2018)
Old 12-28-2018, 04:19 AM   #2
GSWatson
2013 144
GSWatson's Avatar
Default Re: Man TGE high roof 4x4 van
Drooling....
GSWatson is offline   Reply With Quote
Old 12-28-2018, 05:23 AM   #3
mexm123
Wow, that is an interesting alternative. But is AWD really better than the 4x4 system of the sprinter?
mexm123 is offline   Reply With Quote
Old 12-28-2018, 03:52 PM   #4
Sprinter 4x4
We have the vw version of this in the uk I have driven one and itís very nice , but itís not a 4x4 as such itís front wheel drive when it detects wheel spin it then engages the haldex diff and puts drive to all wheels and applies the brakes to the spinning wheel . I feel totaly the opposite to you I want something higher off the ground as the bumpers hit ruts in the ground easily , so I have been waiting for the new sprinter 4x4 as itís higher . The vw crafter is also now available in 4 motion with an 8 speed auto box itís a lovely drive but expensive at around £50000 with a few options on it
Sprinter 4x4 is offline   Reply With Quote
Old 01-02-2019, 03:14 PM   #5
asimba2
asimba2's Avatar
The 4x4 system in the Sprinter is about as weak as a 4x4 system can be. 35/65 torque split, no all wheel drive mode, not shift on the fly (and not that easy to get in and out of 4WD), and no lockers. But in a 9.5' tall van, you're going to be limited by more than just the 4WD system, so it's good enough for most.
The TGE/Crafter is permanent all wheel drive and the Haldex center diff starts tranferring torque when slip is detected. It can send as much as 60% of it's torque to the front or rear, whichever has more traction. (The Sprinter can only send up to 35% to the front.) The TGE/Crafter also has a locking rear diff. I have one on my 4Runner and it's night-and-day from just being in 4WD. The TGE/Crafter would run circles around the Sprinter. That said, the TGE/Crafter could benefit from a small suspension lift, which would give it better clearance than the Sprinter's body-only lift.
The Following User Says Thank You to asimba2 For This Useful Post:
dynaco1 (07-01-2019)
Old 01-02-2019, 10:00 PM   #6
Sprinter 4x4
Unless the one in the USA is different it isnt permanent 4 wheel drive itís front wheel drive they might call it that but itís not driving all the wheels all the time only when it detects wheel spin it then does as you say , having driven both the crafter 4 motion and sprinter 4x4 the sprinter is far better off road as the crafter bottoms out all the time . The only lift option hear in the uk is a seikle lift suspension,this only gives you an absolute maximum raise of 51 mm and thatís by then fitting bigger tyres it is an improvement but still not as good as the sprinters aproche and departure angles . I am currently waiting for the new model sprinter 4x4 to be available to drive before deciding which one to buy .The crafter is a very nice drive I love it but the ground clearance is a big issue with both front and rear bumpers hitting the ground , the sills also in the middle of the van will also bottom out very easily going over rough terrain, if you are just going to use it on the road then itís not a problem , build quality on the vw is very good , and no rust issues like the sprinter , time will tell what the new one is like . I have several friends that have the new shape sprinters and they are experiencing quite a few problems mainly electrical issues with hand brakes and the Satnave system information centre thing
The Following User Says Thank You to Sprinter 4x4 For This Useful Post:
marc1 (02-23-2019)
Old 07-01-2019, 07:09 AM   #7
Wyuna
Yeah there isn't many lift Options for the new Crafter, but Seikel do make a nice balanced lift kit, which is normally a 30mm lift plus the option of oversized tires.
I believe its got to do with the CV Joints angle from what they told me.
I put the Seikel lift kit on my 2017 T6 Transporter Campervan and larger KO2's to get to a 48mm lift, (i can't go more than 50mm here legally without a ****load of testing and paperwork) it hasn't let me down yet.
Wyuna is offline   Reply With Quote
Old 07-02-2019, 01:15 PM   #8
kcshoots
Are you kidding? I'd love at least a 7-speed transmission and 8 or 9 would be even better. It'd significantly reduce the turbo lag, accelerate better, have a higher top speed, have improved fuel economy and thus range, as well as run quieter and reduce emissions. I feel that the Sprinter 5-speed transmission is one of it's greatest faults, along with the associated turbo lag. And the second being that 4-wheel drive can't be shifted in and out on the fly.
kcshoots is offline   Reply With Quote
Old 07-02-2019, 02:32 PM   #9
asimba2
asimba2's Avatar
Gearing makes a huge difference. When I drove the 4 cyl/7-speed and the V6/5-speed Sprinters back-to-back, the 4 cylinder version felt like an entire generation newer vehicle. I couldn't believe the difference. And for fuel economy, I get close to 50% better fuel economy than a Sprinter 4x4 V6. Now if we could just have an AWD Sprinter WITH the 4 cylinder diesel...
Old 07-07-2019, 06:59 PM   #10
Ed463
I really like the look of these. I just spoke with someone who has both a 4x4 Sprinter and a MAN. He rates the MAN higher, to be expected I guess it's a far newer design.
The only downside with the MAN being the lack of a reduction gear. But apparently this is in development.
Surprisingly good value as well. I've found one with 400miles on it for $47k.
Ed463 is offline   Reply With Quote
