Go Back   Sprinter-Forum > Classifieds > Other items For Sale / Wanted
Other items For Sale / Wanted Post For Sale or Wanted items. NO Sprinters.
Old 11-07-2018, 04:48 PM   #1
vtsoundman
Default FS: CA - Dometic Brisk II 13,500 BTU A/C Black RV Van Roof Top Air Conditioner
Black Dometic Brisk II A/C unit removed from Sprinter van - barely every used. Capacitor soft start installed to make starting on small generators and inverters easier. Unit is approx 2yrs old, van had <8,000 miles when removed and hardly ever used. This unit is a ducted unit - so it will require a 'pretty panel' if you want to install it w/o ducts in your RV or van. Has a small crack (typical) in the outside housing and some small scuffs (from trees). Was working when removed.
This unit is extremely efficient and very powerful. Comes with Remote thermostat and fan speed switch.
DOMETIC BRISK II AIR
13,500 BTU ROOFTOP AIR CONDITIONER, DUCTED APPLICATION.
The Brisk II's smart design and improved materials combine to maximize air flow and performance. It is best-in-class of any standard RV rooftop air conditioner for weight, air flow and capacity. Tested for use in extreme conditions.
13,500 BTU
COOLING CAPACITY
LIGHTWEIGHT
UNDER 75 LB / 34 KG
EASY INSTALLATION
https://sfbay.craigslist.org/nby/pts/d/dometic-brisk-iibtu-c-black/6743086164.html
$350
SF Bay Area. Respond via PM or CL Ad
vtsoundman is offline   Reply With Quote
Old 11-07-2018, 05:09 PM   #2
vtsoundman
Default Re: CA - Dometic Brisk II 13,500 BTU A/C Black RV Van Roof Top Air Conditioner
Pics
Old 06-05-2019, 08:31 PM   #3
vtsoundman
Default Re: FS: CA - Dometic Brisk II 13,500 BTU A/C Black RV Van Roof Top Air Conditioner
Sold
