Old 07-03-2019, 06:30 AM   #11
sikwan
06 T1N Can
sikwan's Avatar
Default Re: Underlined blue after Youtube
If you use a youtu.be link, it will look like this...
http://youtu.be/xBdpINm9UBU
The above link redirects to the correct youtube.com link, which looks like this
I inserted a space so it doesn't parse...
Code:
https://www.youtube.com /watch?v=xBdpINm9UBU&feature=youtu.be
The embedded video...
Youtu.be links are not parsed.
Garandman (07-03-2019)
Old 07-03-2019, 07:40 PM   #12
Originally Posted by Garandman View Post
So what is the tag for embedding a video? Don’t see it on the menu.
To quasi-translate Sik's answer:
If you want the "player" and video splash image to appear, just insert the YouTube(.com) address.
No tags or mark-up needed.
IF you do NOT want the embedded player and splash, then use the youtu.be construct.
(again, no tags needed as you're typing, but the forum will add the URL tags automatically)
