Old 10-05-2018, 09:04 PM   #71
Default Re: Autopsy: Infamous "Y" cable from alternator to starter to battery
Originally Posted by sajohnson View Post
For some examples, I used this calculator:
https://www.calculator.net/voltage-drop-calculator.html
1) I entered: copper; 1 AWG; 14Vdc; single set of conductors; 5 feet; 1 amp. Voltage drop = 0.0012 volts.
2) All the same except 50 amps. Voltage drop = 0.062 volts.
3) Same except 100A. Voltage drop = 0.12 volts.
Thereby demonstrating Ohm's Law: V=I*R ... voltage = current times resistance.
The cable has a fixed resistance, so raising the current by a factor of 100 raises the voltage drop by one hundred.
Rearranging it to R = V/I we can see that your length of cable has 0.0012 ohms resistance.
Old 06-14-2019, 05:07 PM   #72
will902
Waldo_Sprinter_Van
will902's Avatar
Hello everyone,
Thought I would share my experience so far...
2007 Freightliner Sprinter 3500
Alternator replaced ~2 year ago (diesel mechanic shop) ~ $700
MB Battery Replaced ~2 months ago (myself) ~ $250
Y-cable replaced ~ 2 weeks ago (MB dealer) ~ $700
Still have battery light light on with no charge (tested at the battery)
Should I take the van back to the dealer or take it to a different Sprinter Specialist altogether?
As a side note...
Iím wondering if my charging system to house batteries is causing a malfunction in the chassis charging system?
Iím running a 300 watt inverter which powers my 70amp fridge and 10amp smart charger?
will902 is offline   Reply With Quote
Old 06-14-2019, 08:20 PM   #73
sajohnson
'09 View/08 3500 chassis
Originally Posted by will902 View Post
Hello everyone,
As a side note...
Just as a starting point, you could check the voltage both with and without the engine running.
If you check it after it's been sitting for a couple hours, it should be about 12.7 volts.
With the engine running it should be about 14.0-14.1 volts.
One crude but easy way to see if an alternator is working is that at night, with the headlights on, when you switch the engine off the lights should dim noticeably. If the intensity remains the same then the battery is not being charged. Obviously it's better to use a meter, but it you don't have one that's one way to tell.
2009 Winnebago View 24J on 2008 Dodge Sprinter 3500 cab-chassis
sajohnson is offline   Reply With Quote
The Following User Says Thank You to sajohnson For This Useful Post:
will902 (06-15-2019)
Old 06-15-2019, 06:44 PM   #74
Well, i'd certainly *start* by disconnecting the Sprinter-side from the inverter.
Which size alternator did you *originally* have? What size engine? Did you have the "intelligent" battery system?
(these questions can be answered from your datacard, available from https://www.datamb.com/ )
If you have the 4-cylinder (was that an option in 2007?), the alternator system ain't simple, and theoretically requires programmed adaptation to the Sprinter's ECM. Was your "diesel shop" capable of doing that?
Your inverter could simply be subjecting the Sprinter-side to wacky high-frequency varying loads that the Sprinter's systems (IC panel watching system voltage telling LINbus-controlled alternator's regulator what to supply) can't keep up (or gets into "fatal oscillations")
I'd also put an oscilloscope on the Sprinter-side of the inverter just to see what's happening.
(i should do that on mine, too...) Is your inverter "pure sine wave" or just MSW?
Old 06-15-2019, 10:19 PM   #75
will902
Waldo_Sprinter_Van
will902's Avatar
Thanks for your offered advice.
To clarify:
It’s a 6 cylinder 3.0L
No intelligent battery system (option available in 2014 I think?)
The VIN indicates that:
14 V/220 A ALTERNATOR
ENGINE OM 642 DE 30 LA 115 KW (156 HP) 3800 RPM
The output at the alternator is intermittent... one day it puts 14.1V and the next day 11.9V,
Wondering if replacing the Y-cable the alternator was working overtime and is wearing out?
Old 06-16-2019, 04:47 AM   #76
lindenengineering
Where was the alternator sourced from?
Old 06-17-2019, 04:28 PM   #77
To clarify:
Itís a 6 cylinder 3.0L
But the NCV3 alternator size/type needs to be the same as the OEM. The T1N could easily swap in a larger alternator. From all that I have gleaned/recall the NCV3 needs to remain as OEM.
Is there any evidence of oil leakage/contamination in the area of the alternator? Oil on the collector rings can result in intermittent brush contact which will affect excitation/output.
will902 (06-17-2019)
Old 06-17-2019, 05:10 PM   #78
will902
Waldo_Sprinter_Van
will902's Avatar
Oh that could be... thanks for the suggestion. Th last time I replaced the engine oil I incorrectly seated the oil filter cap gasket and had oil come up through the cap and spray the under hood. Iíve been monitoring the alternator and it seems to be working correctly for the past 4-5 days.
Would a shop be able to diagnose a bad alternator if the brushes were intermittently losing contact?
Old 06-17-2019, 05:46 PM   #79
smiller
2008 View J (NCV3 3500)
It seems unlikely that both the orignal and replacement unit are both bad. Alternator output on the NCV3 is controlled via CANbus (acutally LIN bus) so the replacement must be correct for your vehicle. As Dennis and Vic are hinting, where did you get the replacement unit and are you sure that it is the correct item? And is it an OEM/Bosch replacement or an off-brand?
smiller is online now   Reply With Quote
Old 06-17-2019, 06:26 PM   #80
11.9 is *really low* ... if your battery was "normal" (say 12.5 v after engine off for a while), i'd hope it would still be noticeably above 12v if the alternator wasn't helping (unless it's been an hour of "not helping"). The alternator/regulator could be doing other "funny" things.
Bad ground strap connections between alternator/engine and frame, or bad negative to the battery should also be checked, as well as the famous Y cable.
charging, electrical problem, low voltage
