NCV3 Write-Ups Help other NCV3 owners by posting your experience working on your Sprinter. |
OK So I sot out to make my additions look nice, I had a number of unused fuse slots and additionally I had a unused fuse older.
I found the parts, (I'll post later all of the part numbers.) Single Terminal Double Terminal Triple Terminal Single terminal is used to take the fused power and run your cable to you device., it could also be used to bring power to the fuse holder The Double and Triple terminals will only be used to bring power from the source to the fuse holder. The fuse block has 9 fuse locations, Power can be brought in to 1, 2 or 3 of the fuse locations. This is helpful if you have a number of fuses which have the same need ie all need to be on when the ignition is running. You can use a Triple terminal and a 10G primary wire to bring power to 3 fuse locations. instead of running power for each. OK once you have power the next to run your line to the device you need to give power to. The fuse holder in position 1-9 allow you to run 2 devices off of the same fuse. so instead of splicing your wires you can just run the two lines and terminate them on a shared fuse. In order to insert the terminals you need to have the red tap pushed up slightly you can see that from the attached pictures. once I find all of the part numbers again I will post them here. Let me know if you have any questions. WPJ
2013 2500 Passenger Wagon aka The BEAST, 144" High-top Loaded GTA - Greater Toronto Area |
The Following 8 Users Say Thank You to WPJ For This Useful Post: | Bobnoxious (08-28-2019), brassmonkey001 (09-28-2018), JFM (11-30-2017), Nimpoc (Yesterday), odix@yahoo.com (06-25-2019), Oldfartt (02-17-2013), RoadToad (04-05-2019), slem (02-17-2013) |
#2 |
How do you remove an existing crimp lug from the fuse holder?
Cheers Ross
2011 315 Mercedes extra long Cargo Van converted to RV 2000 313 Mercedes Sprinter Motorhome (Sold) |
The Following User Says Thank You to Oldfartt For This Useful Post: | BlueIce1 (02-24-2016) |
#3 |
Ross, that can be a chore based on if its a double or triple. But the crimp terminal has two small pins you need a small removal tool to get it in and push them down then you can remove the terminal, mind if it is a triple then you have 6 pins to hold down.
#4 |
Parts List
Fuse Holder was about 14.00, terminals were 1.20 if I remember correctly.
2013 2500 Passenger Wagon aka The BEAST, 144" High-top Loaded GTA - Greater Toronto Area Last edited by WPJ; 02-19-2013 at 01:45 AM. |
The Following User Says Thank You to WPJ For This Useful Post: | Oldfartt (02-19-2013) |
#5 |
Also you need the red tabs raised inorder to push in your wire terminals
#6 |
Yahoo finally someone knew what I have been looking for for 2 yrs. Thank you kindly
Can you tell me what parts on your list are the single and double and triple fuse connectors. I have plenty of unused pspaces on my under dash fuse block. Just want to add one to 4 fuses and only really need the singles but will buy the double and triples for the future. Your help would be greatly appreciated |
#7 |
Are the parts the same for under dash and seat?
One has a 905 designation the other (which you ordered) is 915. Also what is the 900 designation for? |
#8 | |
![]() Quote:
So T1N were 903. NCV3 were 906. Some parts are "universal" (nuts, bolts, screws) so have 000 or 001 --dick
2005 T1N 118" Freightliner 2500 Passenger Wagon (2.7L, 15" tires, standard (short) roof) Get YOUR Sprinter's full configuration datacard by entering your VIN to https://www.datamb.com/ http://diysprinter.co.uk/reference <-- lots of service documentation, Thanks to Jens Moller and Arnie_Oli ((as always: this post may go through a couple of post-posting edits... so maybe give it ten minutes before commenting)) |
#9 | |
UK 2008 NCV3 518 CDI
![]() Quote:
I've got a lot of superfluous wiring I'd like to remove and I'd rather remove it completely than just chop it. |
#10 |
I rely on either extremely tiny jeweler's screwdrivers, or the wood-handled long-needle "pithing" tool (also called "dissecting needle")
(i tried looking it up to provide an Amazon/eBay reference, but all of the early pages' hits were for certain playing cards in "Magic: The Gathering") Ah: found them: https://www.carolina.com/dissecting-...jl_ctx=on_site Needles.jpg --dick
2005 T1N 118" Freightliner 2500 Passenger Wagon (2.7L, 15" tires, standard (short) roof) Get YOUR Sprinter's full configuration datacard by entering your VIN to https://www.datamb.com/ http://diysprinter.co.uk/reference <-- lots of service documentation, Thanks to Jens Moller and Arnie_Oli ((as always: this post may go through a couple of post-posting edits... so maybe give it ten minutes before commenting)) Last edited by autostaretx; 07-11-2019 at 06:56 PM. |
Tags |
fuse, fuses, nvc# |
Thread Tools | |
Display Modes | |
