Old 06-16-2010, 06:05 PM   #1
cahaak
cahaak's Avatar
Default Common Maintenance Work Procedure Thread Link List
Hi,
In the short time I've had my sprinter I managed to go through every post in the T1N section and what I have done is to creat a Word document that has hyperlinks to all of the various threads that I have found useful. It includes the standard maintainence threads as well as a bunch of other useful threads. I find it very useful and fast for looking things up.
So, here it is -
Chris
--- List from PDF ---
Glow plug thread with module modification
Hitch information
Oil change information
Driver foot heater tube modification
Crankshaft sensor replacement
https://sprinter-source.com/forum/sh...ad.php?t=40927 Video: https://sprinter-source.com/forum/sh...ad.php?t=76487
Transmission drain and service
http://sprinter-source.com/forum/showthread.php?t=7605
http://sprinter-source.com/forum/showthread.php?t=2557
http://sprinter-source.com/forum/showthread.php?t=2476
http://sprinter-source.com/forum/showthread.php?t=6704
Brakes:
Replacing the FOB battery
http://sprinter-source.com/forum/showthread.php?t=8109
Glow plug testing:
https://sprinter-source.com/forum/sh...2&postcount=17 - part of a long and very informative thread on glow plug replacement
Air Filter change
https://sprinter-source.com/forum/sh...0366#post60366
cabin filter change
http://sprinter-source.com/forum/showthread.php?t=2374
Air vent pin fix
http://sprinter-source.com/forum/showthread.php?t=4242
Rear AC idle cut out
http://sprinter-source.com/forum/showthread.php?t=6607
Broken Hood release and replacement
https://sprinter-source.com/forum/sh...ad.php?t=17545
Panel removal and retainer clips
http://sprinter-source.com/forum/showthread.php?t=1648
https://sprinter-source.com/forum/sh...ighlight=panel
Starter motor replacement
https://sprinter-source.com/forum/sh...ad.php?t=31076
Alternator Replacement
https://sprinter-source.com/forum/sh...ad.php?t=26087
https://sprinter-source.com/forum/sh...ad.php?t=45516
Serpentine belt replacement
https://sprinter-source.com/forum/showthread.php?t=5478
Serpentine belt tensioner
https://sprinter-source.com/forum/sh...ad.php?t=18310
Recirculating pump replacement
https://sprinter-source.com/forum/sh...ad.php?t=13404
...If you want to repair the recirculating pump https://sprinter-source.com/forum/sh...ad.php?t=13546
Radiator cleaning
https://sprinter-source.com/forum/sh...ad.php?t=12434
Aux battery info
http://sprinter-source.com/forum/sho...hlight=battery
OM647 O2 sensor cleaning (OM612 doesn't have one)
http://sprinter-source.com/forum/showthread.php?t=5038
Antenna replacement
http://sprinter-source.com/forum/showthread.php?t=5896
Trailer wiring harness
http://sprinter-source.com/forum/showthread.php?t=7489
http://sprinter-source.com/forum/showthread.php?t=6880
http://sprinter-source.com/forum/showthread.php?t=4444
Fuel filter
http://sprinter-source.com/forum/showthread.php?t=7537
https://sprinter-source.com/forum/showthread.php?t=2318
Fuel filter - OM612 2001-2003 specific
OM612 fuel rail pressure control valve rebuild
https://sprinter-source.com/forum/sh...ad.php?t=29457
OM612 clear line replacement
https://sprinter-source.com/forum/sh...ad.php?t=58974
OM612 engine harness replacement
https://sprinter-source.com/forum/sh...hlight=harness
Headliner clips
http://sprinter-source.com/forum/sho...88&postcount=1
Winter Grill cover
http://sprinter-source.com/forum/showthread.php?t=8852
http://sprinter-source.com/forum/showthread.php?t=663
Dome light replacement bulbs
http://sprinter-source.com/forum/showthread.php?t=8756
Heater control explanation
http://www.sprinter-source.com/forum...ht=temperature
various sprinter PDF files in this thread
http://sprinter-source.com/forum/showthread.php?t=6344
Post about changing tire sizes to 215/85/R16
http://sprinter-source.com/forum/showthread.php?t=3064
Stepwell plug screw locations
http://sprinter-source.com/forum/showthread.php?t=6899
Seat covers and floor mats
http://sprinter-source.com/forum/showthread.php?t=10553
Rear seat belt cover and seat belt buckle replacement
https://sprinter-source.com/forum/showthread.php?t=6295
Front Blower/fan motor resistor replacement
http://sprinter-source.com/forum/showthread.php?t=4221
https://sprinter-source.com/forum/showthread.php?t=8262
Front heater/AC fan removal and brush replacement
https://sprinter-source.com/forum/sh...?t=9252&page=3
Transmission pan plug removal and number.
http://sprinter-source.com/forum/showthread.php?t=6271
Radiator swing out: If your T1N has AC and you need access
  • water pump
  • OM612 clear line replacement
  • Harmonic Balancer
  • Serpentine belt tensioner and idler pulleys
https://sprinter-source.com/forum/sh...ad.php?t=58962
Radiator Push out technique (w or w/o AC)(for any of the above except harmonic balancer)
https://sprinter-source.com/forum/sh...04&postcount=1
Harmonic balancer issues
http://sprinter-source.com/forum/showthread.php?t=5226
Drone noise at around 70 mph
http://sprinter-source.com/forum/showthread.php?t=1420
Subwoofer
http://sprinter-source.com/forum/sho...ight=subwoofer
Cargo lamps from the aux battery
http://sprinter-source.com/forum/showthread.php?t=2252
Front shocks/struts
http://sprinter-source.com/forum/showthread.php?t=2839
https://sprinter-source.com/forum/sh...ad.php?t=28362
Rear shocks
https://sprinter-source.com/forum/showthread.php?t=4865
Rear AC cover and painting it
http://sprinter-source.com/forum/showthread.php?t=1862
Armrest part numbers
http://sprinter-source.com/forum/showthread.php?t=1410
Swivel shades and overhead storage
http://sprinter-source.com/forum/showthread.php?t=1495
Sliding door latch (not the handle)
https://sprinter-source.com/forum/sh...ad.php?t=14026
https://sprinter-source.com/forum/showthread.php?t=2250
Door adjustment - slider and front doors
https://sprinter-source.com/forum/showthread.php?t=7110
Sliding door handle
https://sprinter-source.com/forum/sh...ad.php?t=14009
Rear Axle U-Bolt retorquing
https://sprinter-source.com/forum/sh...ad.php?t=55366
Auxiliary Heater
...D2 Airtronic installed in rear
...Espar thread
....http://sprinter-source.com/forum/sho...ighlight=espar
....http://sprinter-source.com/forum/showthread.php?t=2178
...Wiring Espar heater to run from a switch and adding a timer
....http://sprinter-source.com/forum/showthread.php?t=668
....http://sprinter-source.com/forum/showthread.php?t=601
Windshield wiper arm replacement
https://sprinter-source.com/forum/showthread.php?t=9487
Last edited by hkpierce; 08-05-2019 at 05:11 PM. Reason: Changed Doc file to PDF / Displayed Links to Post
The Following 52 Users Say Thank You to cahaak For This Useful Post:
02bigcargovan (04-21-2013), ajm3s (08-11-2011), Aqua Puttana (09-10-2010), bconover (03-25-2013), BigBlueBuilder (01-16-2017), BISON (10-10-2016), blessedmomof8 (09-10-2010), bossogasa (04-07-2014), brassarl (04-10-2013), Brit (11-27-2018), CJPJ (12-04-2015), compact (01-05-2019), davisdave (03-12-2011), dbeyer (06-16-2010), degzie (12-16-2011), derekhski (06-06-2016), DesertAdventures (01-16-2018), Dieseldoctor (09-23-2013), Foghorn,Ct. (12-09-2013), glasseye (09-10-2010), Gulf SV (11-22-2010), GunntuckySmooth (08-28-2016), hayduke (06-01-2011), ibgroovin2 (06-02-2012), ions82 (06-24-2019), jdcaples (06-17-2010), JustThePilot (07-18-2012), kkanuck (09-17-2012), LeeOts (06-01-2012), Luc (11-29-2016), marbled_rye (09-10-2018), mawsea (12-28-2013), maxextz (09-16-2010), mean_in_green (09-10-2010), mendonsy (06-16-2010), metaldirtart (08-04-2019), MikeHowe (10-02-2013), MXHauler (12-13-2016), napo (04-06-2012), PBM (06-17-2010), Rbroome (05-21-2015), ReGULT51 (04-25-2019), seabiscuit (05-19-2013), seans (06-17-2010), Senta (11-23-2018), Simon (05-11-2016), Sjoberg (10-26-2012), slappy (10-16-2018), SneakyAnarchistVanCamper (02-11-2018), Tulisan9k (01-30-2015), w1nzr (10-06-2011), Wildmonkey (12-02-2012)
Old 08-02-2013, 05:07 PM   #2
Default Re: Thread hyperlinked document
No "black death"?
--dick (looking it up for someone else...)
Old 11-04-2013, 10:51 AM   #3
NetDoc
NetDoc's Avatar
Default Re: Common Maintenance Work Procedure Thread Link List
Yeah, I need info on black death and resurfacing the injector seals.
Pete 'NetDoc' Murray
2005 Freightliner 2500 140"
www.ScubaBoard.com
Solo otro día en el paraíso!
Mechanics always start what they finish!
NetDoc is offline   Reply With Quote
Old 11-27-2013, 04:34 PM   #4
hulagun
Haulin' A** since 1974
hulagun's Avatar
Default
Replacing serpentine belt, pulleys, and tensioner:
http://sprinter-source.com/forum/sho...belt+tensioner
Serpentine belt replacement only, this is a better thread:
http://sprinter-source.com/forum/showthread.php?t=5478
And here is an excellent thread about problems caused by T1N rear wheel ABS sensors and rings.
http://sprinter-source.com/forum/showthread.php?t=18072
2005 T1N 2500 HC OM647 2.7L 5-cyl Turbo Cargo Platinum Silver 118" Wheelbase Moto Hauler
hulagun is offline   Reply With Quote
Old 07-17-2014, 11:20 PM   #5
gggGary
gggGary
I'm searching right now but this thread needs a link to an alternator replacement thread........
This thread looks like it describes the job.
http://sprinter-source.com/forum/showthread.php?t=26087
I gotta do it so may add some pics to that thread.
gggGary is offline   Reply With Quote
Old 03-23-2016, 06:33 PM   #6
shotgunaids
shotgunaids's Avatar
Awesome resources. Is there a thread anywhere with a write up on pulling the engine? I haven't had any luck searching.
Thanks,
Casey
[EDIT HKP] Not really common maintenance. See http://www.mercedes.gen.in/mercedes-...gine-swap-t1n/
shotgunaids is offline   Reply With Quote
