Other tidbits. Page 46 has a procedure to test the clutch packs with the trans installed. The valve body is dropped, and compressed air is applied to the correct port. Leaks in the seals will shop us as loud hissing.
This manual indicates that the TCC is only active in 3-5th gears, but other manuals indicate 2nd gear is also has TCC activity.
