Go Back   Sprinter-Forum > NCV3 Sprinters > NCV3 Database
NCV3 Database Reference Information, Part Numbers, Recalls, TSBs, and etc.
Old 04-23-2017, 10:50 PM   #1
Bobnoxious
Default CDI Direct Injection
Here's another.
The Following 4 Users Say Thank You to Bobnoxious For This Useful Post:
4wheeldog (06-20-2019), CJPJ (03-31-2019), Dougflas (04-26-2017), TooMuchHair (04-01-2019)
Old 04-25-2017, 06:08 PM   #2
cevans
cevans's Avatar
Default Re: CDI Direct Injection
This part is so cool, gone are the days of balancing injectors.
Zero quantity calibration
In order to counteract the change in the injection
quantity, the actuation duration of the fuel injectors
can be corrected via zero quantity calibration. On
engine 651 with the Delphi injection system, correction
is performed with the help of two knock censors.
At defined intervals during engine operation or in
deceleration mode, a preinjection quantity is calibrated
for each cylinder individually. Based on the
shortest possible actuation duration, the actuation
duration is increased until the CDI control unit
receives a signal from both knock sensors. The difference
between the determined and the nominal actuation
duration is used for injection quantity correction.
Corey@IDParts (dot) com - Fighting against leaking oil cooler seals!
Manager of Mercedes & Sprinter Parts @ IDParts.com - 888-444-7951
Sprinter Maintenance Service Kits / Sprinter Brake Sets / Sprinter NCV3 Oil Cooler Seal Kits
cevans is offline   Reply With Quote
Old 03-31-2019, 09:56 PM   #3
CJPJ
2008 3500 170"ext. 3.0L
CJPJ's Avatar
Location: Contra Costa California, Douglas County, Oregon
Piezo Fuel Injectors Explained
The Tower of Piezo: The smartest injectors you’ll ever meet.
If you’ve ever seen the sparks created by someone munching Wint-O-Green Life Savers in a darkened room, you’ll have witnessed this phenomenon: Certain crystalline materials, such as sugar, produce minute amounts of electricity when you squeeze them. There’s even a word for it: “piezoelectric,” which describes electricity resulting from pressure. But the process is also reversible, in that these same materials expand slightly when electricity is applied to them. There are numerous places in a car where piezoelectric expansion can come in handy.
Take, for example, the precise metering necessary for modern-day fuel delivery. Bosch, Continental, and Delphi, among others, have harnessed this peculiar property of expanding piezo material—rather than the usual electromagnet—to open the fuel-injector nozzle and precisely spray fuel into both gasoline and diesel engines. Making these devices work, however, isn’t easy.
One reason is that the expansion of the piezo crystals is minuscule. A slice of piezo material two-hundredths of an inch thick expands only about 0.00002 inch when it gets hit with roughly 140 volts of electricity. That two-hundred-thousandths of an inch is not nearly enough to move an injector’s pintle, which is the part that seals the nozzle and must open to inject fuel.
The Continental injector has hundreds of little piezo slices stacked on top of each other so that the combined expansion increases the total motion. The stack produces 0.004 inch of movement—enough to move the pintle far enough to inject fuel. But because this motion is in the wrong direction—down, not up—the addition of two tiny levers allows the expansion of  the piezo stack to cause the pintle to be lifted and the fuel spray to begin. When the injection is complete, the voltage cuts off, the piezo stack shrinks, and a spring closes the pintle.
Piezo injectors have a few key benefits that justify all of this bother. For one thing, they open and close much faster than conventional injectors. That makes for more precise control of the injection interval, which determines how much fuel is sprayed into the engine. Piezo units also provide feedback by producing minute fluctuations in the electricity used to activate them. For example, if the engine-control computer calls for an injector-opening time of 0.5 second, and the injector response shows that it opened for only 0.496 second, the computer can add a tiny bit of time to the next injection cycle to compensate. Such precise fuel metering makes for improved combustion, which leads to better fuel economy and reduced emissions.
Not only are piezo injectors more accurate than conventional solid injectors, they also can perform some tricks that are completely beyond the capabilities of their predecessors. For one thing, by applying a little less electricity, the piezo crystals expand less so the injectors can open partway. A smaller opening means a longer injection time, which is beneficial when trying to accurately inject a tiny amount of fuel, such as when a car is nearly coasting. Because they act so quickly, piezo injectors also can inject several times (as many as seven in some diesels) during a single combustion cycle. This flexibility can reduce emissions in all engines as well as limit soot in diesels.
These benefits have secured a home for piezo injectors in many of the latest diesel and direct-injection gasoline engines. And Continental, for one, says that its piezo units don’t cost more than the less capable conventional equivalents. Piezo injectors are one of the key devices that will keep internal combustions competitive against these pesky electric upstarts for years to come.
https://www.caranddriver.com/feature...ors-explained/
CJPJ is offline   Reply With Quote
