Old 08-29-2019, 07:56 PM   #1
john thomas
Default boost pressure
is there any way to check boost pressure an what should it be 08 sprinter
john thomas is offline   Reply With Quote
Old 08-29-2019, 10:15 PM   #2
manwithgun
manwithgun's Avatar
Default Re: boost pressure
https://sprinter-source.com/forum/sh...t=77100&page=4
2007 Dodge Sprinter 2500 144WB V6 OM642 NCV3 CRD
manwithgun is offline   Reply With Quote
Old 08-29-2019, 11:07 PM   #3
Aussie 2002 4x4
Aussie 2002 4x4's Avatar
if you can buy or borrow a Scangauge II, you can keep track of heaps of things while on the move
Aussie 2002 4x4 is offline   Reply With Quote
Old 08-29-2019, 11:58 PM   #4
lindenengineering
Oh come on Guys --You scan gauge gazing geezers you!
Turbo "nuevo nuevo" system in optimum condition 2150 millibars to 2200 millibars .
That's about 30 psi "darlings"!
BUT
Don't go over 23,50 millibars cos it will trip out with an over boost code!
Old 09-12-2019, 09:18 PM   #5
john thomas
I was told the turbo activator needed replaced so I did did not fix still have low boost is there a fuse for the turbo activator should the activator move when the switch is turned on
Old 09-14-2019, 01:18 PM   #6
john thomas
is there a fuse that operates the turbo actucator
Old 09-14-2019, 01:24 PM   #7
There's no dedicated fuse in the panel. The conditioned/variable special signal comes from the ECM aka ECU.
The turbo vane actuator should move at least slightly when the engine is first started. It can be watched while someone else starts the engine.
Low boost often traces to charge air system leaks. It can also be a sensor problem. Unfortunately boost leaks or sensor issues don't necessarily trigger a DTC in the ECM.
