SubForums: Events Scanners
Old 09-12-2019, 02:57 PM   #3981
tarheeltwice
Default Re: What did you do to your Sprinter today.
New running boards.. beware of falsely advertised item. This is NOT a no drill item and it is NOT custom for 2019. But the manufacturer has been contacted, they are aware and reportedly making new brackets for the new body style. Thanks too my brother for some creative engineering to make it work. Steelcraft STX600 Running Boards from realtruck.com
Sent from my Pixel 2 XL using Tapatalk
tarheeltwice is offline   Reply With Quote
The Following User Says Thank You to tarheeltwice For This Useful Post:
Aqua Puttana (09-12-2019)
Old 09-17-2019, 12:39 PM   #3982
USMC Mustang
Upgraded the OEM battery and power system to 400Ah of Lithium and a 3kW inverter. See details in this post: https://sprinter-source.com/forum/sh...ad.php?t=79309
USMC Mustang is offline   Reply With Quote
Old 09-18-2019, 09:31 PM   #3983
skier1950
Replaced the spare tire carrier that was mounted to the trailer hitch (continental kit style) with a rear door mounted one. I did this to increase the departure angle of the van. Before I was scraping the ^%$# out of the old carrier bottom bracket everytime I went anywhere where there was a steep angle to enter/exit. This was espcially troublesome due to my very steep driveway. In addition, I no longer feel like I'm going to get a hernia everytime I lower and raise the spare tire to access the rear compartment and I don't need to worry about putting the cotter pin in the bracket to prevent the tire from falling down. The holes that hold the pin in were never aligned and it took a mallet to get it to place. Now all I need to do is open and close the door. I would send a picture but I don't know how to do it (I'm old and in the way). The best thing about this mount is that no holes were drilled. Instillation took less than an hour. It would probably take someone with more mechanical skills than i possess 1/2 an hour. Check it out at owlvans.com
skier1950 is online now   Reply With Quote
The Following 2 Users Say Thank You to skier1950 For This Useful Post:
BrennWagon (09-21-2019), TOASTER.13 (09-22-2019)
Old 09-19-2019, 10:02 PM   #3984
BrennWagon
Pete
Today I did a rough install of some cargo drawers that I made. The box is 4x4x19 tall. I made the thumb buttons for the latches, only ones connected right now, I lost the ferrule for the other side so thatll get finished up tomorrow. Im planning on building out to the wall and hinging the deck floor panels
File Type: jpg 10B31BDD-82E3-4AD5-93A0-D7029AECE3BE.jpg (96.7 KB, 155 views)
File Type: jpg E2FB8269-8DFA-45C0-8E5C-6C728F62B0DD.jpg (109.5 KB, 149 views)
File Type: jpg 8FDCC56E-CF67-4E5F-812C-A45B31D8EF96.jpg (109.7 KB, 146 views)
BrennWagon is offline   Reply With Quote
The Following 2 Users Say Thank You to BrennWagon For This Useful Post:
Mickyfin (09-21-2019), ranchworld (09-21-2019)
Old 09-21-2019, 07:18 AM   #3985
Mickyfin
Mickyfin's Avatar
I just finished fitting my fresh powder coated sliding door rail, all by myself, quite chuffed, wouldn't of been possible without these forums, got some great help here.
IMG_20190921_101137 by S STEEL, on Flickr
IMG_20190921_101144 by S STEEL, on Flickr
My van is a 170" WB High Top 2012 Volkswagen Crafter 2.0TDi, which was built in the very same German factory as the Mercedes Sprinter of the same year.
The Following 2 Users Say Thank You to Mickyfin For This Useful Post:
BrennWagon (09-21-2019), hippy (09-21-2019)
Old 09-21-2019, 09:24 PM   #3986
hippy
hardware modifier
Today I fitted tounge and groove to the roof in my conversion, it's 9 months since my "friend" said he would be back in 2 weeks to help me build this camper conversion.
Been a while since I posted. I've just started getting on with it.
hippy is offline   Reply With Quote
The Following User Says Thank You to hippy For This Useful Post:
Old 09-22-2019, 04:42 PM   #3987
sassmatt72
2006 low top 10 pass
IMG_2677.jpgSo I finally stated on my big build...
It's amazing what a mig can do...
I'm back!
sassmatt72 is offline   Reply With Quote
The Following 2 Users Say Thank You to sassmatt72 For This Useful Post:
BrennWagon (09-22-2019), Mickyfin (09-23-2019)
Old 09-22-2019, 09:17 PM   #3988
BrennWagon
Pete
Today I squared and bolted down (3/8” carriage bolts) my cargo drawer box and attached hinged side pieces over the wheel wells. Before bolting it down, I removed the third bench brackets with the intent of making the second row take a three seater bench and the hope of finding another three seater for cheap locally. The wide third row bench was missing when I bought my van.
Old 09-23-2019, 12:36 AM   #3989
grantwilson
VanGoOutdoors
grantwilson's Avatar
Untitled by Grant Wilson, on Flickr
new wheels!
custom built 16x8 +25 fuel revolvers
2019 144" Pebble Grey 4x4 currently being built. Contact me!
FreedomVanGo - Jacksonville Florida
The ONLY Certified Adventure Wagon dealer and installer in the SouthEast
Authorized Dealer for Dometic, Ripplewear, Tern Overland, Van Compass and more!
www.vangooutdoors.com
www.youtube.com/GrantWilsonFL
www.Instagram.com/FreedomVanGo
grantwilson is offline   Reply With Quote
The Following 2 Users Say Thank You to grantwilson For This Useful Post:
BrennWagon (09-23-2019), Mickyfin (09-23-2019)
Old 09-23-2019, 03:52 AM   #3990
HighPockets
First time I have looked up close at the new van. Although it looks the same from a distance it has suttle refinements in nearly every body panel that gives it a more refined look. I like it. So glad they didn't stylize it.
Gene
'07 CRD 144" high top, Koni Reds, Hellwig stabilizer bar, 276K miles, new paint, Pioneer SS with two amps, 11 speakers, at work on RV build-out.
The Following User Says Thank You to HighPockets For This Useful Post:
