MrChrisBoice
2018- 2500 4x4 (170/high roof)
7,700 miles
Contact Chris: 505-280-6504
https://saltlakecity.craigslist.org/cto/6815088516.html
Build out:
•CR Lawrence sliding doors & driver side
windows with opening leafs
•CR Lawrence panel windows
•Roof rack
•Flush mounted 295 watt solar panel
•200 amp hour lithium battery
•2000 watt Samlex inverter with remote start
and battery monitoring
•Midnight Solar solar controller
•4 remote operated lighting zones in living
space so you can turn the lights on or off
from anywhere
•1 hard manual switches light in backsplash
•Webasto Air Top 2000 STC Diesel heater
w/high altitude adjustment
•Webasto digital rheostat/7day timer
•Vitrifrigo stainless steel 12v fridge/freezer
•Cherry countertops
•Custom upper and lower cabinets made of
Baltic Birch (not mdf
or particleboard) with Cherry trim
•Blum hinges
•soft close glides
•Southco Marine latches
•pneumatic struts on upper cabinets
•Under mount stainless steel sink
•Bench with custom upholstered cushions
•78”x67” bed with poster memory foam mattress
•110 outlets throughout living space
•12v USB ports in kitchen and sleeping area
• 2 Maxx Air 10 speed remote operated roof
vent with rain shields
•Custom built sliding cargo tray (500lbs
capacity)
•Quick disconnect outdoor shower (optional
propane water heater)
•Passenger swivel seat
•1000lbs leaf spring added to rear
•Method Racing Wheels
•BFG AllTerrain KO2 tires 275/70/17
7,700 miles
Build out:
•Roof rack
from anywhere
•Cherry countertops
•Blum hinges
•soft close glides
capacity)
