View Poll Results: Best Insulation for Walls/Ceiling
Polyiso, PIR, ISO 8 7.08%
XPS (Blue/pink 'Styrofoam') 6 5.31%
EPS (White 'Styrofoam') 0 0%
3M Thinsulate SM600L (synthetic fiber) 73 64.60%
Fiberglass rolls or batts 0 0%
Polyurethane foam (white/yellow spray) 7 6.19%
Icynene foam (eco-friendly spray, closed cell) 2 1.77%
Sheep's wool 17 15.04%
Voters: 113. You may not vote on this poll | Withdraw Vote
Old 03-12-2019, 06:38 PM   #11
sprinterPaul
Default Re: Best Insulation for Walls/Ceiling
Originally Posted by MotoXPress View Post
Polyiso on the floor or ceiling also reduces the standing height - a big concern for taller people.
On the ceiling you have 1.5" of rib height to fill. So you don't really lose anything. The floor is different. But I fail to see how adding Thinsulate under the floor and them compressing it helps. I'm sure the part thats in the corrugations helps. I didn't insulate my floor and it's been fine.
Old 03-14-2019, 11:04 PM   #12
BHamB
I went with .5" EPS foil board backed with Havelock wool on the ceiling. Havelock wool on the upper and mid walls, easy install, no adheisives required. I put 3M thinsulate on the lower walls; however, I am not a huge fan of the required 3m adhesive. Moisture and condensation seems to naturally work its way down to the weeping holes. I'll check it in 12 months and update accordingly.
BHamB is offline   Reply With Quote
Old 03-15-2019, 03:05 PM   #13
hein
Van Guru
There is a low VOC 3M 90 high temp spray adhesive available and we are working with 3M to determine which PSA (peel and stick) tape will work best especially in cooler temps. Many people tend to use too much spray adhesive. The trick is to place the Thinsulate(TM) SM600L in the wall cavities and then pull back the edges and spray adhesive behind and near the top of the pieces in such a way that it gets on both the Thinsulate(TM) fibers and also the metal skin. Then gently press it back in place.
Sheep's wool does appear to be getting some traction lately so we'll have to see how it holds up down the (bumpy) road so please keep us posted with an update. Denim was popular but it got soggy when condensation got to it over time. Many organic insulation products are sprayed with Borates to achieve the FVMSS-302 flammability rating required in vehicles. When moisture is present this can leach out and form boric acid which is corrosive. Some folks and pets develop a reaction to it. Thinsulate(TM) contains no such additives.
All the best,
Hein
2010 MB 3500 RV conversion.
Old 03-15-2019, 03:11 PM   #14
BikeJozz
BikeJozz's Avatar
https://www.greenbuildingadvisor.com...lyisocyanurate
BikeJozz is online now   Reply With Quote
Old 03-15-2019, 04:15 PM   #15
hein
Van Guru
Did you know that if you burn Isocyanate that it releases toxic gas?
The stuff is nasty and the dust is not something you want to inhale.
https://www.osha.gov/SLTC/isocyanates/
https://firesciencereviews.springero...038-016-0013-2
Old 03-15-2019, 04:35 PM   #16
radair603
After using Thinsulate I would not consider anything else. It is SO easy to cut with scissors or a rotomat, can be fished through ribs and tight spaces and is not toxic or itchy. $600 for a roll seems very expensive at first but the time saving makes up for it. It's a drop in the bucket when doing a full build with diesel heater, windows, solar-electric, awning, refrigerator, water system, etc.
Edited to say I also added 1/2" rigid foam and a layer of Reflectix to my ceiling because I have a black van that can heat up like an oven. Great in cold temps but not so great in the hot desert.
radair603 is offline   Reply With Quote
The Following 2 Users Say Thank You to radair603 For This Useful Post:
gltrimble (03-15-2019), Lostgriz (07-12-2019)
Old 03-15-2019, 07:33 PM   #17
Shawn182
Valid point...but in reality of you are in the van still at the point that the fire reaches the insulation, the toxic gasses are likely the least of your problems.
Shawn182 is online now   Reply With Quote
The Following User Says Thank You to Shawn182 For This Useful Post:
al415 (06-30-2019)
Old 03-15-2019, 09:21 PM   #18
hein
Van Guru
I would hope and pray that you and your precious cargo are safely out of the van and well clear of any smoke. I am also considering the safety of the firefighters, homes nearby, and folks driving by. Sorry to be sort of blunt in this thread. My training and experience as engineer has allowed me to see past what most folks consider as part of a failure analysis.
All the best,
Hein
Terrapin (03-16-2019)
Old 03-16-2019, 12:57 AM   #19
NNGVan
2008 3500 Custom Uplift
A system is better than any single product.
Given the ribs have 2+ inches on he walls and ceiling is 1.5 here is what I did.
1) Polyiso 1” directly on the skin everywhere I could. Walls and ceiling, etc.
2) Small closed foam spray kit 200 lbf kit everywhere the poly didn’t fit.
3) Attic Foil not reflectix (much cheaper) on the front/back of my ThermalPly which I nailed to the ribs using 1x2 furrings directly on the ribs. This gave me a nice air gap for radiant heat.
4) Large Gap Filler for inside the ribs.
Cost was cheaper than a roll of Thinsulate
System R value 9+ (some argue about the advantage of radiant heat but there’s a 15-20 difference in Mexico in direct sunlight)
It took 4 times as long but I wasn’t in a hurry do it right it’s the hardest thing to do over.
No idea on the toxic levels everything is sealed and on the other side of the wall.
You lose about .5-.75 do to the furrings but man it handles Canada to Mexico better than anything I’ve seen.
2008 Cargo/Work Sprinter 3500
Bought:
Bad everything, every light possible.
Broken: Needed brakes, tires, calibers, lower control arms, crushed pumpkin, abs, CEL, DPF, swirl valves, EGR bad flow?
Current:
Fixed: New brakes, tires, calibers, lower control arms and bearings, pumpkin, CEL off (Missing DPF pervious owner Green tune delete), New swirl valves, EGR codes just disappeared after fresh wipe.
WIP: ABS / ESP / Brake LIGHT
NNGVan is offline   Reply With Quote
The Following User Says Thank You to NNGVan For This Useful Post:
Niceguy12 (08-02-2019)
Old 03-16-2019, 01:43 PM   #20
Robert-NE
NNGVan, how did you come up with a system R value of 9+?
Everyone else, I am seeing a big push for Thinsulate, and I can appreciate some of the benefits over other forms of insulation. However, while still in the planning phase of my build, I am trying to understand the lack of votes for closed-cell spray foam based on the five criteria points:
1) R Value - closed-cell spray foam has the highest R-rating per inch of any other common materials
2) Installation effort - It is messy and requires proper technique required to prevent van wall distortion, but installs quickly compared to cut-and-fit of others.
3) Toxic/safe - I assume this is the number one benefit of Thinsulate over spray foam?
4) Cost - DYI spray foam kits cost about the same as Thinsulate
5) Thickness - Again, spray foam has the highest R-value per inch of any common insulation product
So, is the potential safety factor of spray foam the ONLY downside?
Robert-NE is offline   Reply With Quote
