View Poll Results: Best Insulation for Walls/Ceiling
Polyiso, PIR, ISO 14 9.27%
XPS (Blue/pink 'Styrofoam') 8 5.30%
EPS (White 'Styrofoam') 1 0.66%
3M Thinsulate SM600L (synthetic fiber) 89 58.94%
Fiberglass rolls or batts 0 0%
Polyurethane foam (white/yellow spray) 10 6.62%
Icynene foam (eco-friendly spray, closed cell) 3 1.99%
Sheep's wool 26 17.22%
Voters: 151. You may not vote on this poll | Withdraw Vote
Old 09-22-2019, 04:00 PM   #161
Default Re: Best Insulation for Walls/Ceiling
Not really. I would leave them in for insulation value if its convenient. Otherwise ditch them.
Old 10-04-2019, 12:16 PM   #162
taildragger
I am going to use "pour foam" urethane on my floor and walls.
PROS: R6 per inch, every nook and cranny filled, sound reducing, so strong, it will be my floor, easy to install
CONS: Expensive, $520 for 2 inches of floor insulation, messy
taildragger is offline   Reply With Quote
Old 10-04-2019, 02:44 PM   #163
nickbokhoven
Originally Posted by Garandman View Post
Quasi related question. Any reason not to remove the foam blocks in the ceiling behind the B pillar?
Note the foam blocks are quite important per the BEG
nickbokhoven is offline   Reply With Quote
The Following User Says Thank You to nickbokhoven For This Useful Post:
Garandman (10-04-2019)
Old 10-04-2019, 03:39 PM   #164
gltrimble
Too late for me, I threw the foam blocks away. Did not realize I left them out until after the headliner was reinstalled. Not sure they would have worked anyway with all the modifications.
Old 10-04-2019, 08:44 PM   #165
Garandman
Garandman's Avatar
Thanks! Looked it up.
http://www.ntea.com/NTEA/Member_bene.../FMVSS201.aspx
This Standard applies to MPVs, trucks and buses with a GVWR or 10,000 lbs. (4,536 kg) or less. It establishes requirements for the use of energy-absorbing materials on the interior components such as instrument panels, seat backs, interior doors, armrests and sun visors.
Beginning Sept. 1, 2007, trucks, buses and MPVs produced in two or more stages with a GVWR of 10,000 lbs. (4,536 kg) or less must provide head protection when an occupant’s head strikes upper interior components, including pillars, side rails, headers and the roof.
2006 Sprinter 118” ~ 16” Rial Transporter rims ~ 235/65x16
Old 11-08-2019, 03:00 AM   #166
Robert Foster
This is the first thread that I've seen Thinsulate mentioned for use in the floor. Is there a thread around that details the assembly of the layers for a floor using Thinsulate ? Are there furring strips involved to prevent the Thinsulate from compressing or is there a more dense variety of Thinsulate as there is with Rockwool ? What am I not understanding ?
Why hasn't Rockwool (Roxul) become more prevalent in insulating vans ?
2005 Sprinter Westfalia ... currently undergoing a complete refitting
Old 11-22-2019, 02:04 PM   #167
Graphite Dave
Dave Orton
If your head reaches the location of the foam blocks then you have some other major issues to deal with.
Old 11-23-2019, 05:31 AM   #168
hein
Van Guru
Minicell is our most popular floor insulation. We are also using Thinsulate AU4002-5 double scrim under plywood floors. Strategic use of furring strips or blocks may be required although I have had customers with Sprinters just roll out the Thinsulate and then lay their floor over it. It does compress a bit but will not loose all of it's loft.
All the best,
Hein
DIYvan
541 490 5098
(Below) Thinsulate AU4002-5 under the floor in our Transit. White pieces are expanded PVC furring strips attached to metal floor with VHB tape
More info and photos: https://www.fordtransitusaforum.com/....24553/page-16
2010 MB 3500 RV conversion.
onebigsnook (12-10-2019), Robert Foster (11-24-2019)
Old 11-23-2019, 03:25 PM   #169
99sport
Hein,
In a post somewhere you mentioned you would have 3M sound deadener / absorber available in the fall. I'm at the point where I need to apply sound absorbing mat if I am going to use it. Is the 3M product available yet? Do you have a spec sheet for it?
99sport is offline   Reply With Quote
Old 11-23-2019, 04:43 PM   #170
hein
Van Guru
Originally Posted by 99sport View Post
Hein,
We have put in our order request but do not yet have a delivery date. Pricing is to be determined. We will stock both 1.6mm and 2.9mm thicknesses.
https://www.3m.com/3M/en_US/company-...9877683&rt=rud
All the best,
Hein
DIYvan
541 490 5098
99sport (11-23-2019)
