I think we are having a communication breakdown. I miss took what you wrote on your first comment.
Not uncommon in email and forum postings... don't worry about it.
I took sides to mean legs of the system, i.e. hazards and turn sugnals.
When i write "sides" (especially involving turn signals) i mean "indicating LEFT turn" and "indicating RIGHT turn".
If i meant "turn signals" versus "hazards" i would use the word "circuits" or "path" (or i'd say "signals" and "hazards").
To be clear, all of my lights including my turn signals work correctly with the hazards activated. I have no functionality through the multi selector switch. If thats what you call the turn signal knob.
I don't think i ever mentioned "knob" ... i (like you) wrote multi-function switch (MFS), which means the stick that you push up and down to indicate right (up) and left (down). The term MFS also includes all the bits inside its cylindrical plastic housing that's mounted on the steering column (since that's where the contacts are).
All other lights functioning normally. No fuse looseness or blown ones. I guess that points to the knob/switch. Is that right?
It could still mean conductors built into Fuse Block #1, but i'd certainly suspect the MFS.
Unfortunately, it is very difficult to access the "intermediate points" to test things with a voltmeter or ohmmeter. You're pretty much forced to pull off the MFS switch and then see if the appropriate pin-to-pin (on its connector) connections are made (and opened) as you move the directional stick up and down.
It happened as I was driving. I had blown the body manufacturers fuse mentioned earlier however and didnt know if they may be connected. I cant recall if the signals worked when I first drove it after that happened, but I rhink they were working because i didnt notice til midway through the drive.
I can't see a reasonable way for the Body Man Fuse to have damaged the turn system, although explaining HOW you blew the fuse might yield a clue.
There have been "opened the MFS and fixed the contacts" postings (with photos), so there's hope.
I don't recall if the contacts they worked on were the turn signals or some other function (such as high/low beam headlights)
