Corbury1492
Ok I finally did it this weekend. After 2 years of enjoying summer and not working too much on the van. I pulled off the factory rear air-conditioner (after having it professionally decommissioned at the compressor with smaller belt and emptying the system).
(BTW van is out of warranty.)
Thanks to Paul http://paulsince72.wixsite.com/padams/sprinter. AND hein!
Macro steps:
1. remove aircon and prep brackets
2. test fit fan and solar supports
3. install fan on van
4. mount panels to solar supports (on floor)
5. lap seal fan and all openings
6. wait
7. mount solar array on van
8. complete wiring
9. test for water tight
10. replace interior
Here are the more detailed steps:
Previously
1. remove all the interior rear air-conditioner trim parts
2. remove the headliner
3. measure the hole
4. have an 1/8" aluminum plate made to fit the hole - including maxxair hole (I had a local sheet metal shop make me this on their water jet - $75.). Drawing is included - it fit perfectly.
5. create 3/4" mahogany wood "hoop" for the maxxair interior screw support.
Major steps
1. get on roof on some platform (I used my rack for much of this work).
2. uncover the system
3. unbolt the major parts of the condenser
4. cut the pipes where necessary
5. unbolt the interior fan unit from interior
6. hang a plastic drop cloth below the hole
Now you will have - a large hole in the roof and a couple of aluminum brackets with some weird shapes. AND 3 other openings: 1) 2 pipe fittings and 2) 1 power opening.
My goals
1. maxxair fan install
2. 2 x 100W solar panels
Tools
- angle grinder with cutting wheel (you should be comfortable with this tool with aluminum - you don't want to hit the roof with it).
- drill - for new holes
- jigsaw with metal cutting blade
- rivet gun
- cold galvanizing paint
Next steps
1. cut off the pipe fittings flush with the existing OEM roof fittings.
2. push the electrical whip inside the van.
3. *delicate work* use angle grinder to trim the aluminum brackets to about 3-4" above the roof. You will have a jagged angle sticking up from the roof on both sides - but it will be ok!
4. dry fit the plate and the maxxair.
5. I found that the factory roof whole was slightly too small - I jig sawed it and painted it. It only needed about on 1/8" off on the whole - toward the front of the van.
6. dry-fit again.
7. cut piece to cover the the electrical hole.
Solar plan
- Get 2 x 8' - 2" Aluminum angle in 1/8" material.
- Test mount angles to the factory brackets.
- Test mount solar panels to the angles
- Make sure the panels will clear the maxxair fan - front and back. (measurements)
Next Steps - mount the panel to cover the main hole (and other openings)
1. dry fit the panel (and the hole piece) and clamp it in place.
2. pre-drill the rivet holes
3. add the maxxxair roof bracket, clamp and predrill all maxxair holes.
4. vacuum all drill shavings
Next Step - dry-fit solar before sealing maxxair and hole.
1. place angles on roof
2. clamp angles to the remaining factory air com mounting brackets
3. drill hole to attach angle to factory bracket
4. test fit
5. cut angle "foot" for the front of the solar angle (one for each side).
6. dill hole for the foot in angle.
7. test fit angle with foot
8. repeat for other side.
test fit solar wiring roof entry gland
1. cut hole in the roof panel.
2. clean and prep for mounting gland
Next Step - mount the maxxair
- this has been covered elsewhere.
- I used GRK cabinet screws into mahogany interior "hoop".
Next step - Seal the maxxair, roof holes and solar gland.
- self-leveling Lap seal - covered in depth elsewhere.
Final step
- after assembling solar panels to angles (on floor)
1. lift assembly on to the roof
2. bolt to solar assembly to the existing air con angles
3. glue angle "feet" to the roof with 3m 4000.
Let the entire thing set overnight.
Interior
- caulk all the remaining pipe openings with 4000.
- pull fuse for the AC.
- wrap all remaining electrical connectors and secure to interior ceiling.
Observations
- WOW the van drives better without all that weight up in the air.
- love the solar power
- Victron is really great - I'm using the MPPT 75/15 with the bluetooth dongle and the iPhone app.
Macro steps:
6. wait
8. complete wiring
Previously
3. measure the hole
Major steps
My goals
Tools
- rivet gun
Next steps
6. dry-fit again.
Solar plan
4. test fit
Final step
Interior
Observations
