Go Back   Sprinter-Forum > VS30 Sprinters > VS30 Talk
VS30 Talk General Discussions related to VS30 W907 Sprinters.
Old 12-07-2018, 02:08 PM   #1
Gski
Default The choice: Diesel vs Gas
The 2019 sprinter adds one more decision to the purchase process.
My personal experience is all in sailboats, where diesel is the obvious choice because it is safer and the engine will last at least 40 years with a bit of regular love. Most of that isnít relevant for vans.
Hearsay reliability evidence isnít much help to me, even if you know a guy who knows a guy who has a sample size of one.
I am not interested in getting religion: both engine types have been in use for a century because both work well for many purposes.
Gas advantages
- More filling stations, more pumps too.
- Can idle to charge batteries or to heat water or to heat the van.
- More familiar to most North American drivers.
- Better for drag racing.
Gas disadvantages
- Less energy per litre of fuel, so less range between fill ups.
- No (KL1) fuel tap, so harder to fuel an Espar heater.
- Gas engines historically have shorter lifespans, but so do vans. If the engine lasts as long as the vehicle, not a problem.
Economy depends on the relative prices of gas and diesel where you are filling your tank. That will change as we travel.
How would you choose?
Gski is offline   Reply With Quote
The Following User Says Thank You to Gski For This Useful Post:
Mikayla (12-23-2018)
Old 12-07-2018, 02:17 PM   #2
john61ct
Default Re: The choice: Diesel vs Gas
In NA diesel is way more expensive to keep serviced after 100-150K.
May not be important to buyers of new, but I think will influence resale value.
First-year bugs shakeout process on the other side.
john61ct is online now   Reply With Quote
The Following User Says Thank You to john61ct For This Useful Post:
Old 12-07-2018, 02:41 PM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
From what I've read on here I don't think that choice actually exists!
In other words whilst MB may show a Gas option in their brochures, etc. in reality they are not offering one for sale in the US.
Keith.
35,000 miles from New
Old 12-07-2018, 07:41 PM   #4
Rock Doc
My personal experience is that going in, diesel is more expensive than gas and it takes forever to make up the original purchase difference in fuel costs over the life of the vehicle; break-even is HUNDREDS of thousands of miles down the road. Second, diesel is more expensive to maintain (more oil per change, etc.) Performance wise, diesel has much more torque than gas, but gas has more horsepower. (Do you want to pull quickly, or over the long haul. Gas sprints, diesel marathons.)
However, gas engines tolerate sitting unused much better than diesel. Diesel engine seals dry out much more quickly than gas engine seals. Depending upon your use, if you drive frequently, diesel can be your friend. If you drive occasionally (like with most RV uses), gas may be a better choice. For myself, I drive my diesel Sprinter RV on a 20+ mile loop at least once a month when I’m not RVing it. (I was badly burned on this with a diesel pusher motorhome in the past—$7k to reseal the Cummins C8.3 engine!!)
Rock Doc
2014 Pleasureway Plateau TS in 2013 Sprinter 3500
Rock Doc is offline   Reply With Quote
The Following User Says Thank You to Rock Doc For This Useful Post:
Old 12-07-2018, 07:44 PM   #5
vantastic adventure
I owned a gas ProMaster for a hot min. 7-10 MPG got me out of that vehicle in a hurry! (along with many other issues).
vantastic adventure is offline   Reply With Quote
The Following User Says Thank You to vantastic adventure For This Useful Post:
Old 12-07-2018, 08:12 PM   #6
Graphite Dave
Dave Orton
Sold 08 diesel Sprinter and bought 15 gas Transit Ecoboost. One of my better decisions.
No prestige but a much better driving vehicle. Cost of ownership is approximately the same. Transit gets 3 mpg less fuel economy than the V6 Sprinter but gas costs less and scheduled maintenance costs are significantly lower. Any repairs are less costly with a Transit. At 26,000 miles the Transit has not required any repairs. Sprinter by 20,000 miles had to be towed once and had an EGR valve failure that caused a LHM. We will see if the Transit is better or worse than the Sprinter. So far better.
Unfortunately the gas engine that Mercedes is offering in the new Sprinter is small. Probably fine for local deliveries but not as suited for a full conversion or pulling a trailer IMO.
http://ortontransit.info
Old 12-07-2018, 08:42 PM   #7
Mein Sprinter
2010 Roadtrek SS Agile
Mein Sprinter's Avatar
Gas advantages
Gas disadvantages
Assuming that MBenz has finally corrected its "emission" idiosyncrasies with their 2019/2020 models then I'd stay Diesel.
Had quite a few diesels; VW Rabbit Truck; VW Jetta; 240D and 300TD..non of these had DEF or DPF. Ran forever but rust killed them on the East coast.
Diesels simply last longer as they are marinated in oil: diesel fuel is an oil... every part is lubricated to the hilt, then comes motor oil which further smears the bowels of its engine. Motor oils must be changed in due time as the oil thickens.
Gasoline on the other hand is a "solvent".. everything within its engine is sort of diluted and oil must be changed to regain lubricity.
Yes, the world is changing and many will see the demise of diesels eventually.
cheers...
Mein Sprinter is offline   Reply With Quote
Old 12-10-2018, 05:34 PM   #8
The Grand Tour
Mercedes rates the gas engine at the same 190 horsepower that they rate the diesel engine at.
And the gas engine has two more gears and a better gear spread.
Regardless of the load, the gas engine should perform better than the diesel engine.
The Grand Tour is offline   Reply With Quote
The Following 2 Users Say Thank You to The Grand Tour For This Useful Post:
Mikayla (12-23-2018), ptheland (12-10-2018)
Old 12-10-2018, 05:42 PM   #9
The Grand Tour
The Sprinter 3.0 diesel was rated at 188 horsepower last year. This year, they are now calling it 190 horsepower.
Mercedes rates the M274 gas engine at up to 241 horsepower in other applications. But when offered as a $7,000 less-expensive Sprinter engine, they're now claiming that it only makes 190 horsepower.
I'm calling shenanigans- marketing shenanigans. Mercedes doesn't want to lose sales on the diesel engine that is slower, won't save you any money on fuel, and sells for $7,000 more.
The Following User Says Thank You to The Grand Tour For This Useful Post:
Old 12-10-2018, 05:52 PM   #10
Mercedes probably de-rated the gas engine for the heavy sprinter. The same approach was used with the diesels compared to the car applications. A full loaded 3500 towing with a GCWR of 14klbs can peg the load at 100% for 30 minutes straight.
I would be curious to see the emissions gear on the gas powerplant. I believe its GDI? which adds a fair bit of complexity...
The Grand Tour (12-10-2018)
