Old 02-28-2020, 03:30 PM   #31
lindenengineering
Default Re: Swirl flap mechanicals
Ah you are referring most likely to BG 244 or 245 for regular fuel additive use .
See this
Dennis
The Following User Says Thank You to lindenengineering For This Useful Post:
Kajtek1 (02-28-2020)
Old 02-28-2020, 03:36 PM   #32
manwithgun
manwithgun's Avatar
Hereís another one that shows the procedure in detail along with whatís being expelled from the tailpipe.
https://youtu.be/w4ABTo42tKA
2007 Dodge Sprinter 2500 144WB V6 OM642 NCV3 CRD
manwithgun is online now   Reply With Quote
Old 02-28-2020, 03:53 PM   #33
Sinatorj
Is this something that would be valuable as a PM in order to prevent buildup?
Sinatorj is offline   Reply With Quote
Old 02-28-2020, 04:16 PM   #34
lindenengineering
Yes a nearby shop who specializes in Ford diesels does this as routine.
Knowing of course that 2004 to 2009 F250'/350s and the 6 litre engine families were very prone to coking up.
The older 6 litre Powerstroke EGR cooler was a major repair expense to owners when it first came out. That was when we first got interested in BG solutions to correct common expensive issues on Fords. Nowadays we have cross transferred those procedures to Spriners because of the upper cylinder coking issues particularly on the CD14 engine series.
Offering it as a routine service can become an issue simply because as a shop unless the engine is exhibiting a driveability problem , it can be a hard sell as many think its just an upsell and not necessary.
Dennis
manwithgun (02-28-2020)
Old 02-28-2020, 05:40 PM   #35
4wheeldog
2018 144" Tall Revel
Dennis
Out of curiosity, what do you charge for the BG treatment?
I already do BG 245 every 10k. And I have a 2018. Just wondering if it is worth it, when it gets to 60k or so.
4wheeldog is online now   Reply With Quote
Old 02-28-2020, 05:44 PM   #36
smiller
2008 View J (NCV3 3500)
Originally Posted by manwithgun View Post
Here’s another one that shows the procedure in detail along with what’s being expelled from the tailpipe.
I gotta ask... is the DPF removed prior to performing the BG intake service? If not how is it not destroyed (or at least compromised or service life shortened) when all that crap runs through it?
smiller is online now   Reply With Quote
Old 02-28-2020, 06:05 PM   #37
showkey
Originally Posted by dharmasprint View Post
So the bottom line here, is that you have to remove the intake manifolds off to examine the nature of the condition.
Is walnut blasting an option?
What's "repacking the intake manifold"?
Sorry auto correct typo........replacing not repacking.
2008 3500 chassis Class C built in 2010
Pulling 6x12 enclosed trailer
showkey is offline   Reply With Quote
Old 02-28-2020, 06:15 PM   #38
showkey
Dennis
Thatís understandable as the Repair industry as over sold ( aka upsells ) all the flushes for fuel injection, power steering, intakes, brake, exhaust, transmission and engine flushes.
Historically flushes have been a huge profit center.......aka wallet flush.
Old 02-28-2020, 06:36 PM   #39
Kajtek1
Is it coincidence that you can't buy Liqui Moly 3029 Diesel Engine Air Flow Intake Cleaner in USA?
Watching youtube- the product is really used in UK, but beside Dennis, no shop will offer it in this country.
Bottom line - $30 of "miracle in the bottle" can save you over $2000 in manifold changing.
Kajtek1 is online now   Reply With Quote
Old 02-28-2020, 07:04 PM   #40
lindenengineering
OK if you say so.
I won't risk any engine clean out that jeopardizes the end result.
The moment I hear clattering & banging it means something is getting damaged.
Irrespective of offering an upsell, we use the BG system mostly for a clean out before dismantling in the shop.
This saves us a huge amount in manifold & port clean up times. Turn around times are drastically reduced.
It also cleans out the pan, removing carbon & tar at piston levels and below
Often we do a SAAB pan rake out test before clean out just to see how much carbon & crap has settled in the pan.
We can usually purge the pan & sump with the BG system chemicals whereas before we were dropping the sump box to clean it out .
Again time saved .
I suppose compared to Ford owners who are facing huge bills for carbon related teardown,the BG system saves the customer money and boost our profit line.
So its win win all round especially with Ford Powerstroke EGR coolers & pesky manifolding.
Dennis
