dpearson
2011 Serenity
My 2011 Serenity has decided to start leaking water from around the fill valve. It appears to be related to one of the plastic fittings that is threaded into the fill valve. Now for the problem... how on earth does one get at those fittings? The fill valve is attached to the plastic service panel with a pop-riveted strap. Even if I drill out the rivets and remove the strap I still won't be able to get into the little space to do any work on the valve. The service panel itself is screwed and riveted to the underbody frame, and the black tank is right behind the panel. Do you drill out the rivets and remove the panel? Do you drop the black tank? This looks like a little job turning into a much bigger job. I am contemplating cutting out the part of the panel that holds the fill valve, but I am worried making it look good afterwards. Any guidance would be helpful.
Thanks
David
Thanks
David
