2004 Sprinter Airstream Westfalia
Offered for Sale : 58,500.00
An incredibly practical camper-van, a self-contained unit that you can park in a standard size parking space. It has received gentle use & has been conscientiously & professionally maintained. Sale due to limitations from back surgery. Clean in & out, a head-turning classic touring coach.
Brochures:
http://dl.dropbox.com/u/6232178/Airstream Westfalia Sprinter brochure 1.pdf
http://dl.dropbox.com/u/6232178/Airstream Westfalia Sprinter brochure 2.pdf
TECHNICAL SPECIFICATIONS
Model: Airstream Westfalia
Chassis: 2500 Mercedes-Benz Sprinter Van w/unibody construction
Engine: Mercedes Benz CDI Turbo Diesel 2.7 liter 154 HP @ 3800 RPM
Transmission: 5 speed automatic with overdrive, 244 lbs. torque @ 1600-2400 RPM
Brakes: 4 wheel disc brakes w/ABS system
Wheelbase: 140"
Michelin Radial Tires with alloy wheels
Turning radius: 21'
Gross combined weight rating (GCWR): 13,550 lbs
Gross vehicle weight rating (GVWR): 8,550 lbs
Unit base weight (UBW): 7,100 lbs
Net carrying capacity: 1,450 lbs
Towing capacity: 5000 lbs
Hitch tongue max weight: 500 lbs.
Towing hitch
Diesel tank capacity: 26.4 gal
14V/200-amp alternator & 2 auxiliary 85 amp hour gel batteries
Belted Seating capacity: 5
Sleeping capacity: 4 (sleeps two up top & two below)
Fresh water tank w/drain: 26.4 gal
Water heater (LPG manual light): 3 gal
Holding tank: Gray Water 18.5/Black Water 9.6 gal
LPG with remote fill: 33 lbs
Patio Awning: Fiamma
DIMENSIONS
Exterior length: 18'5"
Exterior width: 6'3"
Exterior height with a/c: 11'
Interior head room (sofa location, living area): 7' 9"
Interior width (floor): 5'8"
Cabin door width: 3'5"
INTERIOR DRIVER COMPARTMENT
Swivel seats for driver and front passenger
Driver & front passenger air bags
3-way adjustable driver seat
3-point seat belts w/ extension & head restraints Automotive air conditioning / heater
AM/FM w/ mp3 player input / Sirius Radio
Power windows & mirrors
Cruise Control
LIVING/SLEEPING AREA
Large power skylight with remote & rain sensor
Integrated screen/shades on all windows
Heat insulated vent windows in roof
Laminate countertops
Washable durable vinyl flooring throughout
Storage racks in rear doors
Built-in lockable safe
Roof bed - 6'6" x 4'8" w/ high comfort springs & safety net - comfortable!
Sofa - converts into a 6'4" x 4'2" double bed
Large removable dining table & side folding table
KITCHEN
Laminate cabinets and galley top with backsplash
Stainless steel sink w/ glass cover & chrome faucet
Pull-up stainless steel draining board
BATHROOM
Complete wet bath with shower, hand basin, storage cupboard, large mirror and toilet - shower/faucet unit recently replaced w/ new equipment
Roof vent
Outdoor shower hookup, hose & nozzle w/ mix valve
APPLIANCES
Twin burner stainless steel gas stovetop & range vent
2.1 cubic feet refrigerator & freezer
3 gallon LPG water heater
Microwave
Low profile 110/12V Kerstner air conditioner
Cable TV & telephone hook-ups (1 each)
17" LCD flat panel TV w/ DVD & USB streaming
Smoke, carbon monoxide & LPG detectors
Airtronic diesel-power auxiliary heating system w/ timer - needs service
110 Volt inverter
ELECTRICAL - FUNCTIONAL
Power lock doors w/ remote keyless entry
External waste & water connections
Main switch for 12V supply and water pump (new H2O pump)
12V fluorescent lighting w/ RFI ballast under overheads
2.5KW generator w/ remote start, LPG powered (ONAN)
30 amp service (includes 50 amp 25' power cord)
Central control & monitoring panel: heating, refrigerator & freezer, water tank levels & battery
TECHNOLOGY AND SAFETY
ESP - Electronic Stability Program
BAS - Brake Assist System
ASSYST maintenance monitoring system
Fire extinguisher
Front independent suspension w/ front & rear stabilization bars
Heavy duty front & rear shock absorbers
Four wheel ABS & disc brakes
EBD (Electronic Brake Force Distribution)
Acceleration skid control
Replacement Parts - engine hoses, fuses, pump
Back up camera
8' Aluminum collapsible step ladder - stores away
Recently Serviced by Dr. A - Service records
CURRENT MILEAGE (July 2011)
63,000 Miles -Mechanically Sound
Images to follow after the 4th of July weekend
Steve & Debbie McKinney
Conway, NH 03818
603-447-3372
mckfam@ncia.net
Brochures:
Wheelbase: 140"
Turning radius: 21'
Towing hitch
DIMENSIONS
Cruise Control
KITCHEN
BATHROOM
Roof vent
APPLIANCES
Microwave
110 Volt inverter
Fire extinguisher
Back up camera
Conway, NH 03818
603-447-3372
mckfam@ncia.net
