2003 3500 RV with diesel D5WSC Espar Hydronic that circulates engine coolant to preheat engine, circulates to the rear cabin heater box, and circulates to a water-water heat exchanger for shower water. There is no storage tank-style hot water heater.
The Espar is mounted behind the driver side underneath. Its elevation is below the top of the engine radiator. When mounted there is zero access to the bleed screw. I suppose I could remove the mounting bolt and rotate the unit out just far enough to get access to the bleed screw.
I repaired the combustion blower to solve a F31 and then reinstalled it.
Now, I need to bleed it to solve a consistent F14 overheat, most likely caused by insufficient coolant flow due to air pockets. Yeegads! Now I gotta bleed the sucker.
Has anybody here done this? Espar documentation is woefully short on this issue. To my knowledge there are no other bleed ports in the system.
Exactly what is the step by step procedure to bleed it? HELP!!
Thanks in advance.
Rick M
Thanks in advance.
Rick M
