Go Back   Sprinter-Forum > VS30 Sprinters > VS30 Write-Ups
VS30 Write-Ups Help other VS30 owners by posting your experience working on your Sprinter.
Old 04-01-2019, 04:30 PM   #11
Sprinty
Default Re: DD/Digital Lab/Camper
How did you find fitting it into the closed ribs? Were you able to fish it through or just had to pack it in?
At 3.5“ thick, do you have to compress it a fair bit? I believe the ribs/ cavities of the van are about 2” deep?
Sprinty is offline   Reply With Quote
Old 04-03-2019, 01:55 AM   #12
sulkorp
At 3.5 thick, do you have to compress it a fair bit? I believe the ribs/ cavities of the van are about 2 deep?
No problems getting it into any parts of the van. I didn't have to fish it, it was pretty easy to get it in. It's really easy to cut out pieces and pull it through. The size of the wool will keep it in place. Super 77 for any bits otherwise.
If it was a small cavity it would have gotten squished into there.
I understand that an airgap is part of the insulation process. There is not always an airgap, in the closed portions. Although if wanted you could not use the full thickness of the 3.5. It is pretty simple to separate it, and if you wanted to make a thinner it wouldn't be hard.
3.5 was what I could find in my timeframe, and happy with it so far.
sulkorp is offline   Reply With Quote
Old 05-09-2019, 04:01 PM   #13
sulkorp
Finally had some time to finish off the drivers side deatmatting and insulation.
All of the factory lower trim now is insulated.
Luckily I could work around the seats being installed in the van.
Old 05-29-2019, 11:01 AM   #14
Notfamous
Nice work so far!
What ramp are you using to load your cart? I have a filmtools Jr that I'm going to be strapping down in the back.
Sent from my Pixel 3 XL using Tapatalk
Notfamous is offline   Reply With Quote
Old 05-30-2019, 11:47 PM   #15
sulkorp
Originally Posted by Notfamous View Post
Nice work so far!
You'll have plenty of space for that cart : )
I currently load in-and-out a Deploy v3 cart, and have an INOVATIV Ranger cart inside for storage/workspace.
The INOVATIV was my old cart, yet needed to switch footprints as I couldn't get into a lot of locations by myself. It also took a lot to wire up everyday.
I have a ramp which is temporary, and it is a Prime Tri fold ramp. I didn't want to get a traditoinal ramp installed, as they take up a lot of space and block the rear windows.
This one I use 2/3 sections, and am able to walk up and push in my cart.
I first used it going straight into the floor of the van, yet noticed the ramp was damaging the gasket that goes around the rear doors. Now I place it on the bumper, and have a small hump to get over when in.
Ideally I'm going to get a Roll-A-Ramp, as they don't seem to take up a lot of space.
I store the ramp strapped together and inside for transport at the moment. It slides in along the drivers side.
Here are a couple of photos of the setup currently when I am working in the van.
Old 07-08-2019, 08:49 PM   #16
Scribe with a Stylus
You mentioned that “I have a ramp which is temporary, and it is a Prime Tri fold ramp. I didn't want to get a traditoinal ramp installed, as they take up a lot of space and block the rear windows.
I store the ramp strapped together and inside for transport at the moment.”
Would either of these be suitable for picking up partially disabled relatives who might be able to walk up the ramp but not be able to step up the high steps into a Sprinter? Would either be suitable for use with the sliding door instead of the back door?
Walk in His Peace,
David
Scribe with a Stylus is offline   Reply With Quote
Old 07-09-2019, 09:42 PM   #17
sulkorp
Walk in His Peace,
David
Yes both would work for that method. I have not put the Prime ramp at the side, so cannot mention its mounting.
I would suggest the Roll A Ramp
https://www.rollaramp.com/
Van page
https://www.rollaramp.com/van-ramps/
It can either roll into itself, or be tightened and fold like a folding ramp.
The prime ramp is very simliar to a ladder, and is not solid all the way up.
Roll A Ramp is more of a solid ramp/step the whole way up. It can also be mounted via quick release pins if it is going in/out.
On their website they show a variety of uses for their ramps (ie houses, accessibility)
Old 07-16-2019, 03:31 PM   #18
sulkorp
Walk in His Peace,
David
Here are some photos of the ramp setup I am doing.
I realize the roll a ramp can be quite pricey, so this may actually fit your needs. It is less than $200
I have no problem walking up and down it.
There are folding variations, although you would need 2 of them, and they don't lock together.
Old 07-31-2019, 01:30 AM   #19
Default Re: DD/Digital Lab/Camper - Ramps for access - Thank you
Thank you. That information was very useful.
Walk in His Peace,
David
Old 08-21-2019, 07:41 PM   #20
sulkorp
Lots of work, little time to do bigger jobs on the van.
Maxxair fan and adapters are in. Going to be putting a 4pin XLR connector on the wiring, and run it off of existing 12v motorcycle batteries that I have in pelican cases.
Wrapping out equipment after long hours and little light at times, has led me to a bunch of little scratches. Spent some time covering them up with paint. I will eventually be putting in paneling/material so not too concerned about the look.
The configuration of the carts/equipment is still changing, which is a learning process for where equipment ends up rubbing up against the body.
Both wheel arches are now fully deadmatted. I did take off the rubber protective coverings, to find out that my main equipment cart has rubbed up against the rubber and paint. sometimes denting the panel. Sanded those down to remove any surface rust, later primed. The current configuration is likely going to be the final one, as there isn't any damage happening on a recurring basis.
