markxengineering
I am using the 1250 (for B2B only, I have separate controller for solar due to my panel voltage being too high). I am using the ignition start and manual override, both features work fine to turn the charging on. Turning off is the hassle, when I want to prevent B2B charging and use Solar only. This is 95% of my use. In order to get what I needed, I took the 1250 apart, pulled out the on/off toggle switch, and relocated it to my center console, where it belongs. The on/off switch comes by default in a ridiculous location which is inaccessible without removing two screws and sticking fingers near live wires. Probably so they can sell more of their "remote control" kits someday. The kits are not available yet.
Other than that, I'm happy, it sends 50+ amps into my house bank and it's easy to set up/customize.
