Old 09-29-2014, 08:40 PM   #1
bhenrich
Default Espar Underseat Installation
Group,
I recall seeing a write-up on here of an Espar under passenger seat installation. Does anybody know what I'm talking about? I would appreciate any help or information from anybody that has mounted one there before.
thanks,
Blake
bhenrich is offline   Reply With Quote
The Following User Says Thank You to bhenrich For This Useful Post:
elMano (03-16-2017)
Old 09-29-2014, 09:03 PM   #2
GeorgeRa
2013 Sprinter DIY 144WB
GeorgeRa's Avatar
Default Re: Espar Underseat Installation
There are other folks who installed them as well, search for - passenger espar d2
http://sprinter-source.com/forum/sho...&postcount=536
http://sprinter-source.com/forum/sho...&postcount=537
Good luck.
George.
Edit: On the page 5 from the "Factory Espar installation" there is a picture of the perforated cover on the right side of the passenger seat to improve air circulation. I checked with Eberspacher, MB and VW about availability of this item and got nowhere. MB and VW said to go to Eberspacher and vice versa. Bought the original solid door and will experiment drilling holes after returning home.
File Type: pdf Factory espar installation for Sprinter and Crafter.pdf (1.60 MB, 1230 views)
George.
https://goo.gl/photos/2NCR3teXLSwNYSwN8
GeorgeRa is offline   Reply With Quote
The Following 8 Users Say Thank You to GeorgeRa For This Useful Post:
bhenrich (09-30-2014), Curious George (11-27-2015), Deancm (03-26-2016), Do the Sprinter (11-11-2015), hippy (10-24-2019), jamesthomsen (12-29-2015), kcmtb (11-30-2019), Mickyfin (11-14-2018)
Old 09-29-2014, 09:38 PM   #3
Diamondsea
Use the search function at the top right of the screen. Search for ESPAR INSTALLATION and also ESPAR UNDERSEAT INSTALLATION.
2013 Advanced RV
Southeastern Virginia
Diamondsea is offline   Reply With Quote
Old 09-30-2014, 12:50 AM   #4
bhenrich
Thanks George, yours is the exact post & installation I wanted to copy! Your thread doesn't have any of the search terms I was using, like under seat, passenger, etc. Thank you!
Good luck.
George.
Old 09-30-2014, 02:15 PM   #5
PaulDavis
George did a nicer job than me, but you can also see mine here:
http://sprinter-source.com/forum/sho...1&postcount=37
Just fired it up finally last weekend - worked without any problems after the second start.
Aimed for a year of vanlife, ended up owning a house in Galisteo, NM | 2010 170 cargo NCV3 | my build thread | Wifely blog: Two people, 1 van, 2 bikes, lots of running shoes
PaulDavis is offline   Reply With Quote
Old 10-01-2014, 01:27 AM   #6
CuStOm
Great work guys.
These look pretty small. Do they really pump out enough heat to keep a sprinter at 68-72f in the winter if camping?
CuStOm is offline   Reply With Quote
Old 10-01-2014, 01:45 AM   #7
PaulDavis
I haven't tried mine yet but (a) other posters have claimed "0F outside, 70F inside my 170" (b) the thing does blast out some very warm air :)
Old 10-01-2014, 01:55 AM   #8
Diamondsea
In my former DIY my D2 could just keep up 68 degrees when it was 20 outside. I had reasonable insulation. It becomes more difficult to heat past a temperature rise of 40 degrees. Interestingly for refrigeration it seems to be increasingly difficult to cool more than 40 degrees below ambient!
2013 Advanced RV
Old 10-01-2014, 08:40 PM   #9
Rensho
Do you guys feel that the underseat install adds to the noise of the heater? Is it an issue at all?
I'm about to install mine.
Rensho is offline   Reply With Quote
Old 10-01-2014, 08:45 PM   #10
PaulDavis
when the fan is on high, the noise of the furnace itself is hardly an issue. when it is on low, it seems to me that the fan is still the loudest component (which isn't saying much - the thing just isn't very loud).
it is easy for me to understand what other D2/D4 users have said about the noise of the pump tick though ... at night, i can imagine this being disconcerting because it is not a continuous sound.
