-   Sprinter Talk (https://sprinter-source.com/forum/forumdisplay.php?f=3)
-   -   Need a Degreaser that Actually works (https://sprinter-source.com/forum/showthread.php?t=24127)
PubRider 12-17-2012 03:05 AM
Recently changed my Turbo Resonator, I imagine it probably leaked for years prior to me changing it.
I'm an Old Air Cooled VW guy and I've never seen stuff like this.
I've tried 3 different types of degreasers with only marginal results.
There is this weird baked on snott/jelly like coating that they're not even phasing.
The rear axle is got some of this going on as well...
*Any recommendations would be appreciated...
Eric Experience 12-17-2012 09:40 AM
Re: Need a Degreaser that Actually works
Pubrider.
Best to leave the mess there. It is very dangerous to use powerful solvents on a modern electronic motor. The alternator is just under the turbo and it contains an electronic regulator which is sealed with a wax to make it water proof, powerful solvents will rip into the wax. Just close the bonnet. Eric.
Altered Sprinter 12-17-2012 10:40 AM
Just replace it they don't cost that much,if it's leaking there may have hairline crack as this was normal on OEM resonators. I belive the Q5 was the upgraded resontor.
Richard
skydiver007 12-17-2012 11:43 AM
Are we on the juice again. He has already replaced the resonator, just looking for a proper de-greaser to clean up the offending mess left behind by a leaky resonator. :bash:
Altered Sprinter 12-17-2012 11:47 AM
brush KERO let it soak for ten minutes then spray degreaser on and wash off, then dry off with air compressor, or a can of compressed air at 75pi.
PubRider 12-18-2012 12:46 PM
Yup the resonator is all done and working great.
The bolts for the resonator prior to me cleaning were barely visible.
I'm just looking to spot clean a few areas of extreme build up is all.
