-   Sprinter RV's & Conversions Talk (https://sprinter-source.com/forum/forumdisplay.php?f=5)
-   -   Water tank & Pump (https://sprinter-source.com/forum/showthread.php?t=9236)
baldeagle 01-02-2010 07:52 PM
Water tank & Pump
Hi all and Happy New Year. If anyone has seen my pics they would have seen I'm making a van from scratch so have loads to learn. I have an upright water tank with a hole for the pipe to suck water out, with an external pump. I finally fitted it today only to find the pump leaks. As I'm strapped for cash the best option is a submersible pump from Ebay for 7ish but whats the way to drop it into the tank as surely if you have a big hole to drop it in it'll all slosh out? :idunno:
http://i672.photobucket.com/albums/v...t/DSCI0164.jpg
nick41 01-03-2010 05:28 AM
Re: Water tank & Pump
Mate i would just cut a hole in the top and drop the pump in with pipes and wires through the same hole the sikaflex a patch over the hole. When the sika set's no water will get out and it will be sealed for life.:thumbup:
sikwan 01-03-2010 05:38 AM
Can you fix the pump, like replace the seals?
At least take it apart (since you're thinking of buying/using something else) and find out why it's leaking. You may even luck out and find something odd to repair the leak.
I wouldn't go submersible because if it breaks you will have to take it out to fix it.
Hit The Road Jack 01-03-2010 11:31 AM
I agree with Seek on this one Baldeagle...:hmmm:
Quick fix:
http://www.ehow.com/how_7774_repair-rvs-water.html
New pumps:
http://www.pplmotorhomes.com/parts/r...ater-pumps.htm
