-   Sprinter RV's & Conversions Write-Ups (https://sprinter-source.com/forum/forumdisplay.php?f=119)
-   -   2018 Sprinter Cargo 144 Adventure Van (https://sprinter-source.com/forum/showthread.php?t=68045)
overland.van 08-01-2018 08:37 PM
Well, I pulled the trigger and bought a new 2018 Sprinter 2500 Cargo 144WB 4x2 in Stone Grey at Mercedes-Benz of Loveland yesterday.
Figured I would start a thread here just to keep my own thoughts and ideas organized and chronicle the build.
Let's start with the van...
Optional equipment is as follows:
  • Active Safety Plus Package
  • F01 Swivel Seat Package
  • X13 Lighting Package
  • X22 Trailer Hitch Package
  • X27 Additional Battery Package
  • AR2 Axle Ratio 3.92
  • CF4 Suspension w/H.D. Front & Rear Stabilizers
  • CT1 Rear Spring Vibration Absorbers
  • D03 Roof - High
  • D13 Roof Rails
  • D93 Deletion of Cargo Partition (Standard)
  • ED8 Parametric Special Module (PSM) Preparation
  • EN7 Audio 15 (Standard)
  • ES2 12V Power Outlet Rear Compartment
  • E46 12V Power Outlet - Driver Seat Base
  • FJ1 I/P Hinged Lid-Center Stack Bin
  • FZ9 Keys - Two Additional Masters
  • F43 Laminated Glass Rear
  • H16 Heated Driver Seat
  • J51 Fuel Gauge, Optimized for AUX Fuel Tap
  • L65 Lamps - Cargo Compartment
  • MS1 Cruise Control
  • RF1 Continental Tires
  • RM1 Tires Mud & Snow
  • R98 Rims Painted Jet Black
  • T16 Sliding Door - Right Side (Standard)
  • T74 Assist Handle - Sliding Door
  • T75 Door Mounted Assist Handles, Driver & Passenger
  • T85 Assist Handle - Left Rear Door
  • T86 Assist Handle - Right Rear Door
  • V43 Cargo Van Wood Floor (Standard)
  • W17 Fixed Window, Right Side Front
  • W70 Tint for Rear Windows and Rear Side Windows
Sprinter build sheets are weird.
Here's a couple pictures of the van with its big (little?) brother.
https://photos.smugmug.com/photos/i-...-z2LqqzX-L.jpg
https://photos.smugmug.com/photos/i-...-jNC9xLZ-L.jpg
grantwilson 08-01-2018 09:03 PM
Re: 2018 Sprinter Cargo 144 Adventure Van
awww man i want your rear doors
Wyuna 08-01-2018 09:40 PM
love that colour, looking forwards to the build
overland.van 08-02-2018 02:45 AM
Why's that?
overland.van 08-02-2018 04:54 AM
Preliminary Build Plan
Okay, so I'm going to layout my build plan, as it were, thus far...
My mantra for this build is K.I.S.S. - I hope no one out there doesn't know what that acronym means :laughing:
My plans so far...
Exterior:
  • Matte black hood wrap, maybe even the side rocker panels and the front of the high roof
  • 265/75/16 BFG KO2s (if keeping the factory steelies) or 265/70/17 KO2s and Black Rhino Warlord Wheels
  • Auxiliary lighting
  • Winch? (I know the Agile Off-Road setup only works with the 4x4 models but does anyone know anything about this offering from N4 Off-Road? http://www.n4-offroad.com/?Winch-pla...II-III&lang=fr
  • Dual Maxxair fans
  • Awning
  • Roof rack and ladder?
  • CR Lawrence Awning window behind driver door, opposite sliding door
  • Sliding "bunk windows" on both sides in the rear, mounted at the height where the bed will be most of the time. Trying to figure out what size would fit nicely between the E-Track MOAB bed rails... 10x30? 10x28?
  • MB windows in rear cargo doors
Interior:
  • Adventure Wagon RUV interior kit and MOAB bed, with a couple of Mule storage bags
  • Mountain bike fork block mounts
  • Snowboard / ski rack mounted to wall
  • Chemical toilet
  • MB second row seat install (would have it added using the MB parts, and work done by DOT certified shop that will do all necessary reinforcement for safety)
  • Rubberized flooring with some additional e-track for more tiedown locations
  • Some sort of basic storage box / drawer in the rear for ease of storing and accessing helmets, pads, other recreational gear
  • Espar heater with high-altitude kit
  • Fridge/Freezer (already own an ARB 50QT that is in the Jeep)
  • USB / 12V plugs as well as some standard wall plugs for ease of charging devices
A/V & Electrical:
  • Replace factory headunit
  • Replace factory speakers and add some additional speakers in rear, definitely 2 in the upper part of the rear doors, and maybe some midway through the van
  • Adventure Wagon electrical kit for USB / 12V / Lighting / Fans
  • House battery system (at least upgrade OEM AUX battery to the AdWag twin 6V kit, if not go with something better)... Would like to be able to charge devices, run fridge and other electronics / stereo for 2-3 days without starting the van
overland.van 08-02-2018 07:33 AM
Ah, I just watched your window install video... you have the glass in the rear. I want your rear doors! :laughing:
Desertbound 08-02-2018 06:23 PM
Our winch mount will work on your van. It is compatible with newer 2wd vans that have the 2015+ front end.
https://vancompass.com/collections/s...2007-2500-3500
Take a look at the instructions on the above webpage and let us know if you have any questions.
sales@vancompass.com
-Rob
overland.van 08-03-2018 05:28 AM
-Rob
Thank you, Rob! I will have a look.
overland.van 08-03-2018 07:16 AM
Order of Operations
I have been thinking through order of operations on the build, as well as making some minor changes to my ideas for the interior based on conversations I'm having with various van builders.
I think the first things I'd probably want to tackle are:
- A window tint to the front windows to match that of the glass on the sliding door. The sun here in Colorado is no joke.
- Hood and rocker panel wrap, while the van is still clean...
- Head unit. I had heard the stock one is horrible. One look at mine confirmed what I had heard.
- Windows. At least a full size CR Laurence window with awning vents opposite the sliding door, to get some airflow and make it more immediately livable. If I can figure out the approximate height where the MOAB bed would be mounted (with mattress on top), maybe the bunk windows as well, but probably best to wait on these until doing the AdWag interior.
- Fans. Front and rear Maxxair 7500K is what I'm thinking. The AdWag interior will support this configuration and this will allow for more airflow (one fan blowing in, one pulling air out and hopefully enough that it pulls some flow through the window.
- Sound deadening and insulation. This is a freaking wormhole, if I've ever seen one. Thinsulate, Hush Mat, Denim, Lizard Skin, open cell foam, Luxury Liner Pro, Damplifier, Polyiso, etc., etc., etc. :thinking: :wtf:
- Tires. Want to get these on before ski season.
Next I'm thinking I'd tackle:
- Espar heater with high-altitude kit and muffler. Want to get this in before the winter.
- Second row seat mounts. Originally was thinking of mounting in the 1.0 position, but a builder suggested the 2.0 position, as it would clear the MOAB bed and leave some room for a galley if I wanted to add one, or even a table between the front swivel chairs and the bench. This would also help when bringing friends along on ski trips.
- Floor. Rubberized, with E-track for tie downs and bike fork blocks. This would at least allow me a water resistant floor for ski season and also the ability to mount a bike upright in the back for fall trips to Fruita.
Lastly:
- Batteries
- AdWag interior
- Additional speakers and Amplifier
