Old 01-10-2010, 02:37 AM   #1
fredbail
Default Proposed fix for rusty fuel filler neck ?
Recently I was offered to have my tank filler neck replaced, along with the gas cap, with a new fuel filter. The tank would be removed and taken to someplace that cleans tanks out and cleaned. The fuel lines and the injectors would be cleaned. The reasoning is that rust has settled in my tank from the rusty fuel neck. The rust mixes with the fuel and is not adequately screened by the fuel filter, messing up the injectors, and maby (insert your own word here) the cylinder walls. This proposed work would be $1,200 ....Whatchuthinku? ,thanks PS. 2006...way rusty neck and cap
fredbail is offline   Reply With Quote
The Following User Says Thank You to fredbail For This Useful Post:
Plutogogo (02-25-2012)
Old 01-10-2010, 04:32 AM   #2
Altered Sprinter
Altered Sprinter's Avatar
Default Re: Proposed fix for rusty fuel filler neck ?
Whatchuthinku?
Well as in proper Her Royal Majesty's English
fredbail I have news for you
Mercedes-Benz-Sprinter from the extensive listings of part numbers apart from to C clips between the Note:Plastic fuel tank to the rusty Neck Quote there are no metal fuel filler tubes
Behind the plastic fuel cap there are two of;and only two small sections of gold cadmium plated metal objects:Plated as a rust preventative of course.
IN the first and foremost line of reasoning to your whatdoyathinkum:... Rust is not present as such.
Fact your fuel and I hope it's ULSD summer grade therefore water in U.S fuels is present the rust is not rust but a rusticate ,thus is an algie bacterium that forms a fungus on the rear plated fuel cap and the metal plated locking mechanism the lockes your cap down [AIRTIGHT it's vacuum SEALED]THE AIR PRESSURE IS ATMOSPHERICALLY INERT.
"What to look for"
Open fuel door flap,remove fuel cap and look at the metal rear section behind the
plastic cap!If you can see water droplets then this is contaminated fuel from your supplier,or suppliers.
Over time the algie can attack this section and cause the rusticate to attack and form a rusticate fungus that eventually eats the metal out and real rust forms.
Basically the back metal section would fail and collapse,this has not happened to you unless your living in the Artic region of minus 30fC permanently.
I'm as usual prepared to back this up with H/D photographic evidence
The cap can not rust if an additive is used And I can prove it
The long term preventative solution is to add to your fuel a Non alcohol based upper cylinder lubricant with anti-gel properties such as Red-line 85plus with winterized anti gel agents.
Red-line is guaranteed to work as I have used it full time since January 2005
There is no rust in the tank, fuel lines, or even a hint of injector damage or leakage anywhere.
If Alcohol based additives are used{Be Warned} this will eat out and damage any copper component in your fuel lines to the injectors O rings.
I would strongly advise you to lift the engine cover and look for Black death before you even think of wasting $1200 dollars of your very hard earned money
Or go to a authorized Mercedes Out let for a proper diagnostic report.
What sediment that is collected at the bottom of your tank; if present may go to both Oil and fuel filters they will capture any large contaminates.
US Winter based fuels are your enemy not your friend Use an additive.
RICHARD
No Shalam - No Shalom
JSMITH0711 (09-24-2013)
Old 01-10-2010, 04:40 AM   #3
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
How many miles do you have on your 2006?
I think my understanding about the fuel system is less complete than I'd suspected.
This is what I know:
The factory filter is rated at 5 microns. That's too fine a mesh for human red blood cells - at 7 to 9 microns - to pass. That's gotta be a really fine grit of abbrasive - so to speak - passing through your high pressure pump.
What doesn't make sense to me:
I know that the filter's not 100% efficient, but wouldn't it get clogged with visible rust first?
I thought a clogged fuel filter pretty much starved the engine.
Does the filter have a "bypass" for when the media's clogged; the engine is getting "unfiltered" fuel?
Where did I lose the plot?
-Jon
Aqua Puttana (01-10-2010)
Old 01-10-2010, 04:49 AM   #4
sikwan
06 T1N Can
sikwan's Avatar
Originally Posted by Altered Sprinter View Post
"What to look for"
I found rust on the underside of my cap too, but it was surface rust as described above and had not eaten into the base metal or coating. A quick rub with Redline Diesel Fuel Catalyst (the little leftover in the bottle after dumping it in the tank before refueling with diesel) cleaned up most of the build up and has stayed clean since.
I didn't think the filler neck was metal, at least the one in my '06 isn't (ok maybe just the top, but still). But in any case, I have this nice bridge that I can sell you for $800...
Old 01-10-2010, 01:49 PM   #5
maxextz
Rollin Rollin Rollin.....
maxextz's Avatar
ive found the only solution to this problem is to become richard.
did you see his sprinterand his fuel cap am i jealous?........feck i am.
max........
The Following 2 Users Say Thank You to maxextz For This Useful Post:
Altered Sprinter (01-10-2010), GEARS (01-10-2010)
Old 01-10-2010, 02:04 PM   #6
Altered Sprinter
That sprinter cost a mint so I have to look after it.
Richard
Old 01-10-2010, 10:53 PM   #7
GEARS
2005 140WB standard roof
GEARS's Avatar
When I bought my 2005 Sprinter, the fuel cap tabs were rusted off and the filler neck looked worn out.
I replaced them myself with about $80 worth of dealership parts in about an hour but wish that I knew the oil fill cap was the same size because it's a whole lot cheaper than a gas cap!
You don't have to drop the tank to replace the filler neck because it's high on the side of the tank, just make sure the fuel light is on and it's a piece of cake! You don't even spill a drop of fuel either.
GEARS is offline   Reply With Quote
Old 01-11-2010, 12:35 AM   #8
stp57
Is Marvel Mystery Oil alcohol based?
Steve
stp57 is offline   Reply With Quote
Old 01-11-2010, 12:52 AM   #9
jdcaples
jdcaples's Avatar
Steve
The MSDS is attached.
Are mineral spirits a form of alcohol?
MM010-4.pdf
-Jon
Old 01-11-2010, 02:08 AM   #10
-Jon
Jon,
No.
I looked it up for verification.
Mineral Spirits
Mineral spirits is the name for what is a "light hydrocarbon" or "blended petroleum hydrocarbon solvent" used for degreasing and cleaning, as well as for thinning any oil-based paint or varnish.
Mineral spirits contain Stoddard Solvent*, hydrodesulfurized naptha, nonanes, n-propylbenzene, trimethylbenzenes, ethylmethylbenzenes, alkanes, isoparaffins and cycloalkanes, all of which come from the refining of petroleum.
*Stoddard solvent is a petroleum mixture that is also known as dry cleaning safety solvent, petroleum solvent and varnoline. The main trade name is Varsol.
Mineral spirits are flammable and toxic.
Link is here:
http://www.secondchancegarage.com/public/315.cfm
AP/vic
NAS (N. Amer. Spec) 2004 140 2500 >310,000 mi.DAD Paint=Arctic Whitewash Brushtone Grey
2006 Freightliner 140 2500 >148,000 mi. Arctic Whitewash
