Can some one explain to me what it means when the "A/C off Rest" button light is illuminated? Not sure if it is off or on when lit?? Also, would my van be a T1N or a NCV3?
Thanks, Daig
2007 Dodge Sprinter 2500, 170 wb, highest roof. |
#2 | |
Not Suitable w/220v Gen
When the AC Rest light is on, I believe our AC Compressor is resting, not working. -Jon
#3 |
Daig
Your van is a NCV3 (2007 and newer) If the red light is on your a/c is at rest. That's how I remember it. If you push the defrost button the red goes out meaning the a/c compressor is running. If you want conditioned air push the button, light goes out, compressor starts. A nice feature if you can remember to do it is turning the temp control all the way warm or all the way cold depending on the season, and push the a/c rest button when you exit the van (key off). The fan will come on to position 1 and will continue to run for 30 minutes or some predetermined battery voltage to pump conditioned air into the cabin in your absence. A Reilly nice feature in cold environments. gary
Keep Doing What You Did, and You'll Keep Getting What You Got... ![]() 2008 2500 CRD 144 inch High Roof Crew Van |
#4 |
>1,800,000m in MB vans
I interpret the REST function to mean "free cab heat with engine off" - it only works with ignition off after all and is separate from AC. It's not a great feature though is it - the engine's radiated heat doesn't last much more than ten minutes even though the REST timer runs to thirty.
Simon, aka MIG - 416CDI (An OM651 Euro5 Panzerwagen that thinks it's a chocolate lime...) |
#5 |
Great, thanks for the input fellas. This formum is very helpful.
| Thread Tools | |
| Display Modes | |
