| T1N Write-Ups Help other T1N owners by posting your experience working on your Sprinter. |
All the details are shown in
Rlent posted that his oil pressure at idle & @ operating temperature (using Mobil 1 0w40) was 0, or close to 0, but that he wasn't sure how accurate his gauge was. That concerned me, so before I installed the gauge, I cobbled together a test setup where I could compare the reading of the gauge to my tire pressure gauge. They both read the same over a range of pressures. Rlent also posted that he thought Mobil 1 0w40 was very "thin" at operating temperature and that might be why his gauge reading was so low. I too use Mobil 1 0w40 (because it's strongly recommended by the '03 service manual) and I also think it looks very thin at temp. But, my experience since installation of this gauge has assured me this oil is indeed ideal for my engine. Although I don't have oil pressure specs for my engine, I do have specs & data for an earlier version (OM602.961 - my son's 1987 190D 2.5T). This engine's oil pressure at idle & @ 80c (176F) operating temp is 26 psig (Rotella T 5w40 synthetic). From his service manual, oil pump relief valve opening pressure for this engine is 5.8 bar (84 psig) & minimum pressure specs @ operating temp are 0.3 bar (4.4 psig) @ idle and 3 bar (44 psig) @ 3k rpm. For comparison, my engine's oil pressure @ 73F ambient (startup) is 57 psig @ idle and hits a plateau of ~85 psig (probably relief valve opening pressure) @ 1500 rpm. At 180F (82C) operating temperature, oil pressure @ idle is 22psig & in 5th gear is about 5 less than the speedometer reading (not really connected to each other, but an easy way for me to remember in the coming years). So, @ 60 mph indicated (~2150 rpm), it's 55 psig & @ 70 mph indicated (~2550 rpm) it's 65 psig. So, Mobil 1 0w40 allows me to use the engine to its practical limits while (mainly) operating below the relief pressure (meaning full flow of oil to the engine, except when cold) and well above (likely) minimum oil pressure specs. Last edited by sikwan; 10-07-2010 at 01:27 PM. Reason: Combined Doc files into one PDF and attached to this post. |
| The Following 7 Users Say Thank You to talkinghorse43 For This Useful Post: | Aqua Puttana (12-20-2011), autostaretx (09-15-2011), Buckskinner (04-03-2013), Ciprian (09-25-2009), jdcaples (09-25-2009), mackconsult (10-07-2010), owner (06-21-2012) |
#2 |
Spark Plugs not allowed!
Where did you get the gauge pod that fit the sprinter? Any 2 or 3 gauge pods available?
Ciprian ~~~~~~~~~~~~~ 2004 Freightliner Sprinter. |
#3 |
#4 |
I beg to differ with you on this statement ..... I am a mechanical engineer who designs pumps, so I know a bit about hydraulic systems.
When a relief pressure valve goes off in a designated "finite" hydraulic system. Flow will become constant. Below the cracking point of the relief pressure valve the flow will have a linear relationship to pressure. I.E. At low pressure you will have less flow than at say a higher pressure. What this means is that max flow for the hydraulic system is achieved at the highest pressure. On a lighter note ............ can you give an estimated costing on how much all this was?
97 XR600R Honda Dual Sport Motorcycle 98 18' Avon RIB w/ 90 HP 4 stroke Yamaha 95 TDI Passat VW Wagon 05 2500 140" normal height sprinter van w/ veggie oil conversion kit ![]() 08 Laser Pro #194171 Vancouver, Washington, USA Sail Smart, Sail Hard, Then think about Sailing Fast !!!!! http://www.mackconsult.com/ Some day I will sell everything, buy a cascade 36 or a cal 40 sailboat, and turn left at the Columbia River Bar !!!!
#5 | ||
| The Following User Says Thank You to talkinghorse43 For This Useful Post: | Buckskinner (04-03-2013) |
| Thread Tools | |
| Display Modes | |
