Old 11-04-2009, 09:20 PM   #21
DesmoSprinter
Default Re: front speaker replacement
Do these speakers work for a 2002 Sprinter 2500 as well?
DesmoSprinter is offline   Reply With Quote
Old 11-05-2009, 04:48 PM   #22
surlyoldbill
surlyoldbill's Avatar
I think the 2002 and the 2003 are the exact same model.
2003 140shc 2500 passenger model
The Following User Says Thank You to surlyoldbill For This Useful Post:
DesmoSprinter (12-14-2009)
Old 12-14-2009, 04:04 PM   #23
DesmoSprinter
Thanks for the post guys. I can't believe that $24pair of speakers are a significant improvement over MB speakers. MB = FAIL!
It was an easy job, as you guys mentioned, even for a mechanically retarded like me
Installed in 2002 Freightliner Sprinter
Old 12-14-2009, 05:06 PM   #24
surlyoldbill
Glad it worked for you. The speakers are a BIG improvement over the stock speakers, which have tiny magnets and inferior cone material. There are probably no 4" speakers available that will give decent full spectrum sound, and if you're a partially-assed audiophile like me, you'll want to install some 6.5" speakers somewhere, and maybe a small powered subwoofer under the passenger seat (bolt it down good so it doesn't rattle). Speaker placement should be so that the left and right have as little overall difference in distance from your head as possible; mounting a speaker right above the door will make the driver side 1' from your head, and the passenger side 5' from your head, where mounting them in the bottom of the doors will make the driver side 4' from your head and the passenger side 6'.
My opinion on car stereo, especially in trucks, vans and convertibles, is that when you're driving the interior noise is so high that you will not be able to enjoy or notice the extra $1000+ you might spend on high-end components. And you have less of a target for thieves. If you are a younger person, you will probably want to throw this logic out the window and buy the most popular brand name equipment with more power than you could ever use, and put stickers on the outside of your van signifying that you have expensive equipment installed.
The old saying about all stereos is true; you can have the BEST radio/cd/etc player in the world, but it will sound horrible through crappy speakers; you should dedicate at least half of your radio budget toward the speakers because they are what actually recreate the sound, this goes for home systems, too. In this age of digital sound and amplification, the speakers are the MOST important component in your system, now more than ever.
On a side note, I should have thought of this before: my laptop speakers are not very loud, and watching movies while on road trips (parked) was difficult. I started to bring along a powered speaker for these trips, but I rediscovered in a drawer an FM transmitter that was designed to plug into MP3/CD players to play them over your car stereo before direct connections became popular. I now run the laptop audio through my sound system.
Old 03-02-2010, 10:00 PM   #25
mobileLA
I just " invested" in a pair of the $24 speakers at Wally World.
It was so easy to swap them out that I did it while waiting in traffic.
I am thinking about getting a Pioneer head unit with Bluetooth etc.
It's a P7100BT. Anyone have anything bad to say about them with fitment and such?
'05 140" Green Standard Top Mobile Design Studio
'03 1.8T VW Jetta
'74 VW Thing
'63 LI125 Lambretta with 200cc
mobileLA is offline   Reply With Quote
Old 05-06-2010, 03:23 PM   #26
Riptide
Riptide's Avatar
Here's my experience with changing out the front speakers to the VR3 units:
1. When I tried to pull off the drivers' side A-pillar cover, the entire foam insert exploded. The cleats on the pillar cover just would not come out. So, I have to order a new foam insert. ( P/N 05123185AA) The pillar cover does not have to be removed entirely; only enough to clear the speaker cover. The passenger side released much better...
2. The speaker covers come up without too much problem. Note how it snaps in.
3. As was stated, bend three of the four mounting tabs off the new speaker. Then drop them in. I did not tape them or adhere them at all. The fit seemed snug enough.
4. Reinstall the pillar cover, giving a good whack over the areas of the three mounting pins.
They do sound better, but now that I have to replace the foam insert, the total project is considerably more than 24 bucks. Oh well, might as well take the opportunity to run the cable up to the rear view camera/mirror.
The Following 2 Users Say Thank You to Riptide For This Useful Post:
eghaley (10-11-2010), TX-Sprinter (08-28-2012)
Old 05-06-2010, 03:27 PM   #27
hkpierce
I guress I would be too cheap to replace the foam - just tack-glue it back, put the fascia back on, and forget. Out of sight, out of mind.
Old 05-06-2010, 05:09 PM   #28
Riptide
Riptide's Avatar
Originally Posted by hkpierce View Post
I guess I would be too cheap to replace the foam - just tack-glue it back, put the fascia back on, and forget. Out of sight, out of mind.
I thought about that, but the foam unit, which is reinforced with a plastic frame, screws to the pillar, and then the pillar cover snaps to the foam unit. When it exploded, it was because the screw mounts had ripped out. For some reason, the foam insert seemed stuck to the pillar cover when I tried to pull it off.
Besides, once I know it's broken, I can't leave something broken, even if it is covered up. It's an affliction.
Old 05-08-2010, 01:55 PM   #29
bcholka
Have you guys seen these door panel speakers from Ebay?? I did a search on "door speakers" and didn't come up with much so I figured I'd post this E-bay listing. I tried to copy some pictures over as well but was unsuccessful. The panel/speaker combos look nice!!
Welcome to eBay!
Find items similar to Dodge or Mercedes Sprinter Door Panel Audio Upgrade. See all items in - Car Electronics > Car Speakers & Speaker Systems.
Listed in category:
Electronics > Car Electronics > Car Speakers & Speaker Systems
Also Listed in:
eBay Motors > Parts & Accessories > Car Electronics > Speakers & Speaker Systems
Watch this item
Zoom
Enlarge
99 to 07 Sprinter Van Speaker Upgrade
Item condition: --
Price: US $299.00 Buy It NowBuy It Now
or
Best Offer: Make OfferMake Offer
Watch this item
You're Invited! Join eBay Bucks and earn 2%. See conditions
Shipping: $20.00Standard Flat Rate Shipping Service | See all details
Estimated delivery time varies.
Returns:
No Returns Accepted
eBay will cover your purchase price plus original shipping.
Learn more
Seller info
cbquad ( 514)
97.6% Positive feedback
Ask a question
Save this seller
See other items
Other item info
Item number: 140321226930
Item location: Fort Collins, CO, United States
Ships to: Worldwide
Payments:
PayPal See details
History: 6 sold
SharePrintReport item
Description
Shipping and payments
Seller assumes all responsibility for this listing.
Last updated on 03:56:34 PM PST, Jan 09, 2010 View all revisions
Item specifics - Car Speakers
Type: Full-Range Speaker(s) Size: --
Component Type: -- Brand: --
RMS Wattage: -- Model: --
Condition: --
Item specifics - Parts & Accessories
Part Brand: -- Surface Finish: --
Manufacturer Part Number: -- Warranty: --
Placement on Vehicle: -- Condition: New
2000 - 2007 DODGE MERCEDES-BENZ SPRINTER VAN AUDIO UPGRADE
THIS IS A BRAND NEW PRODUCT MANUFACTURED IN THE UNITED STATES BY KUSTOM KAR AUDIO, IN BOULDER, COLORADO
THESE CUSTOM FABRICATED DOOR PANELS WILL INCREASE THE AUDIO SOUND AND CLARITY IN YOUR SPRINTER VAN
THESE PANELS CAN BE INSTALLED IN UNDER 2 HOURS. EASY INSTALL, YOU CAN DO IT YOURSELF!!
MANUALS AND STEP BY STEP INSTRUCTIONS ARE INCLUDED FOR EASE OF INSTALL
MOUNTING HARDWARE AND WIRING IS INCLUDED AS WELL
NEW SYSTEM WILL USE THE POWER SOURCE FOR YOUR DASHBOARD SPEAKER SETUP AND DIRECT THE SOUND TO THE MEMPHIS AUDIO SPEAKERS IN YOUR NEW DOOR PANELS FOR AN INCREASED AUDIO EXPERIENCE
SETUP PROVIDES BETTER CLARITY, MORE MIDBASE, BETTER STEREOPHONIC SOUND AND BETTER IMAGING THAN YOUR STOCK SYSTEM
SYSTEM WILL WORK WITH ANY FACTORY AM/FM/CD/CASSETTE HEAD UNIT OR AN AFTERMARKET UNIT
SPEAKER MODEL - MEMPHIS CAR AUDIO 5 1/4" COMPONENT SYSTEM IN EACH DOOR
THE MEMPHIS SPEAKERS INCLUDE A 5 1/4" MID BASE DRIVER AND A 1" TWEETER
YOU WILL NOT LOOSE ANY OF YOUR PASSENGER OR DRIVER SIDE STORAGE ROOM. THIS UNIT JUST BOLTS RIGHT ONTO THE DOOR PANEL
AUCTION IS FOR TWO (2) DOOR PANELS, ONE FOR THE DRIVER SIDE, ONE FOR THE PASSENGER SIDE DOOR
THESE UNITS WILL WORK WITH SPRINTER VANS WITH POWER WINDOWS ONLY
INCREASE THE SOUND IN YOUR SPRINTER VAN!!
00929
bcholka is offline   Reply With Quote
The Following User Says Thank You to bcholka For This Useful Post:
turbotmy (07-18-2010)
Old 05-08-2010, 04:58 PM   #30
surlyoldbill
A surface mount limits the amount of resonant space, and won't sound as "loud" or as "full" as a speaker mounted in a cavity. I would check the mount location and make sure it isn't blocked by the seat or by where you normally put your leg. Could be a simple solution for better sound if you only have the dash 4" speakers, though.
