#11 |
06 T1N Can
The glow plug itself is around $16.88 each + tax/shipping.
Price is here... http://www.europarts-sd.com/get-pdf.php?f=sprinter.pdf Seek |
#12 |
Ok I have a question any one have a new glow plug kicking around that they can post a picture of ?
I purchased a set from ebay and well I just got them today and they sure don't look new They look like take-outs that have been cleaned up. I take a new one would what looks to be a copper thread lock line - looks to be brushed up on the threads.I might be wrong but they just don't look NEW I'll post up some pitures later.Andy
Andy C 05 Freightliner 2500 HT |
#13 |
Picture of what I got -- I guess I was expecting boxed ones but they were wrapped in bubble wrap just don't look brand new maybe it's just me
#14 | |
Doktor A
#15 |
Hi Doktor A, thanks for that info.
The person got back to me and sent this: "These plugs were taken off a non installed mopar reman motor. The motor was never ran other than the test run at the rebuilder. If you are unsatisfied I will refund you 100% and request a call tag to have the plugs picked up by UPS." What get me is the were listed as NEW OEM so that's what I wanted. My question is how do I know if these are actually new? They appear that they might but just sat in the motor for a bit. I only paided $56.25 for the 5 but if they are used they might not be worth that. Any ideas on what I should do ? Here's the ad: "You are bidding on a set of (5) new Mercedes O.E.M glow plugs part# 001-159-49-01. These glow plugs fit the 2.7L Mercedes Diesel used in the Dodge and Freightliner Sprinters. These glow plugs are backed by a 100% money back guarantee. "
#16 | |
Doktor A
I recognize your seller from the money back-call tag offer. I even know the engine they came from-he was truthful about that. Keep the glow plugs and give him a brief scolding- he really should have described them as "new take-offs". Doktor A |
#17 |
Thank you Doktor A,
That puts me at ease. So I'll keep them.
#18 |
Doktor A
The danger to the health of the module comes not from failed-open glow plugs but defective glow plugs that fail- shorted to ground. These can trigger a DTC-labeled as excess current draw of module. It can be diagnosed by disconnecting the relay(module) wiring connector. Pin #1-5 are the #1-5 cyl. glow plugs. A short length of 12 gage wire modified with a in-line 20 amp fuse, can then connect direct from battery to each pin -in turn. If fuse survives for minimun of 10 seconds- that particular glow plug being tested is not shorted to ground. Check all the glow plugs with this method and find the plug/plugs which are shorted-then you can safely replace a damaged module without endangering the new one. Doktor A
| The Following User Says Thank You to abittenbinder For This Useful Post: | kkanuck (08-10-2010) |
#19 |
The check engine light just turned on and I got this code off of network car: P0380: Glow Plug/Heater Circuit "A" Malfunction
Diesel engine may be difficult to start Initial Activity: 5/5/07 06:08 PM at 51213 miles P0672: Cylinder 2 Glow Plug Circuit Vehicle is reporting a potential powertrain sensor malfunction Initial Activity: 5/5/07 06:08 PM at 51213 miles It's the very first time that I've had this code, but the car runs great , no problems so far ,any sugestions? Jules
#20 |
I have a 2005 Dodge Sprinter with the 2.7litre 5 cylinder turbo diesel. I am trying to remove the glow plugs & what I am finding is that I can unscrew them & have the threads out of the head but the plug will not come out. Are they prone to carbon buildup on the inside? The hex of the plug appears to turn but not the stem of the glow plugs. Any ideas? I am use to GM stlye glow plug that with a little wiggling they came out. Thanks
| Thread Tools | |
| Display Modes | |
