Go Back   Sprinter-Forum > Regional Discussions > USA
Old 07-31-2009, 06:50 PM   #1
secondcc
Default Engine mods
I have already tryed asking in another section and tryed a search but came up with nothing. Has anyone added a chip, module, dpf or egr deletes, water meth injection, MP-8 fuel rail shim, bully dog programer or anything that would increase mpg. Performance wouldn't be so bad awell. I get 15mpg on average and less when driving around the city. I am carring a full load at all times. I think I am definetly over the weight limit.
2007 Dodge Sprinter 2500. AEM Dry Drop in Filter.
secondcc is offline   Reply With Quote
Old 08-21-2012, 12:32 PM   #2
NILTJason
Default Re: Engine mods
I was wondering if you have made any engine mods and if so what difference did it make? Also which engine do you have? I have an 08 with the diesel and am looking for an increase in mpg and hp as well.
NILTJason is offline   Reply With Quote
Old 08-21-2012, 01:00 PM   #3
sailquik
sailquik's Avatar
secondcc,
Are you running around town in "D" drive @ < 2000 RPMs?
Might have something to do with your poor mileage and lack of power.
Do you have a ScanGauge II or any other perfromance monitoring system
that will tell you the mileage and % of load on the engine?
"D" puts you in overdrive (0:83:1 in 5th gear).
Overdrive is not normally a good gear to drive around town in with a
heavily loaded to overloaded Sprinter.
If you could see how much of the time you are running at > 90% Load,
with the boost at max and the fuel flow at max, you might think about
running a little less gear to improve the fuel mileage AND performance.
Check the specs on your engine in the operators manual.
What the heck is an "AEM Dry Drop in Filter"?
Most aftermarket and cheap filters have been proven to give less
(rather than more) fuel mileage. Could this be a problem?
2012 MB Sprinter NCV3 3500 (DRW) Cargo, 9,990 GAVW, OEM Trailer pkg/ORIS
receiver hitch, RH slider window/rear windows, AUX IN port
for Sound 5, OEM cargo control package, leatherette seat fabric.
Had:
2011 MB Sprinter NCV3 3500 170" wb HT/SB (Deer Crash #2)@ 32K miles!
2010 MB Sprinter NCV3 3500 144" wb HT/SB "5 Tonner" (Not long enough) w 53K miles
2006 Dodge Sprinter T1N 3500 158" wb high top (Totalled in deer crash!) @ 105K miles
Old 08-21-2012, 02:02 PM   #4
dukepilot
Custom Spooling USA
dukepilot's Avatar
Custom Spooling can provide you with a customized ECU remap/tune for your Sprinter. Contact me, peter@customspooling.com for more info and prices. I'm in the SF Bay Area and we can arrange a test drive of my Sprinter and I can also do a mobile install of the tune in your Sprinter.
I'm also running a progressive water/meth injection system on my Sprinter so you can check that out as well during the test drive.
2008 144" NCV3 HiTop, 3.0 CRD OM642, Performance/Emissions Tune by CustomSpooling, Progressive Water/Methanol Injection, 3.92 Axle, Koni Shocks, 235/85-16 Cooper S/T Maxx Tires, Kicker Speakers/10" Sub Woofer/Boss 800 watt amp
If it causes trouble, delete it! If you want improved reliability, performance and economy, get a Customized Tune for your Sprinter! Contact peter@customspooling.com or go to www.customspooling.com and visit our Facebook page at www.facebook.com/customspoolingusa
dukepilot is offline   Reply With Quote
Old 08-22-2012, 12:49 AM   #5
lockrob
I was in the same situation.Maxed out on weight.City driving 15 mpg.
I got the dpf delete and reflash from Dukepilot .Milage went up to 18 in city
23 highway if you keep it at 65.
More power across the board.
Blowing a little smoke now on hard accel is my only complaint.
lockrob is offline   Reply With Quote
The Following User Says Thank You to lockrob For This Useful Post:
dukepilot (08-27-2012)
Old 08-22-2012, 05:01 AM   #6
scubanw3
We have a tuning module that is plug and play. It is emission compliant so you can have excellent performance and remain green. Here is a link to our info, http://sprinterstore.com/sprinter_power_module_chip.htm If you have additional questions, please call Mark or Foster at 503-692-0846 and they will be happy to help you.
Thank you,
Sprinter Store
19460 SW 89th Ave.
Tualatin, OR 97062
503-692-0846
scubanw3 is offline   Reply With Quote
Old 08-22-2012, 06:14 AM   #7
icarus
Hmmn,, about all that rot about how DPFs did nothing to reduce emissions?
Icarus
Old 08-27-2012, 02:37 PM   #8
gary 32
07 ncv3 pv
gary 32's Avatar
Icarus
Icarus you are correct.
Diesel Particulate Filters collect and burn soot into smaller particles.
Exhaust Gas Recirculation takes high particle diesel exhaust and runs it back through our motors to consume and filter high particulate matter. Both systems are very effective cleansers. Without them our diesels tailpipe emissions have larger, sometimes visible particles.
Dpf/egr problems include a narrow window of proper operation and function with no prescribed schedule for service. Every single UPS and Fed Ex truck in my area sure smells like a diesel again, weird because they maintain their own fleets....
gary 32 is offline   Reply With Quote
