| T1N Database Reference Information, Part Numbers, Recalls, TSBs, and etc. |
MIL DTC Light Trouble Code DRB OBD List Info
There have been many questions related to Diagnostic Trouble Codes (DTC), but I didn't find a central location for the information. I have compiled some of the information I found on Sprinter-Source that I feel will help. I have also attached some Text Format (txt) document lists figuring that then people can access the info without needing Adobe Acrobat. I'm hoping maybe with an Ipod Touch over WIFI? I guess this belongs here in "Database". Hope this helps. vic NOTE: Dodge and Freightliner dealers use specific scan tools for the Sprinter. An OBDII (On Board Diagnostics) scan tool may retrieve codes, but the Sprinter diesel engines are not required to be totally OBDII compliant. The Scangauge II will read more codes than some generic scan tools, but I believe it is still based upon OBDII specs. Places like Auto Zone, Advance Auto often will read codes for free using an OBDII scan tool. Unless you're using a dealer type scan tool use caution interpreting the codes that are indicated as there may be errors. A comment from my scan tool manufacturer can be found here: This is the answer from Actron http://sprinter-source.com/forum/sho...5&postcount=10 **** Edit 2010/2/6 Dodge dealers use a DRBIII with a special adapter cable and card to access T1N Sprinter malfunction (trouble) codes and much other information. As of this edit, Doktor A (Andy Bittenbinder) can also provide a DAD unit which accesses much more information than a OBDII scanner does. The DAD may show codes which are not found on these lists. DRBIII scan tools are not appropriate for ChandlerAZMan's NCV3. The appropriate tools are: StarSCAN (end of life'd), StarMOBILE (dead man walking), WiTECH (current Chrysler corporate preference), or an MB Star Diagnosis System (MB SDS). -Jon 20100419 edit: A comment by JD Caples about ScangaugeII and dealer code recognition. **** Just so you know: The ScanGauge will report different integers for DTCs from the factory tool (Chrysler's StarMOBILE, Chrysler's WiTECH and MB's Star Diagnosis System (SDS)). So you can't go waving the numbers at any service advisor with an expectation they'll "jump to it." I'm not saying the Scanguage is useless, but the ScanGuage's ability - to come up with the same info that a factory tool will present - is limited. -Jon Thread is here post #7: Loss of power http://sprinter-source.com/forum/showthread.php?t=10853 **** Caution: There are some inconsistencies or duplicate definitions for codes in these lists so care should be taken with interpreting the information. I have tried to update those problems which have surfaced in added posts. You will find them near the end of this thread. **** Here's a quick link which has a nice scroll feature. I don't know how complete or accurate the list is. It's probably worth checking before using Ctrl F to search my listings. http://www.fcrosby.com/sprinter/dtc.html A txt link list of DTC related code posts and lists: DTC_Codes_Misc_LinksTXT.txt A SprinterDTC_P_CodeList_1 in txt format SprinterDTC_P_CodeList_1TXT.txt A Powertrain_DTC-1Codes list in txt format Powertrain_DTC-1CodesTXT.txt A DieselGenericOBDCodesPartialList in txt format DieselGenericOBDCodesPartialListTXT.txt Related links in Sprinter-Source http://sprinter-source.com/forum/showthread.php?t=3799 http://sprinter-source.com/forum/showthread.php?t=5038 http://sprinter-source.com/forum/showthread.php?p=42243 http://sprinter-source.com/forum/showthread.php?t=833 I may try and add further posts with the actual text of the lists, but that may get too cumbersome. 2010/03/13 edit: Sikwan posted this info previously in another post. Thanks goes to Sikwan.. dtcdia.gif http://www.obdii.com/dtcanatomy.html **** Some NCV3 Code Information (Moved up from Post #24) I somehow had missed this NCV3 specific information related to codes. Thanks goes to JDCaples (Jon) for yet another great contribution. Most, Maybe All NAFTA NCV3 2007 DTCs http://sprinter-source.com/forum/showthread.php?t=7614 ****
NAFTA 2004 OM647 140 2500 Std Roof >255,000 mi. Paint=Arctic Whitewash DAD "My opinion and worth everything you'll never pay for it." is expressly implied. Keeping me on topic will be as successful as herding cats. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR Some people have 10 years experience, others just 1 year 10 times. Last edited by Aqua Puttana; 09-29-2012 at 10:45 PM. Reason: Add links |
| The Following 4 Users Say Thank You to Aqua Puttana For This Useful Post: |
#2 |
I couldn't open the txt documents with an Ipod touch. Here we go....
http://sprinter-source.com/forum/att...9&d=1233157552 Generic P-Codes Only Codes P0105 thru P2199 P0105 Boost Pressure Sensor Can Message Error_ P0105 Boost Pressure Sensor Plausibility_ P0105 Boost Pressure Sensor Signal Voltage Too High_ P0105 Boost Pressure Sensor Signal Voltage Too Low_ P0110 Intake Air Temp Sensor Signal Voltage Too High_ P0110 Intake Air Temp Sensor Signal Voltage Too Low_ P0115 Engine Coolant Temp Sensor Circuit Plausibility_ P0115 Engine Coolant Temp Sensor Circuit Plausibility With Engine Oil Sensor_ P0115 Engine Coolant Temp Sensor Circuit Signal Voltage Too High_ P0115 Engine Coolant Temp Sensor Circuit Signal Voltage Too Low_ P0180 Fuel Temperature Sensor Circuit Signal Voltage Too High_ P0180 Fuel Temperature Sensor Circuit Signal Voltage Too Low_ P0190 Fuel Press Sensor Circuit Malf Signal Voltage Too High_ P0190 Fuel Press Sensor Circuit Malf Signal Voltage Too Low_ P0201 Cylinder 1 Injector Circuit Excessive Current_ P0201 Cylinder 1 Injector Circuit Open Or Shorted To Ground_ P0201 Cylinder 1 Injector Circuit Shorted To Voltage_ P0202 Cylinder 2 Injector Circuit Excessive Current_ P0202 Cylinder 2 Injector Circuit Open Or Shorted To Ground_ P0202 Cylinder 2 Injector Circuit Shorted To Voltage_ P0203 Cylinder 3 Injector Circuit Excessive Current_ P0203 Cylinder 3 Injector Circuit Open Or Shorted To Ground_ P0203 Cylinder 3 Injector Circuit Shorted To Voltage_ P0204 Cylinder 4 Injector Circuit Excessive Current_ P0204 Cylinder 4 Injector Circuit Open Or Shorted To Ground_ P0204 Cylinder 4 Injector Circuit Shorted To Voltage_ P0205 Cylinder 5 Injector Circuit Excessive Current_ P0205 Cylinder 5 Injector Circuit Open Or Shorted To Ground_ P0205 Cylinder 5 Injector Circuit Shorted To Voltage_ P0300 Misfire Detected_ P0500 Wheel Speed Sensor Plaus Can Bus Message From Abs_ P0600 Can Data Bus Bus Circuit Fault_ P1105 Atmospheric Pressure Sensor Signal Voltage Too High_ P1105 Atmospheric Pressure Sensor Signal Voltage Too Low_ P1222 Acc Pedal Position Sensor 1 Ckt Plausibility_ P1222 Acc Pedal Position Sensor 1 Ckt Signal Voltage Too High_ P1222 Acc Pedal Position Sensor 1 Ckt Signal Voltage Too Low_ P1234 Acc Pedal Position Sensor 2 Circuit Plausibility_ P1234 Acc Pedal Position Sensor 2 Ckt Signal Voltage Too High_ P1234 Acc Pedal Position Sensor 2 Ckt Signal Voltage Too Low_ P1482 Glow Plug Module Communication Error_ P1482 Glow Plug Module Excess Current_ P1482 Glow Plug Module Incorrect Timer_ P1482 Glow Plug Module Internal Fault_ P1610 Engine Control Relay Shuts Off Too Early_ P1610 Engine Control Relay Shuts Off Too Late_ P1611 Sensor Supply 1 Voltage Is Too High_ P1611 Sensor Supply 1 Voltage Is Too Low_ P1612 Ignition Voltage Voltage Error_ P1615 Ecm Voltage Supply Is Too High_ P1615 Ecm Voltage Supply Is Too Low_ P1617 Ecm Read/Write Error_ P1617 Ecm Write Error_ P1617 Ecm Incorrect Value_ P1617 Ecm Read Error_ P1630 Immobilizer_ P1681 Acm Circuit Fault_ P2008 Fuel Pressure Sensor Circuit Signal Voltage Too High_ P2008 Fuel Pressure Sensor Circuit Signal Voltage Too Low_ P2009 Water In Fuel Sensor Water In Fuel_ P2009 Water In Fuel Sensor Signal Error_ P2011 Mass Air Flow Sensor Plausibility Air Mass Too Low_ P2014 Engine Oil Sensor Oil Temperature Plausibility_ P2014 Engine Oil Sensor Signal Plausibility_ P2014 Engine Oil Sensor Signal Voltage Is Too High_ P2014 Engine Oil Sensor Signal Voltage Is Too Low_ P2015 Fuel Rail Pressure Malfunction Maximum Fuel Flow Exceeded_ P2016 Fuel Rail Pressure Malfunction Fuel Flow Below Minimum Quantity_ P2017 Fuel Rail Pressure Malfunction Rail Pressure Is Too Low_ P2018 Fuel Rail Pressure Malfunction Rail Pressure Is Too High_ P2019 Fuel Rail Pressure Malfunction Maximum Fuel Pressure Exceeded_ P2019 Fuel Rail Pressure Malfunction Rail Pressure Is Too Low_ P2020 Fuel Rail Pressure Malfunction Rail Pressure Is Too Low_ P2021 Fuel Rail Pressure Malfunction Rail Pressure Too Low_ P2023 Fuel Rail Pressure Malfunction Rail Pressure Too High_ P2025 Intake Pressure Sensor Plausibility_ P2025 Intake Pressure Sensor Signal Voltage Too High_ P2025 Intake Pressure Sensor Signal Voltage Too Low_ P2038 O2 Sensor Circuit Fault_ P2040 Engine Oil Sensor Circuit Invalid Level_ P2040 Engine Oil Sensor Circuit Level Out Of Range_ P2041 Engine Oil Sensor Poor Oil Quality_ P2041 Engine Oil Sensor Quality Measurement Error_ P2041 Engine Oil Sensor Quality Plausibility_ P2042 Engine Oil Sensor Water Contamination_ P2043 Camshaft Position Sensor Circuit Open Circuit_ P2043 Camshaft Position Sensor Circuit Open Or Short Circuit_ P2045 Crankshaft Position Sensor Circuit Lost Signal_ P2045 Crankshaft Position Sensor Circuit Signal Plausibility_ P2047 Fuel Rail Pressure Malfunction Maximum Fuel Pressure Exceeded_ P2049 Fuel Rail Pressure Malfunction Deceleration Error_ P2051 Fuel Rail Pressure Malfunction Maximum Fuel Pressure Exceeded_ P2057 O2 Sensor Signal Circuit Signal Voltage Too High_ P2058 O2 Sensor Signal Circuit Signal Voltage Too High_ P2059 O2 Sensor Signal Circuit Signal Voltage Too High_ P2061 Engine Oil Sensor Open Circuit_ P2062 Engine Oil Sensor Monitoring Error_ P2062 Engine Oil Sensor Signal Error_ P2062 Engine Oil Sensor Synchronization Error_ P2063 Intake Air Temp Sensor Circuit Signal Voltage Too High_ P2063 Intake Air Temp Sensor Circuit Signal Voltage Too Low_ P2065 Mass Air Flow Sensor Supply Voltage Too High_ P2065 Mass Air Flow Sensor Supply Voltage Too Low_ P2066 Mass Air Flow Sensor Plausibility Air Mass Too High_ P2066 Mass Air Flow Sensor Plausibility Air Mass Too Low_ P2067 Mass Air Flow Sensor Signal Circuit Open Or Shorted_ P2067 Mass Air Flow Sensor Signal Voltage Too High_ P2067 Mass Air Flow Sensor Signal Voltage Too Low_ P2068 Mass Air Flow Sensor Plausibility Signal Ratio Error_ P2068 Mass Air Flow Sensor Plausibility Signal Ratio Too Large_ P2068 Mass Air Flow Sensor Plausibility Signal Ratio Too Small_ P2090 O2 Sensor Plausibility_ P2090 O2 Sensor Signal Fault_ P2091 O2 Sensor Low O2 Concentration_ P2091 O2 Sensor Signal Plausibility_ P2100 Fuel Pump Relay Circuit Open Circuit_ P2100 Fuel Pump Relay Circuit Shorted To Ground_ P2100 Fuel Pump Relay Circuit Shorted To Voltage_ P2100 Fuel Pump Relay Excessive Current_ P2104 Starter Relay Circuit Short Circuit_ P2110 Boost Pressure Servo Motor Circuit Short Circuit_ P2112 Boost Pressure Servo Motor Circuit Excessive Current_ P2112 Boost Pressure Servo Motor Circuit Open Circuit_ P2122 Internal Error Engine Shut Off_ P2123 Injector Circuit Fault_ P2123 Injector Circuit Low Side Shorted To Ground_ P2123 Injector Circuit Shorted To Ground Or Voltage_ P2124 Injector Circuit Fault_ P2124 Injector Circuit Low Side Shorted To Ground_ P2124 Injector Circuit Shorted To Ground Or Voltage_ P2132 Glow Plug Control Module Circuit Shorted To Ground_ P2132 Glow Plug Control Module Circuit Shorted To Voltage Or Open_ P2132 Glow Plug Control Module Fault_ P2133 Glow Plug Failure Cylinder #1_ P2134 Glow Plug Failure Cylinder #2_ P2135 Glow Plug Failure Cylinder #3_ P2136 Glow Plug Failure Cylinder #4_ P2137 Glow Plug Failure Cylinder #5_ P2139 Ecm Injector Output Stage_ P2140 Ecm Injector Output Stage_ P2141 Cylinder #1 Injector Open Circuit_ P2142 Cylinder #2 Injector Open Circuit_ P2143 Cylinder #3 Injector Open Circuit_ P2144 Cylinder #4 Injector Open Circuit_ P2145 Cylinder #5 Injector Open Circuit_ P2151 Fuel Press Solenoid Signal Implausible_ P2152 Starter Relay Circuit Short To Ground_ P2153 Starter Relay Circuit Ecm Thermal Overload_ P2153 Starter Relay Circuit Open Or Shorted To Voltage_ P2195 O2 Sensor Heater Circuit Fault_ P2197 Fuel Quantity Solenoid Ecm Thermal Overload_ P2197 Fuel Quantity Solenoid Open Circuit_ P2198 Fuel Quantity Solenoid Short To Voltage_ P2199 Fuel Quantity Solenoid Short To Ground_
NAFTA 2004 OM647 140 2500 Std Roof >255,000 mi. Paint=Arctic Whitewash DAD "My opinion and worth everything you'll never pay for it." is expressly implied. Keeping me on topic will be as successful as herding cats. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR Some people have 10 years experience, others just 1 year 10 times. Last edited by Aqua Puttana; 02-01-2009 at 01:08 PM. |
#3 |
Next P2199 thru P2633
P2199 Fuel Quantity Solenoid Short To Ground_ P2201 Immobilizer Can Message Error_ P2203 Torque Reduction Message From Abs Can Plausibility_ P2203 Torque Reduction Message From Abs Message Error_ P2203 Torque Reduction Message From Abs Messages Missing_ P2203 Torque Reduction Message From Abs No Communiocation_ P2203 Torque Reduction Message From Abs Plausibility #1_ P2203 Torque Reduction Message From Abs Plausibility #2_ P2204 Torque Reduction Message From Tcm Can Plausibility_ P2204 Torque Reduction Message From Tcm Engine Stop_ P2204 Torque Reduction Message From Tcm Message Error_ P2204 Torque Reduction Message From Tcm Messages Missing_ P2204 Torque Reduction Message From Tcm Plausibility_ P2204 Torque Reduction Message From Tcm Tcm Dtc #1_ P2204 Torque Reduction Message From Tcm Tcm Dtc #2_ P2208 Abs Brake Signal Can Message Implausible_ P2208 Abs Can Brake Signal Plausibility_ P2209 Abs Can Message Missing Or Incorrect_ P2210 Esm Can Message Missing Or Incorrect_ P2211 Etc Can Message Missing Or Incorrect_ P2214 Can Message Error_ P2217 Tcm Dtc Internal Fault Present_ P2218 Tcm Dtc 1 2 And 4 5 Shift Solenoid Fault Present_ P2219 Tcm Dtc 2 3 Shift Solenoid Fault Present_ P2220 Tcm Dtc 3 4 Shift Solenoid Fault Present_ P2221 Tcm Dtc Torque Converter Clutch Solenoid Fault Present_ P2222 Tcm Dtc Modulating Pressure Solenoid Fault Present_ P2223 Tcm Dtc Shift Pressure Solenoid Fault Present_ P2224 Tcm Dtc Valve Voltage Supply Fault Present_ P2225 Tcm Dtc Speed Sensor Voltage Fault Present_ P2226 Tcm Dtc Ewm Can Message Fault Present_ P2227 Tcm Dtc Right Rear Wheel Speed Implausible Fault Present_ P2228 Tcm Dtc Transmission Ratio Error Fault Present_ P2229 Tcm Dtc Can Msg Implausible Fault Present_ P2230 Tcm Dtc Tcc Excessive Power Consumption Fault Present_ P2231 Tcm Dtc Not Unequivocal Fault Present_ P2232 Tcm Dtc Negative Gear Comparison Fault Present_ P2234 Abs Dtc External Quantity Control Fault Present_ P2240 Abs Steering Angle Sensor Can Message Implausible 1_ P2240 Abs Steering Angle Sensor Can Message Implausible 2_ P2243 No Message Received From Skreem_ P2244 Instrument Cluster Message Plausibility_ P2252 Lateral Accelerator Sensor Plausibilty_ P2253 Steering Angle Sensor Plausibility_ P2258 Tcm Message Error_ P2258 Tcm No Can Message_ P2306 Sensor Supply 2 Voltage Is Too High_ P2306 Sensor Supply 2 Voltage Is Too Low_ P2319 Ecm Internal Error 1_ P2319 Ecm Internal Error 2_ P2319 Ecm Internal Error 3_ P2319 Ecm Internal Error 4_ P2321 Ecm Internal Error 5_ P2322 Crankshaft Position Sensor Plausibility_ P2323 Ecm Internal Error_ P2324 Ecm Injector Monitoring 1_ P2324 Ecm Injector Monitoring 2_ P2324 Ecm Injector Monitoring 3_ P2324 Ecm Injector Monitoring 4_ P2324 Ecm Injector Undervoltage_ P2325 Ecm Internal Error 1_ P2325 Ecm Internal Error 2_ P2325 Ecm Internal Error 3_ P2325 Ecm Internal Error 4_ P2327 App Sensor Plausibility_ P2329 Ecm Internal Error 1_ P2330 Ecm Internal Error 1_ P2332 Sensor Supply 3 Voltage Is Too High_ P2332 Sensor Supply 3 Voltage Is Too Low_ P2333 S/C Vehicle Speed Plausibility_ P2338 S/C Excessive Acceleration_ P2338 S/C Excessive Deceleration_ P2339 Ecm Checksum Error #1_ P2339 Ecm Checksum Error #2_ P2339 Ecm Invalid Coding_ P2339 Ecm Invalid Data_ P2342 Ecm Internal Error 1_ P2342 Ecm Internal Error 2_ P2343 Ckp Plausibility_ P2344 Kickdown Switch Plausibility_ P2347 Automatic Transmission Coded As Manual Transmission_ P2347 Can Bus Circuit Interuption_ P2347 Manual Transmissio Coded As Auto Transmission_ P2347 Write Error To Eeprom_ P2350 Internal Voltage Error_ P2351 Ecm Supply Voltage Too Low_ P2352 Injection Fault Quantity Error_ P2352 Injection Fault Torque Limit_ P2352 Injection Fault Excessive Engine Speed_ P2353 O2 Sensor Plausibility_ P2354 Ecm Internal Fault_ P2355 Egr Flow Rate Is Too High_ P2355 Egr Flow Rate Is Too Low_ P2356 Ecm Internal Error_ P2357 Ecm Internal Error_ P2358 Ecm Internal Error_ P2359 Boost Pressure Too High_ P2359 Boost Pressure Too Low_ P2366 O2 Circuit Fault_ P2500 Fuel Pressure Solenoid Circuit Excessive Current_ P2500 Fuel Pressure Solenoid Circuit Open Circuit_ P2501 Fuel Pressure Solenoid Circuit Shorted To Ground Or B+_ P2510 Boost Pressure Servo Motor Short To Ground_ P2511 Egr Valve Signal Circuit Shorted To Ground_ P2514 Crankcase Vent Heater Excessive Current_ P2514 Crankcase Vent Heater Open Circuit_ P2514 Crankcase Vent Heater Shorted To Ground_ P2514 Crankcase Vent Heater Shorted To Voltage_ P2521 Improper Start Attempt_ P2526 Boost Pressure Servo Motor Excessive Current_ P2526 Boost Pressure Servo Motor Open Circuit_ P2526 Boost Pressure Servo Motor Short To Ground_ P2526 Boost Pressure Servo Motor Short To Voltage_ P2527 Egr Valve Excessive Current_ P2527 Egr Valve Signal Circuit Open Circuit_ P2527 Egr Valve Signal Circuit Shorted To Ground_ P2527 Egr Valve Signal Circuit Shorted To Voltage_ P2531 Fuel Injector 1 Read Too Large_ P2531 Fuel Injector 1 Read Too Small_ P2532 Fuel Injector 2 Read Too Large_ P2532 Fuel Injector 2 Read Too Small_ P2533 Fuel Injector 3 Read Too Large_ P2533 Fuel Injector 3 Read Too Small_ P2534 Fuel Injector 4 Read Too Large_ P2534 Fuel Injector 4 Read Too Small_ P2535 Fuel Injector 5 Read Too Large_ P2535 Fuel Injector 5 Read Too Small_ P2537 Glow Plug Control Circuit Preglow Fault_ P2537 Glow Plug Control Circuit Preglow Short To Ground_ P2537 Glow Plug Control Circuit Preglow Short To Voltage_ P2538 Glow Plug Module Communication Error_ P2538 Glow Plug Module Excessive Current Error_ P2538 Glow Plug Module Timer Error_ P2606 Cmp/Ckp Synchronization Error_ P2625 Fuel Temperature Sensor Plausibility_ P2633 Maf Sensor Signal Plausibility_ All P-Codes
NAFTA 2004 OM647 140 2500 Std Roof >255,000 mi. Paint=Arctic Whitewash DAD "My opinion and worth everything you'll never pay for it." is expressly implied. Keeping me on topic will be as successful as herding cats. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR Some people have 10 years experience, others just 1 year 10 times. Last edited by Aqua Puttana; 02-01-2009 at 01:06 PM. |
#4 |
Next P0001 thru P0149
All P-Codes P0001 Fuel Volume Regulator Control Circuit/Open P0002 Fuel Volume Regulator Control Circuit Range/Perf P0003 Fuel Volume Regulator Control Circuit Low P0004 Fuel Volume Regulator Control Circuit Hi P0005 Fuel Shutoff Valve A Control Circuit/Open P0006 Fuel Shutoff Valve A Control Circuit Low P0007 Fuel Shutoff Valve A Control Circuit Hi P0008 Engine Pos Sys Perf Bank1 P0009 Engine Pos Sys Perf Bank2 P0010 A Camshaft Pos Actuator Circuit Bank1 P0011 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1 P0012 A Camshaft Pos-Timing Over-Retarded Bank1 P0013 B Camshaft Pos-Actuator Circuit Bank1 P0014 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1 P0015 B Camshaft Pos-Timing Over-Retarded Bank1 P0016 Crank/Camshaft Mis-align/sync P0017 Crank Pos-Camshaft Pos Correlation Bank1 Sensor B P0018 Crank Pos-Camshaft Pos Correlation Bank2 Sensor A P0019 Crank Pos-Camshaft Pos Correlation Bank2 Sensor B P0020 A Camshaft Pos Actuator Circuit Bank2 P0021 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2 P0022 A Camshaft Pos-Timing Over-Retarded Bank2 P0023 B Camshaft Pos-Actuator Circuit Bank2 P0024 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2 P0025 B Camshaft Pos-Timing Over-Retarded Bank2 P0026 Intake Valve Control Solenoid Circuit Range/Perf Bank1 P0027 Exhaust Valve Control Solenoid Circuit Range/Perf Bank1 P0028 Intake Valve Control Solenoid Circuit Range/Perf Bank2 P0029 Exhaust Valve Control Solenoid Circuit Range/Perf Bank2 P0030 1/1 02 Sensor Heater Relay Malfunction P0031 HO2S Heater Control Circuit Low Bank1 Sensor1 P0032 HO2S Heater Control Circuit Hi Bank1 Sensor1 P0033 Turbo Charger Bypass Valve Control Circuit P0034 Turbo Charger Bypass Valve Control Circuit Low P0035 Turbo Charger Bypass Valve Control Circuit Hi P0036 1/2 02 Sensor Heater Relay Malfunction P0037 HO2S Heater Control Circuit Low Bank1 Sensor2 P0038 HO2S Heater Control Circuit Hi Bank1 Sensor2 P0039 T/Super Charger Bypass Valve Control Circuit Range/Perf P0040 O2 Sensor Signals Swapped Bank1 Sensor1/ Bank2 Sensor1 P0041 O2 Sensor Signals Swapped Bank1 Sensor2/ Bank2 Sensor2 P0042 HO2S Heater Control Circuit Bank1 Sensor3 P0043 HO2S Heater Control Circuit Low Bank1 Sensor3 P0044 HO2S Heater Control Circuit Hi Bank1 Sensor3 P0045 T/Super Charger Boost Control Solenoid Circuit/Open P0046 T/Super Charger Boost Control Solenoid Circuit Range/Perf P0047 T/Super Charger Boost Control Solenoid Circuit Low P0048 T/Super Charger Boost Control Solenoid Circuit Hi P0049 T/Super Charger Turbine Overspeed P0050 HO2S Heater Control Circuit Bank2 Sensor1 P0051 HO2S Heater Control Circuit Low Bank2 Sensor1 P0052 HO2S Heater Control Circuit Hi Bank2 Sensor1 P0053 HO2S Heater Resistance Bank1 Sensor1 P0054 HO2S Heater Resistance Bank1 Sensor2 P0055 HO2S Heater Resistance Bank1 Sensor3 P0056 HO2S Heater Control Circuit Bank2 Sensor2 P0057 HO2S Heater Control Circuit Low Bank2 Sensor2 P0058 HO2S Heater Control Circuit Hi Bank2 Sensor2 P0059 HO2S Heater Resistance Bank2 Sensor1 P0060 HO2S Heater Resistance Bank2 Sensor2 P0061 HO2S Heater Resistance Bank2 Sensor3 P0062 HO2S Heater Control Circuit Bank2 Sensor3 P0063 HO2S Heater Control Circuit Low Bank2 Sensor3 P0064 HO2S Heater Control Circuit Hi Bank2 Sensor3 P0065 Air Assisted Injector Control Range/Perf P0066 Air Assisted Injector Control Circuit or Circuit Low P0067 Air Assisted Injector Control Circuit Hi P0068 MAP/MAF-Throttle Pos Correlation P0069 MAP-Barometric Press Correlation P0070 Ambient Air Temp Sensor Circuit P0071 Ambient Temp Sensor Perf P0072 Ambient Temp Sensor Low P0073 Ambient Temp Sensor Hi P0074 Ambient Air Temp Sensor Circuit Interm P0075 Intake Valve Control Solenoid Circuit Bank1 P0076 Intake Valve Control Solenoid Circuit Low Bank1 P0077 Intake Valve Control Solenoid Circuit Hi Bank1 P0078 Exhaust Valve Control Solenoid Circuit Bank1 P0079 Exhaust Valve Control Solenoid Circuit Low Bank1 P0080 Exhaust Valve Control Solenoid Circuit Hi Bank1 P0081 Intake Valve Control Solenoid Circuit Bank2 P0082 Intake Valve Control Solenoid Circuit Low Bank2 P0083 Intake Valve Control Solenoid Circuit Hi Bank2 P0084 Exhaust Valve Control Solenoid Circuit Bank2 P0085 Exhaust Valve Control Solenoid Circuit Low Bank2 P0086 Exhaust Valve Control Solenoid Circuit Hi Bank2 P0087 Fuel Rail/Sys Press-Too Low P0088 Fuel Rail Press Hi P0089 Fuel Press Regulator 1 Perf P0090 Fuel Press Regulator 1 Control Circuit P0091 Fuel Press Regulator 1 Control Circuit Low P0092 Fuel Press Regulator 1 Control Circuit Hi P0093 Fuel Sys Leak Detected-Large Leak P0094 Fuel Sys Leak Detected-Small Leak P0095 Intake Air Temp Sensor2 Circuit P0096 Intake Air Temp Sensor2 Circuit Range/Perf P0097 Intake Air Temp Sensor2 Circuit Low P0098 Intake Air Temp Sensor2 Circuit Hi P0099 Intake Air Temp Sensor2 Circuit Interm/Erratic P0100 Mass or Volume Air Flow Circuit P0101 MAF Sensor Perf P0102 MAF Sensor Low frequency P0103 MAF Sensor Hi frequency P0104 Mass or Volume Air Flow Circuit Interm P0105 MAP/Barometric Press Circuit P0106 Barometric Press Out of Range P0107 Map Sensor Voltage Too Low P0108 Map Sensor Voltage Too Hi P0109 MAP/Barometric Press Circuit Interm P0110 Intake Air Temp Sensor1 Circuit P0111 Intake Air Temp Sensor Perf P0112 Intake Air Temp Sensor Voltage Low P0113 Intake Air Temp Sensor Voltage Hi P0114 Intake Air Temp Sensor1 Circuit Interm P0115 Engine Coolant Temp Circuit P0116 Coolant Temp Sensor Perf P0117 ECT Sensor Voltage Too Low P0118 ECT Sensor Voltage Too Hi P0119 Engine Coolant Temp Circuit Interm P0120 Throttle/Pedal Pos Sensor/Switch A Circuit P0121 TPS Voltage Does Not Agree with MAP P0122 Throttle Pos Sensor Voltage Low P0123 Throttle Pos Sensor Voltage Hi P0124 Throttle/Pedal Pos Sensor/Switch A Circuit Interm P0125 Closed Loop Temp Not Reached P0126 Insufficient ECT for Stable Operation P0127 Intake Air Temp Too Hi P0128 Cooling Sys Error / Thermostat Perf P0129 Barometric Press Too Low P0130 1/1 02 Sensor Heater Relay Malfunction P0131 1/1 02 Sensor Shorted To Ground P0132 1/1 O2S Shorted To Voltage P0133 1/1 O2S Slow Response P0134 1/1 O2S Stays At Center P0135 1/1 O2S Heater Failure P0136 1/2 02 Sensor Heater Relay Malfunction P0137 1/2 O2S Shorted To Ground P0138 1/2 O2S Shorted To Voltage P0139 1/2 O2S Slow Response P0140 1/2 O2S Stays At Center P0141 1/2 02 Sensor Relay P0142 O2 Sensor Circuit Bank1 Sensor3 P0143 1/3 O2S Shorted To Ground P0144 1/3 O2S Shorted To Voltage P0145 1/3 O2S Slow Response P0146 1/3 O2S Stays At Center P0147 1/3 02 Sensor Heater Failure P0148 Fuel Delivery Error P0149 Fuel Timing Error
| The Following User Says Thank You to Aqua Puttana For This Useful Post: | kmessinger (08-21-2011) |
#5 |
Next P0149 thru P0375
P0149 Fuel Timing Error P0150 O2 Sensor Circuit Bank2 Sensor1 P0151 2/1 02 Sensor Shorted To Ground P0152 2/1 02 Sensor Shorted To Voltage P0153 2/1 02 Sensor Slow Response P0154 2/1 02 Sensor Stays at Center P0155 2/1 02 Sensor Heater Failure P0156 O2 Sensor Circuit Bank2 Sensor2 P0157 2/2 02 Sensor Shorted To Ground P0158 2/2 02 Sensor Shorted To Voltage P0159 2/2 02 Sensor Slow Response P0160 2/2 02 Sensor Stays at Center P0161 2/2 02 Sensor Heater Failure P0162 O2 Sensor Circuit Bank2 Sensor3 P0163 O2 Sensor Circuit Low Voltage Bank2 Sensor3 P0164 O2 Sensor Circuit Hi Voltage Bank2 Sensor3 P0165 Starter Relay Control Circuit P0166 O2 Sensor Circuit No Activity Detected Bank2 Sensor3 P0167 O2 Sensor Heater Circuit Bank2 Sensor3 P0168 Decreased Engine Perf Due to Hi Inj Pump Fuel Temp P0169 Water-in-fuel detected for too long P0170 Fuel Trim Bank1 P0171 1/1 Fuel Sys Lean P0172 1/1 Fuel Sys Rich P0173 Fuel Trim Bank2 P0174 2/1 Fuel Sys Lean P0175 2/1 Fuel Sys Rich P0176 Loss of Flex Fuel Calibration Signal P0177 Water In Fuel P0178 Flex Fuel Sensor Volts Too Low P0178 Water in Fuel Sensor Volts Too Low or P0179 Flex Fuel Sensor Volts Too Hi P0180 CNG Temp Sensor Voltage Fail P0181 Fuel Inj Pump Failure P0182 CNG Temp Sensor Voltage Too Low P0183 CNG Temp Sensor Voltage Too Hi P0184 Fuel Temp Sensor A Circuit Interm P0185 Fuel Temp Sensor B Circuit P0186 Fuel Temp Sensor B Circuit Range/Perf P0187 Fuel Temp Sensor B Circuit Low P0188 Fuel Temp Sensor B Circuit Hi P0189 Fuel Temp Sensor B Circuit Interm P0190 Fuel Rail Press Sensor Circuit P0191 Fuel Rail Press Sensor Circuit Range/Perf P0192 Fuel Rail Press Sensor Low P0193 Fuel Rail Press Sensor Hi P0194 Fuel Rail Press Sensor Circuit Interm P0195 Engine Oil Temp Sensor P0196 Engine Oil Temp Sensor Range/Perf P0197 Engine Oil Temp Sensor Low P0198 Engine Oil Temp Sensor Hi P0199 Engine Oil Temp Sensor Interm P0200 Injector Circuit/Open P0201 Injector #1 Control Circuit P0202 Injector #2 Control Circuit P0203 Injector #3 Control Circuit P0204 Injector #4 Control Circuit P0205 Injector #5 Control Circuit P0206 Injector #6 Control Circuit P0207 Injector #7 Control Circuit P0208 Injector #8 Control Circuit P0209 Injector #9 Control Circuit P0210 Injector #10 Control Circuit P0211 Injector Circuit/Open-Cylinder 11 P0212 Injector Circuit/Open-Cylinder 12 P0213 Cold Start Injector 1 P0214 Cold Start Injector 2 P0215 Fuel Inj Pump Control Circuit P0216 Fuel Inj Pump Timing Failure P0217 Decreased Eng Perf due to Eng Overheat Condition P0218 Trans Fluid Over Temp Condition P0219 CKP Sensor Overspeed Condition P0220 APP Sensor2 Circuit P0221 APP Sensor2 Circuit Perf P0222 Idle Validation Signals Both Low P0222 APP Sensor2 Circuit Low Voltage or P0223 Idle Validation Signals Both Hi (Above 5Vs) P0223 Inj Pulse Width Error (Rise Time Long) or P0224 Throttle/Pedal Pos Sensor/Switch B Circuit Interm P0225 APP Sensor3 Circuit P0226 APP Sensor3 Circuit Perf P0227 APP Sensor2 Circuit Low Voltage P0228 APP Sensor2 Circuit Hi Voltage P0229 Throttle/Pedal Pos Sensor/Switch C Circuit Interm P0230 Transfer Pump (Lift Pump) Circuit Out Of Range P0231 Fuel Pump Feedback Circuit Low Voltage P0232 Fuel Shut-Off Signal Voltage Too Hi P0233 Fuel Pump Sec Circuit Interm P0234 Turbo Boost Limit Exceeded P0235 T/Super Charger Boost Sensor A Circuit P0236 MAP Sensor Too Hi Too Long P0237 MAP Sensor Voltage Too Low P0238 MAP Sensor Voltage Too Hi P0239 T/Super Charger Boost Sensor B Circuit P0240 T/Super Charger Boost Sensor B Circuit Range/Perf P0241 T/Super Charger Boost Sensor B Circuit Low P0242 T/Super Charger Boost Sensor B Circuit Hi P0243 Open or shorted condition detected in the turbocharger Wastegate solenoid Control P0244 T/Super Charger Wastegate Solenoid A Range/Perf P0245 T/Super Charger Wastegate Solenoid A Low P0246 T/Super Charger Wastegate Solenoid A Hi P0247 T/Super Charger Wastegate Solenoid B P0248 T/Super Charger Wastegate Solenoid B Range/Perf P0249 T/Super Charger Wastegate Solenoid B Low P0250 T/Super Charger Wastegate Solenoid B Hi P0251 Fuel Inj Pump Fuel valve Feedback Circuit P0252 Fuel Inj Pump Fuel Valve Stuck P0253 Fuel Inj Pump Fuel Valve Open Circuit P0254 Fuel Inj Pump Fuel Valve Current Too Hi P0255 Inj Pump Fuel Metering Control A Interm (Cam/Rotor/Injector) P0256 Inj Pump Fuel Metering Control B (Cam/Rotor/Injector) P0257 Inj Pump Fuel Metering Control B Range/Perf (Cam/Rotor/Injector) P0258 Inj Pump Fuel Metering Control B Low (Cam/Rotor/Injector) P0259 Inj Pump Fuel Metering Control B Hi (Cam/Rotor/Injector) P0260 Inj Pump Fuel Metering Control B Interm (Cam/Rotor/Injector) P0261 Cylinder 1 Injector Circuit Low P0262 Cylinder 1 Injector Circuit Hi P0263 Cylinder 1 Balance Sys P0264 Cylinder 2 Injector Circuit Low P0265 Cylinder 2 Injector Circuit Hi P0266 Cylinder 2 Balance Sys P0267 Cylinder 3 Injector Circuit Low P0268 Cylinder 3 Injector Circuit Hi P0269 Cylinder 3 Balance Sys P0270 Cylinder 4 Injector Circuit Low P0271 Cylinder 4 Injector Circuit Hi P0272 Cylinder 4 Balance Sys P0273 Cylinder 5 Injector Circuit Low P0274 Cylinder 5 Injector Circuit Hi P0275 Cylinder 5 Balance Sys P0276 Cylinder 6 Injector Circuit Low P0277 Cylinder 6 Injector Circuit Hi P0278 Cylinder 6 Balance Sys P0279 Cylinder 7 Injector Circuit Low P0280 Cylinder 7 Injector Circuit Hi P0281 Cylinder 7 Balance Sys P0282 Cylinder 8 Injector Circuit Low P0283 Cylinder 8 Injector Circuit Hi P0284 Cylinder 8 Balance Sys P0285 Cylinder 9 Injector Circuit Low P0286 Cylinder 9 Injector Circuit Hi P0287 Cylinder 9 Contribution/Balance P0288 Cylinder 10 Injector Circuit Low P0289 Cylinder 10 Injector Circuit Hi P0290 Cylinder 10 Contribution/Balance P0291 Cylinder 11 Injector Circuit Low P0292 Cylinder 11 Injector Circuit Hi P0293 Cylinder 11 Contribution/Balance P0294 Cylinder 12 Injector Circuit Low P0295 Cylinder 12 Injector Circuit Hi P0296 Cylinder 12 Contribution/Balance P0297 Vehicle Overspeed Condition P0298 Engine Oil Over Temp P0299 T/Super Charger Underboost P0300 Multiple Cylinder Misfire P0301 Cylinder #1 Misfire P0302 Cylinder #2 Misfire P0303 Cylinder #3 Misfire P0304 Cylinder #4 Misfire P0305 Cylinder #5 Misfire P0306 Cylinder #6 Misfire P0307 Cylinder #7 Misfire P0308 Cylinder #8 Misfire P0309 Cylinder #9 Misfire P0310 Cylinder #10 Misfire P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0313 Misfire Detected with Low Fuel P0314 Single Cylinder Misfire (Cylinder not Specified) P0315 Crank Pos Sys Variation Not Learned P0316 Engine Misfire Detected on Startup (First 1000 Revs) P0317 Rough Road Hardware Not Present P0318 Rough Road Sensor A Signal Circuit P0319 Rough Road Sensor B P0320 No Crank Ref Signal at PCM P0321 Ignition/Distributor Engine Speed Input Circuit Range/Perf P0322 Ignition/Distributor Engine Speed Input Circuit No Signal P0323 Ignition/Distributor Engine Speed Input Circuit Interm P0324 Knock Control Sys Error P0325 Knock Sensor #1 Circuit P0326 Knock Sensor1 Circuit Range/Perf Bank1 or Single Sensor P0327 Knock Sensor Noise Channel Low Voltage P0328 Knock Sensor1 Circuit Hi Bank1 or Single Sensor P0329 Knock Sensor1 Circuit Input Interm Bank1 or Single Sensor P0330 Knock Sensor #2 Circuit P0331 Knock Sensor2 Circuit Range/Perf Bank2 P0332 Knock Sensor2 Circuit Low Bank2 P0333 Knock Sensor2 Circuit Hi Bank2 P0334 Knock Sensor2 Circuit Input Interm Bank2 P0335 Crank Pos Sensor Circuit P0336 Crank Pos Sensor Perf P0337 Crank Pos Sensor Circuit Low P0338 Crank Pos Sensor Circuit Hi P0339 Crank Pos Sensor Circuit Interm P0340 No Cam Signal At PCM P0341 CMP Sensor Signal P0342 ESS Voltage Supply Low P0343 ESS Voltage Supply Hi P0344 Camshaft Pos Sensor A Circuit Interm Bank1 or Single Sensor P0345 Camshaft Pos Sensor A Circuit Bank2 P0346 Camshaft Pos Sensor A Circuit Range/Perf Bank2 P0347 Camshaft Pos Sensor A Circuit Low Bank2 P0348 Camshaft Pos Sensor A Circuit Hi Bank2 P0349 Camshaft Pos Sensor A Circuit Interm Bank2 P0350 Ignition Coil Draws Too Much Current P0351 Ignition Coil # 1 Primary Circuit P0352 Ignition Coil # 2 Primary Circuit P0353 Ignition Coil # 3 Primary Circuit P0354 Ignition Coil # 4 Primary Circuit P0355 Ignition Coil # 5 Primary Circuit P0356 Ignition Coil # 6 Primary Circuit P0357 Ignition Coil # 7 Primary Circuit P0358 Ignition Coil # 8 Primary Circuit P0359 Ignition Coil I Primary/Sec Circuit P0360 Ignition Coil J Primary/Sec Circuit P0361 Ignition Coil K Primary/Sec Circuit P0362 Ignition Coil L Primary/Sec Circuit P0363 Misfire Detected-Fueling Disabled P0365 Camshaft Pos Sensor B Circuit Bank1 P0366 Camshaft Pos Sensor B Circuit Range/Perf Bank1 P0367 Camshaft Pos Sensor B Circuit Low Bank1 P0368 Camshaft Pos Sensor B Circuit Hi Bank1 P0369 Camshaft Pos Sensor B Circuit Interm Bank1 P0370 Fuel Inj Pump Speed/Pos Sensor Signal Lost P0371 Timing Ref Hi Res Signal A Too Many Pulses P0372 Timing Ref Hi Res Signal A Too Few Pulses P0373 Timing Ref Hi Res Signal A Interm/Erratic Pulses P0374 Timing Ref Hi Res Signal A No Pulse P0375 Timing Ref Hi Res Signal B
| The Following User Says Thank You to Aqua Puttana For This Useful Post: | Custom12 (11-09-2010) |
#6 |
Next P0375 Thru P0599
P0375 Timing Ref Hi Res Signal B P0376 Timing Ref Hi Res Signal B Too Many Pulses P0377 Timing Ref Hi Res Signal B Too Few Pulses P0378 Timing Ref Hi Res Signal B Interm/Erratic Pulses P0379 Timing Ref Hi Res Signal B No Pulses P0380 Glow Plug Circuit Perf P0380 Intake Air Heater Relay No. 1 Control Circuit or P0381 Wait To Start Lamp Inoperative P0382 Intake Air Heater Relay No. 2 Control Circuit P0383 P0384 Reserved by document P0385 Crank Pos Sensor B Circuit P0386 Crank Pos Sensor B Circuit Range/Perf P0387 CKP Sensor Supply Voltage Too Low P0388 CKP Sensor Supply Voltage Too Hi P0389 Crank Pos Sensor B Circuit Interm P0390 Camshaft Pos Sensor B Circuit Bank2 P0391 Camshaft Pos Sensor B Circuit Range/Perf Bank2 P0392 Camshaft Pos Sensor B Circuit Low Bank2 P0393 Camshaft Pos Sensor B Circuit Hi Bank2 P0394 Camshaft Pos Sensor B Circuit Interm Bank2 P0400 Exhaust Gas ReCircuitulation (EGR) Flow Malfunction P0401 EGR Sys Failure P0402 EGR Flow Excessive Detected P0403 EGR Solenoid Circuit P0404 EGR Pos Sensor Rationality P0405 EGR Pos Sensor Volts Too Low P0406 EGR Pos Sensor Volts Too Hi P0407 Exhaust Gas ReCircuitulation Sensor B Circuit Low P0408 Exhaust Gas ReCircuitulation Sensor B Circuit Hi P0409 Exhaust Gas ReCircuitulation Sensor A Circuit P0410 AIR Sys P0411 Sec Air Inj Sys Incorrect Flow Detected P0412 Sec Air Solenoid Circuit P0413 Sec Air Inj Sys Switching Valve A Circuit Open P0414 Sec Air Inj Sys Switching Valve A Circuit Shorted P0415 Sec Air Inj Sys Switching Valve B Circuit P0416 Sec Air Inj Sys Switching Valve B Circuit Open P0417 Sec Air Inj Sys Switching Valve B Circuit Shorted P0418 Sec Air Inj Sys Control A Circuit P0419 Sec Air Inj Sys Control B Circuit P0420 1/1 Catalytic Conv Eff P0421 Warm Up Catalyst Eff Below Threshold Bank1 P0422 Main Catalyst Eff Below Threshold Bank1 P0423 Heated Catalyst Eff Below Threshold Bank1 P0424 Heated Catalyst Temp Below Threshold Bank1 P0425 Catalyst Temp Sensor Bank1 P0426 Catalyst Temp Sensor Range/Perf Bank1 P0427 Catalyst Temp Sensor Low Bank1 P0428 Catalyst Temp Sensor Hi Bank1 P0429 Catalyst Heater Control Circuit Bank1 P0430 1/2 Catalytic Conv Eff P0431 Warm Up Catalyst Eff Below Threshold Bank2 P0432 1/2 Catalytic Conv Eff P0433 Heated Catalyst Eff Below Threshold Bank2 P0434 Heated Catalyst Temp Below Threshold Bank2 P0435 Catalyst Temp Sensor Bank2 P0436 Catalyst Temp Sensor Range/Perf Bank2 P0437 Catalyst Temp Sensor Low Bank2 P0438 Catalyst Temp Sensor Hi Bank2 P0439 Catalyst Heater Control Circuit Bank2 P0440 Evap Sys Perf P0441 Evap Purge Flow Monitor P0442 Evap Leak Monitor Medium Leak Detected P0443 Evap Purge Solenoid Circuit P0444 Evap Emission Sys Purge Control Valve Circuit Open P0445 Evap Emission Sys Purge Control Valve Circuit Shorted P0446 Evap Emissions Vent Valve Perf P0447 Evap Emission Sys Vent Control Circuit Open P0448 Evap Emission Sys Vent Control Circuit Shorted P0449 Evap Emission Sys Vent Valve/Solenoid Circuit P0450 Evap Emission Sys Press Sensor/Switch P0451 Evap Emission Sys Press Sensor/Switch Range/Perf P0452 Evap Emissions Press Sensor Circuit Low Volts P0453 Evap Emissions Press Sensor Circuit Hi Volts P0454 Evap Emission Sys Press Sensor/Switch Interm P0455 Evap Leak Monitor Large Leak Detected P0456 Evap Leak Monitor Small (0.020) Leak Detected P0457 EVAP Emission Sys Leak Detected (fuel cap loose/off) P0458 EVAP Emission Sys Purge Control Valve Circuit Low P0459 EVAP Emission Sys Purge Control Valve Circuit Hi P0460 Fuel Level Unit No Change Over Miles P0461 Fuel Level Unit No Changeover Time P0462 Fuel Level Sending Unit Volts Too Low P0463 Fuel Level Sending Unit Volts Too Hi P0464 Fuel Level Sensor A Circuit Interm P0465 EVAP Purge Flow Sensor Circuit P0466 EVAP Purge Flow Sensor Circuit Range/Perf P0467 EVAP Purge Flow Sensor Circuit Low P0468 EVAP Purge Flow Sensor Circuit Hi P0469 EVAP Purge Flow Sensor Circuit Interm P0470 Exhaust Press Sensor P0471 Exhaust Press Sensor Range/Perf P0472 Exhaust Press Sensor Low P0473 Exhaust Press Sensor Hi P0474 Exhaust Press Sensor Interm P0475 EPR Solenoid Circuit P0476 Exhaust Press Control Valve Range/Perf P0477 Exhaust Press Control Relay Low P0478 Exhaust Press Control Relay Hi P0479 Exhaust Press Control Valve Interm P0480 Cooling Fan1 Control Circuit Open(Low speed fan) P0481 Fan 2 Control Circuit P0482 Fan 3 Control Circuit P0483 Cooling Fan Speed P0484 Fan Circuit Over Current P0485 Fan Power/Ground Circuit P0486 Exhaust Gas ReCircuitulation Sensor B Circuit P0487 Exhaust Gas ReCircuitulation Throttle Pos Control Circuit P0488 Exhaust Gas ReCircuitulation Throttle Pos Control Range/Perf P0489 Exhaust Gas ReCircuitulation Control Circuit Low P0490 Exhaust Gas ReCircuitulation Control Circuit Hi P0491 Sec Air Inj Sys Insufficient Flow Bank1 P0492 Sec Air Inj Sys Insufficient Flow Bank2 P0493 Fan Overspeed P0494 Fan Speed Low P0495 Fan Speed Hi P0496 EVAP Emission Sys Hi Purge Flow P0497 EVAP Emission Sys Low Purge Flow P0500 No Vehicle Speed Sensor Signal P0501 Vehicle Speed Sensor Perf P0502 Vehicle Speed Sensor A Circuit Low Input P0503 Vehicle Speed Sensor A Interm/Erratic/Hi P0504 Brake Switch A/B Correlation P0505 Idle Air Control Motor Circuits P0506 Idle Control Sys Low RPM P0507 Idle Control Sys Hi RPM P0508 Undercurrent condition detected in linear idle air Control motor feedback Sensore Circuit P0509 Over current condition detected in linear idle air Control motor feedback Sensore Circuit P0510 Closed Throttle Pos Switch P0511 Idle Air Control Circuit P0512 Starter Request Circuit P0513 Incorrect Immobilizer Key P0514 Battery Temp Sensor Perf P0515 Battery Temp Sensor Circuit P0516 Battery Temp Sensor Low P0517 Battery Temp Sensor Hi P0518 Idle Air Control Circuit Interm P0519 Idle Air Control Sys Perf P0520 Engine Oil Press Sensor/Switch Circuit P0521 Oil Press Sensor Perf P0522 Oil Press Sensor Low P0523 Oil Press Sensor Hi P0524 Oil Press Too Low P0525 Cruise Control Servo Control Circuit Range/Perf P0526 Fan Speed Sensor Circuit P0527 Fan Speed Sensor Circuit Range/Perf P0528 Fan Speed Sensor Circuit No Signal P0529 Fan Speed Sensor Circuit Interm P0530 A/C Refrigerant Press Sensor A Circuit P0531 A/C Refrigerant Press Sensor A Circuit Range/Perf P0532 A/C Press Sensor Low P0533 A/C Press Sensor Hi P0534 Air Conditioner Refrigerant Charge Loss P0535 A/C Evaporator Temp Sensor Circuit P0536 A/C Evaporator Temp Sensor Circuit Range/Perf P0537 A/C Evaporator Temp Sensor Circuit Low P0538 A/C Evaporator Temp Sensor Circuit Hi P0539 A/C Evaporator Temp Sensor Circuit Interm P0540 Intake Air Heater A Circuit P0541 Intake Air Relay 1 Low P0542 Intake Air Relay 1 Hi P0543 Intake Air Heater A Circuit Open P0544 Exhaust Gas Temp Sensor Circuit Bank1 Sensor1 P0545 A/C Clutch Relay Circuit P0546 Exhaust Gas Temp Sensor Circuit Hi Bank1 Sensor1 P0547 Exhaust Gas Temp Sensor Circuit Bank2 Sensor1 P0548 Exhaust Gas Temp Sensor Circuit Low Bank2 Sensor1 P0549 Exhaust Gas Temp Sensor Circuit Hi Bank2 Sensor1 P0550 Power Steering Press Sensor/Switch Circuit P0551 Power Steering Switch Failure P0552 Power Steering Press Sensor/Switch Circuit Low Input P0553 Power Steering Press Sensor/Switch Circuit Hi Input P0554 Power Steering Press Sensor/Switch Circuit Interm P0555 Brake Booster Press Sensor Circuit P0556 Brake Booster Press Sensor Circuit Range/Perf P0557 Brake Booster Press Sensor Circuit Low Input P0558 Brake Booster Press Sensor Circuit Hi Input P0559 Brake Booster Press Sensor Circuit Interm P0560 Sys Voltage P0561 Sys Voltage Unstable P0562 Charging Sys Voltage Too Low P0563 Charging Sys Voltage Too Hi P0564 Cruise Control Multi-Function Input A Circuit P0565 Cruise Control On Signal P0566 Cruise Control Off Signal P0567 Cruise Resume Circuit P0568 Cruise Set Circuit P0569 Cruise Control Coast Signal P0570 Cruise Control Accelerate Signal P0571 Cruise Brake Switch Circuit P0572 Brake Switch 1 Low P0573 Brake Switch 1 Hi P0574 Cruise Control Sys-Vehicle Speed Too Hi P0575 Cruise Switch Failure (Shorted) P0576 Cruise Control Input Circuit Low P0577 Cruise Switch Failure (Open) P0578 Cruise Control Multi-Function Input A Circuit Stuck P0579 Cruise Control Multi-Function Input A Circuit Range/Perf P0580 Speed Control Multiplexed Switch 1 Low P0581 Speed Control Multiplexed Switch 1 Hi P0582 Cruise Control Vacuum Control Circuit/Open P0583 Cruise Control Vacuum Control Circuit Low P0584 Cruise Control Vacuum Control Circuit Hi P0585 Cruise Control Multi-Function Input A/B Correlation P0586 Cruise Control Vent Control Circuit/Open P0587 Cruise Control Vent Control Circuit Low P0588 Cruise Control Vent Control Circuit Hi P0589 Cruise Control Multi-Function Input B Circuit P0590 Cruise Control Multi-Function Input B Circuit Stuck P0591 Cruise Control Multi-Function Input B Circuit Range/Perf P0592 Cruise Control Multi-Function Input B Circuit Low P0593 Cruise Control Multi-Function Input B Circuit Hi P0594 Cruise Control Servo Control Circuit/Open P0595 Cruise Control Servo Control Circuit Low P0596 Cruise Control Servo Control Circuit Hi P0597 Thermostat Heater Control Circuit/Open P0598 Thermostat Heater Control Circuit Low P0599 Thermostat Heater Control Circuit Hi
#7 |
Next P0599 thru P0799
P0599 Thermostat Heater Control Circuit Hi P0600 PCM Failure SPI Comms P0601 PCM Internal Controller Failure P0602 ECM Fueling Calibration Error P0603 VCM Memory Reset P0604 RAM Check Failure P0605 ROM Check Failure P0606 ECM Failure P0607 ECU Internal Perf P0608 Control Mod VSS Output A P0609 Control Mod VSS Output B P0610 Control Mod Vehicle Options Error P0611 Fuel Injector Control Mod Perf P0612 Fuel Injector Control Mod Relay Control P0613 TCM Processor P0614 ECM / TCM Incompatible P0615 Starter Relay Control Circuit P0616 Starter Relay Circuit Low P0617 Starter Relay Circuit Hi P0618 Alternative Fuel Control Mod KAM Error P0619 Alternative Fuel Control Mod RAM/ROM Error P0620 Generator Control Circuit P0621 Alternator L Terminal Circuit P0622 Alternator Field Not Switching Properly P0623 Generator Lamp Control Circuit P0624 Fuel Cap Lamp Control Circuit P0625 Generator Field/F Terminal Circuit Low P0626 Generator Field/F Terminal Circuit Hi P0627 Fuel Pump A Control Circuit /Open P0628 Fuel Pump Relay Circuit Low (or) P0628 Fuel Lift Pump Control Circuit Low P0629 Fuel Pump Relay Circuit Hi (or) P0629 Fuel Lift Pump Control Circuit Hi P0630 VIN Not Programmed in PCM P0631 VIN Not Programmed or Incompatible-TCM P0632 Odometer Not Programmed-ECM/PCM P0633 SKIM Key Not Programmed in PCM P0634 PCM/ECM/TCM Internal Temp Too Hi P0635 Power Steering Control Circuit P0636 Power Steering Control Circuit Low P0637 Power Steering Control Circuit Hi P0638 Throttle Actuator Control Range/Perf Bank1 P0639 Throttle Actuator Control Range/Perf Bank2 P0640 Intake Air Heater Control Circuit P0641 Sensor Ref Voltage A Circuit/Open P0642 Sensor Ref Voltage 1 Circuit Low P0643 Sensor Ref Voltage 1 Circuit Hi P0644 Driver Display Serial Comm Circuit P0645 A/C Clutch Relay Circuit Perf P0646 A/C Clutch Relay Circuit Low P0647 A/C Clutch Relay Circuit Hi P0648 Immobilizer Lamp Control Circuit P0649 Speed Control Lamp Control Circuit P0650 Malfunction Indicator Lamp (MIL) Circuit P0651 Sensor Ref Voltage B Circuit/Open P0652 Sensor Ref Voltage 2 Circuit Low P0653 Sensor Ref Voltage 2 Circuit Hi P0654 Engine Speed Output Circuit P0655 Engine Hot Lamp Output Control Circuit P0656 Fuel Level Output Circuit P0657 Actuator Supply Voltage A Circuit/Open P0658 Actuator Supply Voltage A Circuit Low P0659 Actuator Supply Voltage A Circuit Hi P0660 Intake Manif Tuning Valve Control Circuit/Open Bank1 P0661 Intake Manif Tuning Valve Control Circuit Low Bank1 P0662 Intake Manif Tuning Valve Control Circuit Hi Bank1 P0663 Intake Manif Tuning Valve Control Circuit/Open Bank2 P0664 Intake Manif Tuning Valve Control Circuit Low Bank2 P0665 Intake Manif Tuning Valve Control Circuit Hi Bank2 P0666 PCM/ECM/TCM Internal Temp Sensor Circuit P0667 PCM/ECM/TCM Internal Temp Sensor Range/Perf P0668 PCM/ECM/TCM Internal Temp Sensor Circuit Low P0669 PCM/ECM/TCM Internal Temp Sensor Circuit Hi P0670 Glow Plug Mod Control Circuit P0671 Cylinder 1 Glow Plug Circuit P0672 Cylinder 2 Glow Plug Circuit P0673 Cylinder 3 Glow Plug Circuit P0674 Cylinder 4 Glow Plug Circuit P0675 Cylinder 5 Glow Plug Circuit P0676 Cylinder 6 Glow Plug Circuit P0677 Cylinder 7 Glow Plug Circuit P0678 Cylinder 8 Glow Plug Circuit P0679 Cylinder 9 Glow Plug Circuit P0680 Cylinder 10 Glow Plug Circuit P0681 Cylinder 11 Glow Plug Circuit P0682 Cylinder 12 Glow Plug Circuit P0683 Glow Plug Control Mod to PCM Comm Circuit P0684 Glow Plug Control Mod to PCM Comm Circuit Range/Perf P0685 ECM/PCM Power Relay Control Circuit /Open P0686 ECM/PCM Power Relay Control Circuit Low P0687 ECM/PCM Power Relay Control Circuit Hi P0688 ECM/PCM Power Relay Sensore Circuit /Open P0689 ECM/PCM Power Relay Sensore Circuit Low P0690 ECM/PCM Power Relay Sensore Circuit Hi P0691 Fan 1 Control Circuit Low P0692 Fan 1 Control Circuit Hi P0693 Fan 2 Control Circuit Low P0694 Fan 2 Control Circuit Hi P0695 Fan 3 Control Circuit Low P0696 Fan 3 Control Circuit Hi P0697 Sensor Ref Voltage C Circuit/Open P0698 Sensor Ref Voltage 3 Circuit Low P0699 Sensor Ref Voltage 3 Circuit Hi P0700 EATX Controller DTC Present P0701 Trans Control Sys Range/Perf P0702 Trans Control Sys Electrical P0703 Brake Switch Sensore Circuit P0704 Clutch Switch Circuit (M/T) P0705 Trans Range Sensor Circuit Malfunction (PRNDL Input) P0706 Trans Range Sensor Circuit Range/Perf P0707 Trans Range Sensor Circuit Low P0708 Trans Range Sensor Circuit Hi P0709 Trans Range Sensor Circuit Interm P0710 Trans Fluid Temp Sensor A Circuit P0711 Trans Temp Sensor, No Temp Rise After Start P0712 Trans Temp Sensor Voltage Too Low P0713 Trans Temp Sensor Voltage Too Hi P0714 Trans Fluid Temp Sensor A Circuit Interm P0715 Input/Turbine Speed Sensor A Circuit P0716 Input/Turbine Speed Sensor A Circuit Range/Perf P0717 Input/Turbine Speed Sensor A Circuit No Signal P0718 Input/Turbine Speed Sensor A Circuit Interm P0719 Brake Switch B Circuit Low P0720 Low Output SPEED Sensor RPM, Above 15 MPH P0721 Output Speed Sensor Circuit Range/Perf P0722 Output Speed Sensor Circuit No Signal P0723 Output Speed Sensor Circuit Interm P0724 Brake Switch B Circuit Hi P0725 Engine Speed Input Circuit P0726 Engine Speed Input Circuit Range/Perf P0727 Engine Speed Input Circuit No Signal P0728 Engine Speed Input Circuit Interm P0729 Gear 6 Incorrect Ratio P0730 Incorrect Gear Ratio P0731 Gear 1 Incorrect Ratio P0732 Gear 2 Incorrect Ratio P0733 Gear 3 Incorrect Ratio P0734 Gear 4 Incorrect Ratio P0735 Gear 5 Incorrect Ratio P0736 Reverse Incorrect Ratio P0737 TCM Engine Speed Output Circuit P0738 TCM Engine Speed Output Circuit Low P0739 TCM Engine Speed Output Circuit Hi P0740 Torque Conv Clutch, No RPM Drop at Lockup P0741 Torque Conv Clutch Circuit Perf or Stuck Off P0742 Torque Conv Clutch Circuit Stuck On P0743 Torque Conv Clutch Solenoid/Trans Relay Circuits P0744 Torque Conv Clutch Circuit Interm P0745 Press Control Solenoid A P0746 Press Control Solenoid A Perf or Stuck Off P0747 Press Control Solenoid A Stuck On P0748 Governor Press Sol Control/Trans Relay Circuits P0749 Press Control Solenoid A Interm P0750 Shift Solenoid A P0751 O/D Switch Pressed (Low) More Than 5 Minutes P0752 Shift Solenoid A Stuck On P0753 Trans 3-4 Shift Sol/Trans Relay Circuits P0754 Shift Solenoid A Interm P0755 Shift Solenoid B P0756 AW4 Shift Sol B (2-3) Functional Failure P0757 Shift Solenoid B Stuck On P0758 Shift Solenoid B Electrical P0759 Shift Solenoid B Interm P0760 Shift Solenoid C P0761 Shift Solenoid C Perf or Stuck Off P0762 Shift Solenoid C Stuck On P0763 Shift Solenoid C Electrical P0764 Shift Solenoid C Interm P0765 Shift Solenoid D P0766 Shift Solenoid D Perf or Stuck Off P0767 Shift Solenoid D Stuck On P0768 Shift Solenoid D Electrical P0769 Shift Solenoid D Interm P0770 Shift Solenoid E P0771 Shift Solenoid E Perf or Stuck Off P0772 Shift Solenoid E Stuck On P0773 Shift Solenoid E Electrical P0774 Shift Solenoid E Interm P0775 Press Control Solenoid B P0776 Press Control Solenoid B Perf or Stuck off P0777 Press Control Solenoid B Stuck On P0778 Press Control Solenoid B Electrical P0779 Press Control Solenoid B Interm P0780 Shift Error P0781 1-2 Shift P0782 2-3 Shift P0783 3-4 Shift Sol, No RPM Drop at Lockup P0784 4-5 Shift P0785 Shift/Timing Solenoid P0786 Shift/Timing Solenoid Range/Perf P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid Hi P0789 Shift/Timing Solenoid Interm P0790 Normal/Perf Switch Circuit P0791 Intermediate Shaft Speed Sensor A Circuit P0792 Intermediate Shaft Speed Sensor A Circuit Range/Perf P0793 Intermediate Shaft Speed Sensor A Circuit No Signal P0794 Intermediate Shaft Speed Sensor A Circuit Interm P0795 Press Control Solenoid C P0796 Press Control Solenoid C Perf or Stuck off P0797 Press Control Solenoid C Stuck On P0798 Press Control Solenoid C Electrical P0799 Press Control Solenoid C Interm
#8 |
Next P0799 thru P0999
P0799 Press Control Solenoid C Interm P0800 Transfer Case Control Sys (MIL Request) P0801 Reverse Gear Lockout Circuit Open or Short P0802 Trans Control Sys MIL Request Circuit/Open P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit P0805 Clutch Pos Sensor Circuit P0806 Clutch Pos Sensor Circuit Range/Perf P0807 Clutch Pos Sensor Circuit Low P0808 Clutch Pos Sensor Circuit Hi P0809 Clutch Pos Sensor Circuit Interm P0810 Clutch Pos Control Error P0811 Excessive Clutch Slippage P0812 Reverse Input Circuit P0813 Reverse Output Circuit P0814 Trans Range Display Circuit P0815 Upshift Switch Circuit P0816 Downshift Switch Circuit P0817 Starter Disable Circuit P0818 Driveline Disconnect Switch Input Circuit P0819 Up and Down Shift Switch to Trans Range Correlation P0820 Gear Lever X-Y Pos Sensor Circuit P0821 Gear Lever X Pos Circuit P0822 Gear Lever Y Pos Circuit P0823 Gear Lever X Pos Circuit Interm P0824 Gear Lever Y Pos Circuit Interm P0825 Gear Lever Push-Pull Switch (Shift Anticipate) P0826 Up and Down Shift Switch Circuit P0827 Up and Down Shift Switch Circuit Low P0828 Up and Down Shift Switch Circuit Hi P0829 5-6 Shift P0830 Clutch Depressed Switch Circuit P0831 Clutch Pedal Switch A Circuit Low P0832 Clutch Pedal Switch A Circuit Hi P0833 Clutch Released Switch Circuit P0834 Clutch Pedal Switch B Circuit Low P0835 Clutch Pedal Switch B Circuit Hi P0836 Four Wheel Drive (4WD) Switch Circuit P0837 4WD Switch Perf P0838 4WD Switch Circuit Low P0839 4WD Switch Circuit Hi P0840 Trans Fluid Press Sensor/Switch A Circuit P0841 Trans Fluid Press Sensor/Switch A Circuit Range/Perf P0842 Trans Fluid Press Sensor/Switch A Circuit Low P0843 Trans Fluid Press Sensor/Switch A Circuit Hi P0844 Trans Fluid Press Sensor/Switch A Circuit Interm P0845 Trans Fluid Press Sensor/Switch B Circuit P0846 Trans Fluid Press Sensor/Switch B Circuit Range/Perf P0847 Trans Fluid Press Sensor/Switch B Circuit Low P0848 Trans Fluid Press Sensor/Switch B Circuit Hi P0849 Trans Fluid Press Sensor/Switch B Circuit Interm P0850 Park/Neutral Switch Input Circuit P0851 Park/Neutral Switch Input Circuit Low P0852 Park/Neutral Switch Input Circuit Hi P0853 Drive Switch Input Circuit P0854 Drive Switch Input Circuit Low P0855 Drive Switch Input Circuit Hi P0856 Traction Control Input Signal P0857 Traction Control Input Signal Range/Perf P0858 Traction Control Input Signal Low P0859 Traction Control Input Signal Hi P0860 Gear Shift Mod Comm Circuit P0861 Gear Shift Mod Comm Circuit Low P0862 Gear Shift Mod Comm Circuit Hi P0863 TCM Comm Circuit P0864 TCM Comm Circuit Range/Perf P0865 TCM Comm Circuit Low P0866 TCM Comm Circuit Hi P0867 Trans Fluid Press P0868 Trans Fluid Press Low P0869 Trans Fluid Press Hi P0870 Trans Fluid Press Sensor/Switch C Circuit P0871 Trans Fluid Press Sensor/Switch C Circuit Range/Perf P0872 Trans Fluid Press Sensor/Switch C Circuit Low P0873 Trans Fluid Press Sensor/Switch C Circuit Hi P0874 Trans Fluid Press Sensor/Switch C Circuit Interm P0875 Trans Fluid Press Sensor/Switch D Circuit P0876 Trans Fluid Press Sensor/Switch D Circuit Range/Perf P0877 Trans Fluid Press Sensor/Switch D Circuit Low P0878 Trans Fluid Press Sensor/Switch D Circuit Hi P0879 Trans Fluid Press Sensor/Switch D Circuit Interm P0880 TCM Power Input Signal P0881 TCM Power Input Signal Range/Perf P0882 TCM Power Input Signal Low P0883 TCM Power Input Signal Hi P0884 TCM Power Input Signal Interm P0885 TCM Power Relay Control Circuit/Open P0886 TCM Power Relay Control Circuit Low P0887 TCM Power Relay Control Circuit Hi P0888 TCM Power Relay Sensore Circuit P0889 TCM Power Relay Sensore Circuit Range/Perf P0890 TCM Power Relay Sensore Circuit Low P0891 TCM Power Relay Sensore Circuit Hi P0892 TCM Power Relay Sensore Circuit Interm P0893 Multiple Gears Engaged P0894 Trans Component Slipping P0895 Shift Time Too Short P0896 Shift Time Too Long P0897 Trans Fluid Deteriorated P0898 Trans Control Sys MIL Request Circuit Low P0900 Clutch Actuator Circuit/Open P0901 Clutch Actuator Circuit Range/Perf P0902 Clutch Actuator Circuit Low P0903 Clutch Actuator Circuit Hi P0904 Gate Select Pos Circuit P0905 Gate Select Pos Circuit Range/Perf P0906 Gate Select Pos Circuit Low P0907 Gate Select Pos Circuit Hi P0908 Gate Select Pos Circuit Interm P0909 Gate Select Control Error P0910 Gate Select Actuator Circuit/Open P0911 Gate Select Actuator Circuit Range/Perf P0912 Gate Select Actuator Circuit Low P0913 Gate Select Actuator Circuit Hi P0914 Gear Shift Pos Circuit P0915 Gear Shift Pos Circuit Range/Perf P0916 Gear Shift Pos Circuit Low P0917 Gear Shift Pos Circuit Hi P0918 Gear Shift Pos Circuit Interm P0919 Gear Shift Pos Control Error P0920 Gear Shift Forward Actuator Circuit/Open P0921 Gear Shift Forward Actuator Circuit Range/Perf P0922 Gear Shift Forward Actuator Circuit Low P0923 Gear Shift Forward Actuator Circuit Hi P0924 Gear Shift Reverse Actuator Circuit/Open P0925 Gear Shift Reverse Actuator Circuit Range/Perf P0926 Gear Shift Reverse Actuator Circuit Low P0927 Gear Shift Reverse Actuator Circuit Hi P0928 Gear Shift Lock Solenoid Control Circuit/Open P0929 Gear Shift Lock Solenoid Control Circuit Range/Perf P0930 Gear Shift Lock Solenoid Control Circuit Low P0931 Gear Shift Lock Solenoid Control Circuit Hi P0932 Hydraulic Press Sensor Circuit P0933 Hydraulic Press Sensor Range/Perf P0934 Hydraulic Press Sensor Circuit Low P0935 Hydraulic Press Sensor Circuit Hi P0936 Hydraulic Press Sensor Circuit Interm P0937 Hydraulic Oil Temp Sensor Circuit P0938 Hydraulic Oil Temp Sensor Range/Perf P0939 Hydraulic Oil Temp Sensor Circuit Low P0940 Hydraulic Oil Temp Sensor Circuit Hi P0941 Hydraulic Oil Temp Sensor Circuit Interm P0942 Hydraulic Press Unit P0943 Hydraulic Press Unit Cycling Period Too Short P0944 Hydraulic Press Unit Loss of Press P0945 Hydraulic Pump Relay Circuit/Open P0946 Hydraulic Pump Relay Circuit Range/Perf P0947 Hydraulic Pump Relay Circuit Low P0948 Hydraulic Pump Relay Circuit Hi P0949 Auto Shift Manual Adaptive Learning Not Complete P0950 Auto Shift Manual Control Circuit P0951 Auto Shift Manual Control Circuit Range/Perf P0952 Auto Shift Manual Control Circuit Low P0953 Auto Shift Manual Control Circuit Hi P0954 Auto Shift Manual Control Circuit Interm P0955 Auto Shift Manual Mode Circuit P0956 Auto Shift Manual Mode Circuit Range/Perf P0957 Auto Shift Manual Mode Circuit Low P0958 Auto Shift Manual Mode Circuit Hi P0959 Auto Shift Manual Mode Circuit Interm P0960 Press Control Solenoid A Control Circuit/Open P0961 Press Control Solenoid A Control Circuit Range/Perf P0962 Press Control Solenoid A Control Circuit Low P0963 Press Control Solenoid A Control Circuit Hi P0964 Press Control Solenoid B Control Circuit/Open P0965 Press Control Solenoid B Control Circuit Range/Perf P0966 Press Control Solenoid B Control Circuit Low P0967 Press Control Solenoid B Control Circuit Hi P0968 Press Control Solenoid C Control Circuit/Open P0969 Press Control Solenoid C Control Circuit Range/Perf P0970 Press Control Solenoid C Control Circuit Low P0971 Press Control Solenoid C Control Circuit Hi P0972 Shift Solenoid A Control Circuit Range/Perf P0973 Shift Solenoid A Control Circuit Low P0974 Shift Solenoid A Control Circuit Hi P0975 Shift Solenoid B Control Circuit Range/Perf P0976 Shift Solenoid B Control Circuit Low P0977 Shift Solenoid B Control Circuit Hi P0978 Shift Solenoid C Control Circuit Range/Perf P0979 Shift Solenoid C Control Circuit Low P0980 Shift Solenoid C Control Circuit Hi P0981 Shift Solenoid D Control Circuit Range/Perf P0982 Shift Solenoid D Control Circuit Low P0983 Shift Solenoid D Control Circuit Hi P0984 Shift Solenoid E Control Circuit Range/Perf P0985 Shift Solenoid E Control Circuit Low P0986 Shift Solenoid E Control Circuit Hi P0987 Trans Fluid Press Sensor/Switch E Circuit P0988 Trans Fluid Press Sensor/Switch E Circuit Range/Perf P0989 Trans Fluid Press Sensor/Switch E Circuit Low P0990 Trans Fluid Press Sensor/Switch E Circuit Hi P0991 Trans Fluid Press Sensor/Switch E Circuit Interm P0992 Trans Fluid Press Sensor/Switch F Circuit P0993 Trans Fluid Press Sensor/Switch F Circuit Range/Perf P0994 Trans Fluid Press Sensor/Switch F Circuit Low P0995 Trans Fluid Press Sensor/Switch F Circuit Hi P0996 Trans Fluid Press Sensor/Switch F Circuit Interm P0997 Shift Solenoid F Control Circuit Range/Perf P0998 Shift Solenoid F Control Circuit Low P0999 Shift Solenoid F Control Circuit Hi
#9 |
Next P0999 thru P1399 (includes P0A**)
P0999 Shift Solenoid F Control Circuit Hi P0A00 Motor Electronics Coolant Temp Sensor Circuit P0A01 Motor Electronics Coolant Temp Sensor Circuit Range/Perf P0A02 Motor Electronics Coolant Temp Sensor Circuit Low P0A03 Motor Electronics Coolant Temp Sensor Circuit Hi P0A04 Motor Electronics Coolant Temp Sensor Circuit Interm P0A05 Motor Electronics Coolant Pump Control Circuit/Open P0A06 Motor Electronics Coolant Pump Control Circuit Low P0A07 Motor Electronics Coolant Pump Control Circuit Hi P0A08 DC/DC Conv Status Circuit P0A09 DC/DC Conv Status Circuit Low Input P0A10 DC/DC Conv Status Circuit Hi Input P0A11 DC/DC Conv Enable Circuit/Open P0A12 DC/DC Conv Enable Circuit Low P0A13 DC/DC Conv Enable Circuit Hi P0A14 Engine Mount Control Circuit/Open P0A15 Engine Mount Control Circuit Low P0A16 Engine Mount Control Circuit Hi P0A17 Motor Torque Sensor Circuit P0A18 Motor Torque Sensor Circuit Range/Perf P0A19 Motor Torque Sensor Circuit Low P0A20 Motor Torque Sensor Circuit Hi P0A21 Motor Torque Sensor Circuit Interm P0A22 Generator Torque Sensor Circuit P0A23 Generator Torque Sensor Circuit Range/Perf P0A24 Generator Torque Sensor Circuit Low P0A25 Generator Torque Sensor Circuit Hi P0A26 Generator Torque Sensor Circuit Interm P0A27 Battery Power Off Circuit P0A28 Battery Power Off Circuit Low P0A29 Battery Power Off Circuit Hi P1000 Ignition Circuit Low P1001 Ignition Circuit Hi P1004 ECU Battery Feed & Power Grounds P1005 Sys Ground Circuit P1006 EGR/EVAP Solenoid Circuit Low P1007 EGR/EVAP Solenoid Circuit Hi P1008 Power Steering Circuit Low P1009 Power Steering Circuit Hi P1012 MPA Circuit Low P1013 MPA Circuit Hi P1014 Fuel Pump Circuit Low P1015 Fuel Pump Circuit Hi P1016 Charge Air Temp Circuit Low P1017 Charge Air Temp Circuit Hi P1018 Serial Data Circuit P1019 Power Latch Not Set P1021 Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions P1022 Starter Relay Circuit Low P1024 ECU Start Circuit Low P1025 WOT Circuit Low P1026 WOT Circuit Hi P1027 ECU Sees Wide Open Throttle P1028 ECU Does Not See Wide Open Throttle P1029 ISA Closed Throttle Circuit Low P1030 ISA Closed Throttle Circuit Hi P1031 ECU Sees Closed Throttle P1032 ECU Does Not See Closed Throttle P1033 ISA Circuits P1037 TP Sensor Circuit Reads Low P1038 Park/Neutral Line Hi P1039 Park/Neutral Line Low P1040 Latched B+ Line Low P1041 Latched B+ Line Hi P1042 No Latched B+ 1/2 Volt Drop P1043 Shift Lamp Circuit Grounded P1044 D2–1 Circuit Low (A/T) or P1044 Upshift Lamp Circuit (M/T) or P1044 Shift Lamp Circuit Hi P1045 Shift Lamp Circuit Open P1047 Wrong ECU P1048 M/T Vehicle Configuration P1049 A/T Vehicle Configuration P1050 Idle RPM Low P1051 Idle RPM Hi P1052 MAP Sensor Out Of Limits P1053 Change In MAP Reading Out Of Limits P1054 Coolant Sensor & 5V Supply for TP Sensor/MAP Circuits Low P1055 Coolant Sensor Circuit Hi P1056 Inactive Coolant Temp Sensor P1059 A/C Request Circuit Low P1060 A/C Request Circuit Hi P1061 A/C Select Circuit Low P1062 A/C Select Circuit Hi P1063 A/C Clutch Circuit Low P1064 A/C Clutch Circuit Hi & Power Steering Input P1068 Latch Relay Circuit Hi P1069 No Tach P1074 ECU Does Not See Speed Sensor P1106 MAP Sensor Circuit Interm Hi Voltage P1107 MAP Sensor Circuit Interm Low Voltage P1110 Decreased Engine Perf Due To Hi Intake Air Temp P1111 IAT Sensor Circuit Interm Hi Voltage P1112 IAT Sensor Circuit Interm Low Voltage P1114 ECT Sensor Circuit Interm Low Voltage P1115 ECT Sensor Circuit Interm Hi Voltage P1121 TPS Circuit Interm Hi Voltage P1122 TPS Circuit Interm Low Voltage P1125 Accelerator Pedal Pos Sys P1133 HO2S Insufficient Switching Bank1 Sensor1 P1134 HO2S Insufficient Transition Time Ratio Bank1 Sensor1 P1153 HO2S Insufficient Switching Bank2 Sensor1 P1154 HO2S Insufficient Transition Time Ratio Bank2 Sensor1 P1180 Decreased Engine Perf Due To Hi Inj Pump Fuel Temp P1191 Intake Air Duct Leak P1192 Inlet Air Temp Sensor Voltage Low P1193 Inlet Air Temp Voltage Hi P1194 02 Heater Perf P1195 1/1 02 Sensor Slow During Catalyst Monitor P1196 2/1 02 Sensor Slow During Catalyst Monitor P1197 1/2 02 Sensor Slow During Catalyst Monitor P1198 Radiator Temp Sensor Volts Too Hi P1199 Radiator Temp Sensor Volts Too Low P1214 Inj Pump Timing Offset P1216 Fuel Solenoid Response Time Too Short P1217 Fuel Solenoid Response Time Too Long P1218 Inj Pump Calibration Circuit P1271 Accelerator Pedal Pos Sensor1-2 Correlation P1272 Accelerator Pedal Pos Sensor2-3 Correlation P1273 Accelerator Pedal Pos Sensor1-3 Correlation P1275 Accelerator Pedal Pos Sensor1 Circuit P1277 Accelerator Pedal Pos Sensor1 Low Voltage P1278 Accelerator Pedal Pos Sensor1 Hi Voltage P1280 Accelerator Pedal Pos Sensor2 Circuit P1281 Engine is Cold Too Long P1282 Accelerator Pedal Pos Sensor2 Low Voltage P1282 Fuel Pump Relay Control Circuit or P1283 Accelerator Pedal Pos Sensor2 Hi Voltage P1283 Idle Select Signal Invalid or P1284 Fuel Inj Pump Battery Voltage Out Of Range P1285 Accelerator Pedal Pos Sensor3 Circuit P1285 Fuel Inj Pump Controller Always On or P1286 Accelerator Pos Sensor Supply Voltage Too Hi P1287 Accelerator Pedal Pos Sensor3 Low Voltage P1287 Fuel Inj Pump Control Supply Voltage Low or P1288 Accelerator Pedal Pos Sensor3 Hi Voltage P1288 Intake Manif Short Runner Solenoid Circuit or P1289 Manif Tune Valve Solenoid Circuit P1290 CNG Fuel Sys Press Too Hi P1291 No Temp Rise Seen From Intake Heaters P1292 CNG Press Sensor Voltage Too Hi P1293 CNG Press Sensor Voltage Too Low P1294 Target Idle Not Reached P1295 No 5Vs to Throttle Pos Sensor P1296 No 5Vs to MAP Sensor P1297 No Change in MAP from Start To Run P1298 Lean Operation at Wide Open Throttle P1299 Vacuum Leak Found (IAC Fully Seated) P1336 Crank Pos Sys Variation Not Learned P1345 Crank Pos/Camshaft Pos Correlation P1351 Ignition Control Circuit Hi Voltage P1361 Ignition Control Circuit Low Voltage P1380 Electronic Brake Control Rough Road Data Unusable P1381 Misfire Detected-No Electronic Brake Control Data P1388 Auto Shutdown Relay Control Circuit P1389 No ASD Relay Output Voltage at PCM P1390 Timing Belt Skipped 1 Tooth or More P1391 Interm Loss of CMP or CKP P1398 Misfire Adaptive Numerator at Limit P1399 Wait to Start Lamp Circuit
NAFTA 2004 OM647 140 2500 Std Roof >255,000 mi. Paint=Arctic Whitewash DAD "My opinion and worth everything you'll never pay for it." is expressly implied. Keeping me on topic will be as successful as herding cats. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR Some people have 10 years experience, others just 1 year 10 times. Last edited by Aqua Puttana; 02-01-2009 at 02:14 PM. |
#10 |
Next P1399 thru P2099
P1399 Wait to Start Lamp Circuit P1403 No 5Vs to EGR Sensor P1404 EGR Valve Closed Pintle Pos P1406 EGR Valve Pos P1409 EGR Valve Sys leak P1415 AIR Sys Bank1 P1416 AIR Sys Bank1 P1441 Evap Emissions Flow During Non-Purge P1475 Auxiliary 5V Supply Voltage Hi P1476 Too Little Sec Air P1477 Too Much Sec Air P1478 Battery Temp Sensor Volts Out of Limit P1479 Trans Fan Relay Circuit P1480 PCV Solenoid Circuit P1481 EATX Misfire RPM Signal out of Range P1482 Catalyst Temp Sensor Circuit Shorted Low P1483 Catalyst Temp Sensor Circuit Shorted Hi P1484 Catalytic Conv Overheat Detected P1485 Air Inj Solenoid Circuit P1486 Eva Leak Monitor Pinched Hose Found P1487 Hi Speed Radiator Fan Control Relay Circuit P1488 Auxiliary 5V Supply Output Too Low P1489 Hi Speed Fan Control Relay Circuit P1490 Low Speed Fan Control Relay Circuit P1491 Radiator Fan Control Relay Circuit P1492 Ambient/Battery Temp Sensor Volts Too Hi P1493 Ambient/Battery Temp Sensor Volts Too Low P1494 Leak Detection Pump Switch or Mechanical Fault P1495 Leak Detection Pump Solenoid Circuit P1496 5V Supply, Output Too Low P1498 Hi Speed Radiator Fan Ground Control Relay Circuit P1508 IAC Sys Low RPM P1509 IAC Sys Hi RPM P1594 Charging Sys Voltage Too Hi P1595 Speed Control Solenoid Circuits P1596 Speed Control Switch Always Hi P1597 Speed Control Switch Always Low P1598 A/C Press Sensor Volts Too Hi P1599 A/C Press Sensor Volts Too Low P1602 PCM Not Programmed P1621 PCM Memory Perf or Write P1626 Vehicle Theft Sys Control Loss of Data P1627 A/D Perf P1630 Vehicle Theft Sys PCM in Learn Mode P1631 Vehicle Theft Sys Improper Password P1635 5V Ref ( Circuit P1639 5V Ref ( Circuit P1641 MIL Control Circuit P1643 Wait To Start Lamp Control Circuit P1646 5V Ref (C) Circuit P1652 J1850 Comms Bus P1653 EGR Vent Solenoid Control Circuit P1654 Service Throttle Soon Lamp Control Circuit P1655 EGR Solenoid Control Circuit P1656 Wastegate Solenoid Control Circuit P1680 Clutch Released Switch Circuit P1681 No I/P Cluster CCD/J1850 Messages Received P1682 Charging Sys Voltage Too Low P1683 Speed Control Power Relay; or S/C 12v Driver CKT P1684 Battery Disconnected in the last 50 Starts P1685 Skim Invalid Key P1686 No SKIM BUS Messages Received P1687 No Cluster BUS Message P1688 Internal Fuel Inj Pump Controller Failure P1689 No Comm between ECM & Inj Pump Mod P1690 CKP Sensor Does Not Agree with ECM CKP Sensor P1691 Fuel Sys ESS RPM Error P1692 DTC Set In ECM P1693 DTC Detected in Companion JTEC Mod P1694 No BUS Message Received from ECM Mod P1695 No CCD/J1850 Messages from the Body Control Mod. P1696 PCM Failure EEPROM Write Denied P1697 PCM Failure SRI Mile Not Stored P1698 No CCD/J1850 Message From TCM/PCM P1719 Skip Shift Solenoid Circuit P1740 TCC or O/D Solenoid Perf P1756 Gov Press Not Equal to Target @ not15-20 PSI P1757 Gov Press above 3 PSI in gear with 0 MPH P1762 Gov Press Sensor Offset Volts Too Low or Hi P1763 Governor Press Sensor Volts Too Hi P1764 Governor Press Sensor Volts Too Low P1765 Trans 12 Volt Supply Relay Control Circuit P1899 P/N Switch Stuck in Park or in Gear P2000 NOx Trap Eff Below Threshold Bank1 P2001 NOx Trap Eff Below Threshold Bank2 P2002 Particulate Trap Eff Below Threshold Bank1 P2003 Particulate Trap Eff Below Threshold Bank2 P2004 Intake Manif Runner Control Stuck Open Bank1 P2005 Intake Manif Runner Control Stuck Open Bank2 P2006 Intake Manif Runner Control Stuck Closed Bank1 P2007 Intake Manif Runner Control Stuck Closed Bank2 P2008 Intake Manif Runner Control Circuit/Open Bank1 P2009 Intake Manif Runner Control Circuit Low Bank1 P2010 Intake Manif Runner Control Circuit Hi Bank1 P2011 Intake Manif Runner Control Circuit/Open Bank2 P2012 Intake Manif Runner Control Circuit Low Bank2 P2013 Intake Manif Runner Control Circuit Hi Bank2 P2014 Intake Manif Runner Pos Sensor/Switch Circuit Bank1 P2015 Intake Manif Runner Pos Sensor/Switch Circuit Range/Perf Bank1 P2016 Intake Manif Runner Pos Sensor/Switch Circuit Low Bank1 P2017 Intake Manif Runner Pos Sensor/Switch Circuit Hi Bank1 P2018 Intake Manif Runner Pos Sensor/Switch Circuit Interm Bank1 P2019 Intake Manif Runner Pos Sensor/Switch Circuit Bank2 P2020 Intake Manif Runner Pos Sensor/Switch Circuit Range/Perf Bank2 P2021 Intake Manif Runner Pos Sensor/Switch Circuit Low Bank2 P2022 Intake Manif Runner Pos Sensor/Switch Circuit Hi Bank2 P2023 Intake Manif Runner Pos Sensor/Switch Circuit Interm Bank2 P2024 EVAP Emissions (EVAP) Fuel Vapor Temp Sensor Circuit P2025 EVAP Fuel Vapor Temp Sensor Perf P2026 EVAP Fuel Vapor Temp Sensor Circuit Low Voltage P2027 EVAP Fuel Vapor Temp Sensor Circuit Hi Voltage P2028 EVAP Fuel Vapor Temp Sensor Circuit Interm P2029 Fuel Fired Heater Disabled P2030 Fuel Fired Heater Perf P2031 Exhaust Gas Temp Sensor Circuit Bank1 Sensor2 P2032 Exhaust Gas Temp Sensor Circuit Low Bank1 Sensor2 P2033 Exhaust Gas Temp Sensor Circuit Hi Bank1 Sensor2 P2034 Exhaust Gas Temp Sensor Circuit Bank2 Sensor2 P2035 Exhaust Gas Temp Sensor Circuit Low Bank2 Sensor2 P2036 Exhaust Gas Temp Sensor Circuit Hi Bank2 Sensor2 P2037 Reductant Inj Air Press Sensor Circuit P2038 Reductant Inj Air Press Sensor Circuit Range/Perf P2039 Reductant Inj Air Press Sensor Circuit Low Input P2040 Reductant Inj Air Press Sensor Circuit Hi Input P2041 Reductant Inj Air Press Sensor Circuit Interm P2042 Reductant Temp Sensor Circuit P2043 Reductant Temp Sensor Circuit Range/Perf P2044 Reductant Temp Sensor Circuit Low Input P2045 Reductant Temp Sensor Circuit Hi Input P2046 Reductant Temp Sensor Circuit Interm P2047 Reductant Injector Circuit/Open Bank1 Unit 1 P2048 Reductant Injector Circuit Low Bank1 Unit 1 P2049 Reductant Injector Circuit Hi Bank1 Unit 1 P2050 Reductant Injector Circuit/Open Bank2 Unit 1 P2051 Reductant Injector Circuit Low Bank2 Unit 1 P2052 Reductant Injector Circuit Hi Bank2 Unit 1 P2053 Reductant Injector Circuit/Open Bank1 Unit 2 P2054 Reductant Injector Circuit Low Bank1 Unit 2 P2055 Reductant Injector Circuit Hi Bank1 Unit 2 P2056 Reductant Injector Circuit/Open Bank2 Unit 2 P2057 Reductant Injector Circuit Low Bank2 Unit 2 P2058 Reductant Injector Circuit Hi Bank2 Unit 2 P2059 Reductant Inj Air Pump Control Circuit/Open P2060 Reductant Inj Air Pump Control Circuit Low P2061 Reductant Inj Air Pump Control Circuit Hi P2062 Reductant Supply Control Circuit/Open P2063 Reductant Supply Control Circuit Low P2064 Reductant Supply Control Circuit Hi P2065 Fuel Level Sensor B Circuit P2066 Fuel Level Sensor B Perf P2067 Fuel Level Sensor B Circuit Low P2068 Fuel Level Sensor B Circuit Hi P2069 Fuel Level Sensor B Circuit Interm P2070 Intake Manif Tuning (IMT) Valve Stuck Open P2071 IMT Valve Stuck Closed P2075 IMT Valve Pos Sensor/Switch Circuit P2076 IMT Valve Pos Sensor/Switch Circuit Range/Perf P2077 IMT Valve Pos Sensor/Switch Circuit Low P2078 IMT Valve Pos Sensor/Switch Circuit Hi P2079 IMT Valve Pos Sensor/Switch Circuit Interm P2080 Exhaust Gas Temp Sensor Circuit Range/Perf Bank1 Sensor1 P2081 Exhaust Gas Temp Sensor Circuit Interm Bank1 Sensor1 P2082 Exhaust Gas Temp Sensor Circuit Range/Perf Bank2 Sensor1 P2083 Exhaust Gas Temp Sensor Circuit Interm Bank2 Sensor1 P2084 Exhaust Gas Temp Sensor Circuit Range/Perf Bank1 Sensor2 P2085 Exhaust Gas Temp Sensor Circuit Interm Bank1 Sensor2 P2086 Exhaust Gas Temp Sensor Circuit Range/Perf Bank2 Sensor2 P2087 Exhaust Gas Temp Sensor Circuit Interm Bank2 Sensor2 P2088 A Camshaft Pos Actuator Control Circuit Low Bank1 P2089 A Camshaft Pos Actuator Control Circuit Hi Bank1 P2090 B Camshaft Pos Actuator Control Circuit Low Bank1 c) P2091 B Camshaft Pos Actuator Control Circuit Hi Bank1 c) P2092 A Camshaft Pos Actuator Control Circuit Low Bank2 P2093 A Camshaft Pos Actuator Control Circuit Hi Bank2 P2094 B Camshaft Pos Actuator Control Circuit Low Bank2 c) P2095 B Camshaft Pos Actuator Control Circuit Hi Bank2 c) P2096 Post Catalyst Fuel Trim Sys Too Lean Bank1 P2097 Post Catalyst Fuel Trim Sys Too Rich Bank1 P2098 Post Catalyst Fuel Trim Sys Too Lean Bank2 P2099 Post Catalyst Fuel Trim Sys Too Rich Bank2
| The Following 3 Users Say Thank You to Aqua Puttana For This Useful Post: |
| Thread Tools | |
| Display Modes | |
