#51 |
2005 140" low roof
Finally made some good progress...
Gas lift and ball catches on sink lid to reduce rattle and hold the lid open New side panels & rear speakers with added wall insulation I still need to cover the outer insulation on the rear lower panels Cheers George |
#52 |
2005 140" low roof
Rear view of storage compartments, track system and bed extension
(Seek should recognize the latch...) Cheers George |
| The Following 3 Users Say Thank You to georgetg For This Useful Post: |
#53 |
2005 140" low roof
Leather covered steering wheel from Germany (I think the same as Opa_R no blue stitching though)
It's the same 390mm wheel as in the MB Viano Easy install 2 torqx and a 10mm Allen screw (disconnect the battery before fooling with the airbag) 110 Euros, feels great! Cheers George |
| The Following User Says Thank You to georgetg For This Useful Post: | seans (11-05-2010) |
#54 |
2005 140" low roof
Upgraded radio to the JVC KD AVX40 and added homemade Ipod dock
The second tilt position matches the dash slope perfectly... Cheers George |
#56 |
Your van looks great, did you fabricate the sink frig. unit, or can it purchased as a unit. thanks rex
| The Following User Says Thank You to designrmi For This Useful Post: | georgetg (12-13-2009) |
#57 | |
2005 140" low roof
Sortimo makes an outdoor module based on their storage solutions peek around their site, I got a lot of inspiration from their work... (Plus they make the VW Multivan wall table and transforming track table...) http://www.sortimo-speedwave.de Cheers George |
| The Following User Says Thank You to georgetg For This Useful Post: | ECU (12-29-2009) |
#58 |
2005 140" low roof
#59 |
2005 140" low roof
Aux battery replacement:
My original aux batteries were refurbished, $25 each. They lasted almost 4 years with very poor capacity in the last year. so I sourced replacement batteries. My new batteries are Powersonic 12750 75AH Gel cel batteries. They have nearly identical dimensions although I did have to rework the battery hold-down because of the different terminal configuration. Cheers George
2005 316CDI Graphite Metallic Low Roof 140" wheel base passenger van, VW Multivan T5 floor-group and seats with aluminum tracks, Aluminum galley with fridge microwave and sink, 2 Powersonic 75AH gel-cel, Xantrex XM1800 Inverter, 18" G-Wagen "Ashtaroth" wheels Cooper Discover H/T Plus 265/60 R18, Koni red shocks, Fantastic Fan 6000rbta. http://sprinter-source.com/forum/sho...+camper&page=6 |
#60 |
George, Can you describe the wiring and fuses that you use for your aux battery setup?
I have one of those same batteries and I am thinking of adding a second one. What wire gauge from your alternator to your battery bank, fuse sizes for the alternator run, fuse for between batteries, fuse for the inverter? Thanks! |
| Thread Tools | |
| Display Modes | |
