After a false start 2014/01/01 Edit: a few false starts, I'm starting this thread in an attempt to condense some of the Sprinter Espar heater wiring information into one place.
There is much more information available in various threads in the Database section.
First let me say that I haven't yet repaired my 2004 Espar Hydronic Booster heater. Because it is not working edit: It works now. (as yet /still), I have not modified it to run as an engine warming unit without the engine operating. I have however learned some things and dug up quite a bit of information related to theSprinter standard Espar heaters and now Sprinter Espar D5 units with custom controls.
One thing that I have learned is that there is some information floating around which I don't believe is completely accurate as to the actual wiring of the Sprinter heater. Some of that is in the Sprinter Service Manuals.
The standard ESPAR D5 diesel fired heater units are designed to be installed into many different vehicles and even boats. The design requires only proper voltage, proper fuel, and an enable signal for the heater to fire up and run. MB has requested some modifications of the controls, but even the Sprinter heaters are still basically standard. The Espar heaters can be enabled by different control configurations. Those options range from a simple on-off switch, to a basic thermostat, up to more complex programmable controls.
Note: One expert I've communicated with warned that Bio-fuel is a problem with the Espar heaters. He even cautions against 5% and suggests installing a "Day Tank" and running the heaters on Kerosene. I can't disagree, but installing a day tank with easy fill capability is likely easier said than done. He mentioned that a coffee colored residue which is harder to clean than the normal black soot is one evidence of bio-fuel rlated problems.
Here is what the Sprinter manual describes as the Aux Electric Coolant (aka Water) Pump operation.
Sprinter Electric Coolant Pump Operation
From VA Manual - Plumbing 24 - 75
OPERATION
The electric coolant pump is controlled by the ATC
A/C-heater control and is only operational when the
ignition switch is on under the following conditions:
(1) Vehicle speed below 27 Km/h (17 mph).
(2) Coolant temperature above 65° C (150° F) but
less than 110° C (230 ° F).
(3) Any blower motor speed setting.
(4) Temperature heat setting above the halfway
setting (60% heat).
(5) The pump will turn off at speeds above 48
Km/h (30 mph).
(6) The pump will turn off if the coolant temperature
rises above 110° C (230 ° F).
Even though not mentioned above, the aux electric coolant pumpis also subject to Espar control 12V power is applied to Pin #6 to enable the Sprinter Espar D5 (pump energized).
Mercedes in their wisdom decided to combine circuits with only a couple little note symbols to differentiate the various options. What that does is split the Espar connections into different places depending upon which heater option you have. The schematics are even more complex than I imagined.
It is extremely important to pay attention to the little symbols in the Sprinter schematics.
Cabin Heater Module = (Booster or Aux Heater)
REST System = (Stand alone engine heat scavaging)
Program Timer = (Timed or Programmed Aux Heater)
Except Program Timer = (Booster heater - engine running type)
AND
the actual pin numbers on the split up or sectioned dotted line box Espar Heater connector or "Cabin Heater Module (CHM)" as it is called in the schematic. Eg. - Note that the "Program Timer" Espar Pin #6 shows in both 8W-42-10 and in 8W-42-11. It is the same Pin #6, a duplication including the C204 Pin #7 above it.
I have added some notes to the schematics below. I know that the other related schematics (fan control and ATC module) will benefit from explanation notes too.
I'm not smart enough to create documents directly from the PDF manuals. Some of these are printed pages, hand written notes added, and scanned. If the picture detail is not good enough then you can refer to the ESPAR PDF for details.
The Sprinter VA Service Manual is available in the Database Section of the forum for the Service Manual 8w diagrams.
Please note that MB made no attempt to carry the Espar Heater connector wire colors out into the Sprinter.
NOTE:
The diode circuit modification will woork. There is a better circuit which I outline here.
REST/Booster Engine Pre-heat with DPDT Switch Modification
https://sprinter-source.com/forums/showthread.php?t=36797
My conclusion is that a 12 volt input to Pin #7 of the Sprinter Booster Heater will allow the heater to run as an engine pre-warmer withno other modifications needed one other minor mod . That is a blue wire with switch and diode for the Booster configuration and a yellow wire for the timed configuration. There should be enough info provided here to decide if that is correct. vic
Note the pin numbers in 8W-42-11 (2 each pin #6 ) may appear to be incorrect for an "enable". That is because they are showing only a section of the connector. Some of the pins are shown in 8W-42-10.
Also note the "Fused Optional Equipment Relay Output" label on the Espar heater connections. It would more properly be named "Input" as opposed to "Output". The Espar heater is named the "Cabin Heater Module (CHM)" on the Sprinter schematic. That "Fused Optional Equipment Relay Output" is the electric coolant pump power "on" 12V input in the case of the Sprinter Booster installations.
I also believe that the OEM pump diode configuration isn't shown correctly. I can see no real purpose for the diode wired in as shown. My red line to the diode/pump node shows what I believe would be correct to prevent backfeed to the Sprinter electrics when the ESPAR control is calling for the pump to run. The diode *may* be is definitely related to keeping "pump power on" 12V from getting to Espar Pin #6 while the REST System is running the Aux Electric Coolant Pump.
This is from the Espar PDF.
Here is one idea for a simple on-off switch to enable and run the Booster Heater configuration only without the engine operating. It requires only 2 wires to the dash for the switch and a fuse with diode and wire under the hood. This will only heat the engine and cabin for approx 30 minutes.It will not operate the cabin blower fan. I suspect that a another similar switch (or 1 ea. DPDT switch) could be used with the ATC/REST function to get the fan too. I haven't explored the circuit because I don't need that.
As an aside. I considered using a polarity blocking diode for the Pin #7 Enable feed. Normally that would work and reduce wire needed to the dash. From comments posted on some boating forums, I know that the Espar D5 computer module monitors supply voltage and will shut the heater off if it goes low. The voltage drop of the diode might be noticed. That drop isn't important for the blocking diode shown for the Electric Coolant (water) Pump, but it MAY matter for the supply voltage.Running one wire as opposed to running two wires up to the dash is no big deal anyway. No wires from dash to under hood are needed.
Based upon the comments in the method described in the next post below, it should be easy to locate and intercept the blue wire at the ATC Automatic Temperature Control in the dash to install the SPDT switch. The cigar lighter power socket can be used for the 12 volt supply as suggested also.
The fuse/diode and wire is fairly easily installed in the engine bay.
I tested my modification and it works even with the 10 amp Heater Control Power fuse removed from under the driver seat. The diode is to prevent/block the Pin #6voltage from backfeeding to other circuits during normal operation.
This updated circuit has some advantages. One of the things which I was not thrilled with about a "Constant Run" option was that the added Espar Booster Heater "Engine Off" SPDT switch could be bumped to the "On" position or forgotten. That would keep the diesel D5 heater operating forever. With the switch and diode circuit then the Espar D5 engine off operating time is limited to the 30 minute REST timed cycle.
From member comments the approx 30 minute run time should be enough to pre-heat the engine. If it is not enough in extremely low temperatures, then another REST cycle with the added SPDT switch enabled can be intiated to add another 30 minute time cycle.
Basic Circuit Description
The SPDT switch opens the blue wire from the ATC Automatic Temperature Control to stop any feedback of 12V to the ATC or other circuits. The constant 12V(+) (eg. - from the Power Outlet) feeds through the SPDT switch via the OEM blue wire to power Pin #7 "Heater On" or enable on the Espar heater. Note: The Espar will not actually start until it gets the "Pump Power Verify" signal to Pin #6 from the REST operation.
When the REST button is pushed the Aux Electric Coolant Pump is energized for a time of approx 30 minutes. The wire tapped off the DG/RD wire at the pump connector feeds 12V "Pump Power Verify" or 2nd Enable via the diode to Pin #6 of the Espar Heater. When the REST fan times out the "Pump Power Verify" 12V goes away and the Espar heater initiates a shutdown. When Pin #6 of the Espar is energized during any normal OEM Sprinter operation then the diode blocks any voltage from backfeeding to the Coolant Pump. (A diode in this configuration acts like a check valve in a water system.)
This circuit will not adversly affect any other OEM Sprinter circuit operations. The REST System will not turn on the Espar heater until the SPDT switch is "On" to enable Pin #7.
Using the SPDT switch assures no backfeed of power to the ATC or any other circuits. I wasn't able to determine for certain whether backfeeding of voltage to the ATC would have any adverse affects or not. The safe route is to use the SPDT switch.
It *may* be OK to just use a SPST switch and feed the Blue Pin #7 wire 12 volts directly without worrying about feedback. That is ok to do. There is no backfeed problems with the ATC and the blue wire.
Some additional information is in this thread.
https://sprinter-source.com/forums/showthread.php?p=273061#post273061
Some other 2004 Espar Booster Heater threads which I've posted are here:
Some 2004 Espar Heater Notes
https://sprinter-source.com/forums/showthread.php?t=30384
Remove Espar Heater from T1N
https://sprinter-source.com/forums/showthread.php?t=30427
General Espar Heater Wiring Information
https://sprinter-source.com/forums/showthread.php?t=30191
Cabin Fan Resistor Circuits
https://sprinter-source.com/forums/showthread.php?t=30286
T1N Booster Heater Wireless Control
https://sprinter-source.com/forums/showthread.php?t=30512
My thought process/approach is more that the standard Hydronic Espar Heater is a stand alone unit. It requires proper voltage (constant Pin #1 and "enable" Pin #7), proper fuel (a metered pulsed supply), combustion air (internal fan), and enough coolant flow to keep the water and combustion chamber shell temperatures within proper range (electric pump or engine pump). What MB does to the unit is Sprinter specific.
If you satisfy the basic conditions above the Espar heater will run using its own internal control module. ...
OPERATION
setting (60% heat).
Km/h (30 mph).
Due to some of the names and nomenclature used in the heater circuit information I feel that it is easy to get lost in the documentation. That MB labels the Espar Heater Unit a "module" is just one example.I forgot to mention this.
I know that my Espar Booster heater has a 12 vdc supply that is not subject to the ATC Automatic Temperature Control push switch or the ignition key position. I figured that out during my heater testing. One of the times that I got the heater to run I noticed that it continued to run in a cool down or programmed shutdown cycle even after both the dash switch and the ignition key were off.
The programmed shutdown cycle is mentioned in the Espar controls description. So the Sprinter heater does have a 12 volt supply which allows the Espar module to operate the heater even when the Sprinter is not calling for it. By extension, I'm pretty certain that the Espar module keeps the electric coolant pump operating during that shutdown cycle to avoid overheating, but I didn't think to check for that at the time.In other words, the ESPAR module maintains the ability to control the Sprinter electric aux coolant pump. (Edit: Both the Sprinter and the Espar schematics support that idea.)The Sprinter Espar D5 does not care if the pump is running or not during the programmed cooldown/shutdown cycle. FWIW. vic
AND
NOTE:
