Old 11-26-2013, 05:45 PM   #1
cvcsmkr
Default Help: Turbo louder than Normal, loss of power, CE Codes
Out of nowhere I lost power and CE light came on. I didn't happen to have my scan gauge so reset battery and truck seem to operate normal after that. Then today it did the same thing again loss of power, CE light on. Plugged in the scan gauge and got codes: P0087, 0673, 0672, 0671, 0380. They all seem to be related to the glow plug beside the crank position sensor code. But the turbo seems to be a lot louder than normal, once it gets over 7lbs it almost squeals.
What do you guys think is going on?
cvcsmkr is offline   Reply With Quote
Old 11-26-2013, 06:10 PM   #2
NelsonSprinter
Former Nelson BC Sprinter
NelsonSprinter's Avatar
Default Re: Help: Turbo louder than Normal, loss of power, CE Codes
I'm pretty sure the hoses or hose connections have a leak/split in the turbo charged air lines.
The loss of pressure causes loss of turbo power and LHM. The leak causes the squealing.
Check all turbo hoses from turbo resonator to EGR and if that finds no loose connection or splits, check the intercooler,
Previous owner of '02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Cdn GDE ECO Tuned. . . I am NOT a MECHANIC, I just play one online. I also drive a MB Smart CDI.
Old 11-26-2013, 09:24 PM   #3
cahaak
cahaak's Avatar
Check the resonator also, it may have split at the seam and will be difficult to see.
Chris
2006 140" passenger
normal roof with rear AC
Old 11-27-2013, 02:25 AM   #4
What does the scangauge report for MAP when you're in a "low power" situation?
If it's not boosting, then the ECM has probably decided that there's a leak and stopped asking for it.
Lots of service documentation can be found at: http://aie-services-2.net/Sprinter/
Old 11-27-2013, 02:51 AM   #5
sailquik
sailquik's Avatar
cvcsmkr:
So, you are getting 7 PSI Gauge Pressure when you put the PID BST in your ScanGauge?
Depending on your altitude, that's only equal to ~ 20-21 PSIA MAP (What your Sprinter's systems actually look and and use to give you
the correct Manifold Absolute Pressure (MAP).
At sea level altitude.... your MAP will read 14.7 PSIA at idle or with the engine off. (This is the ambient atmospheric pressure at sea level.
So your BST reading would be zero.
Add your 7 PSIG to the 14.7 PSIA (ambient @ sea level) and you get 21-22 PSIA MAP when it should be up around 34 PSIA.
Sounds like I agree with all the others here....you have a turbo boost leak somewhere.
